学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Short Battery Life
Your OnePlus 6 can do all sorts of things, but spends a lot of time on the charger.
Using Power-Hungry Apps
If you spend a lot of time playing Clash of Clans or watching cat videos on the internet, this could drain your battery quickly. You can check what apps are draining your battery by going into Settings > Battery > Usage Details. You should see a list of apps and how much power they are using. Try using the more power-hungry apps less. If these are apps that you don’t use, you could uninstall them.
Brightness is Too High
You can adjust your brightness by going into Settings > Display > Brightness Level. The lower the brightness, the longer your battery will last. Just make sure you can still see what’s on your screen.
Battery is Faulty
If your OnePlus 6 is old, it’s possible that your battery has degraded and can no longer hold as much charge as a new battery. This is the most drastic and difficult solution, so try our other solutions before attempting to replace your battery.
You can purchase a new battery here.
You can find a guide to replace your battery here.
Overheating
The device feels physically hot to the touch.
Multiple Active Apps
Having too many active apps whilst the phone is not in use is a solid reason as to why it overheats, especially if the phone is being charged. The most reliable way to solve such a problem would be to charge the phone on airplane mode and also turn off active apps that are not in use.
Regular Playing of Games on Device
Playing games regularly contributes to the many factors that may allow the phone to overheat. To bring these factors under control , use one gaming app at a time , lower the brightness of the phone light , take breaks when playing , and remove phone’s protective cases if there is any. By using one app at a time, the phone ram usage is being lowered. Lowering the brightness of the phone light allows for a lesser use of energy and removing the case from the phone is a way of not trapping heat to the device. It is also very important to take breaks when playing as games demand a lot of the phone resources.
Battery Has a Fault
The degradation of a battery life over a period of time leads to overheating of a phone. Replacing the faulty battery is the best solution you can possibly do to solve the overheating issue on the phone. So a new battery can be installed.
You can purchase your new battery here.
You can find directions to replace your battery here.
Back Camera is Broken
Your device cannot access the camera.
Camera is Being Used by Another App
When a blank screen appears, the camera may be being used by another application on the phone. To ensure this is not happening, close all apps or apps that have access to the camera, then return to the camera application.
Camera Connector is Loose
The camera connector on the OnePlus 6 may come loose over time due to wear and tear causing the camera to show a black screen or the screen being fidgety. By using the breakdown guide, readjust the connector so that it is firmly fixed to the camera. If the connector is damaged, a new connector must be installed.
Camera Needs to be Replaced
Dropping or hitting the back of the phone can cause the camera lens to become cracked or cause broken hardware inside the camera. If you see that the lens is visibly cracked, breakdown the phone to gain access to the camera and replace the camera with a new one.
You can purchase a back camera replacement here.
You can find the replacement guide for the camera here.
Side Buttons Are Not Working
When you press the volume buttons or the power button, nothing happens.
Phone is Frozen or Off
If the phone intermittently does not respond to button input, there may be a software issue. Try closing unused applications or powering off and then powering on the phone.
Button Connector is Loose
Impact to the phone from dropping or hitting it on something can cause the button connection to loosen. If this happens, the phone will need to be disassembled and the button flex cable fully reconnected.
Buttons Need to be Replaced
If the button flex cable is not loose, or the button is physically cracked or damaged, the button will need to be replaced.
You can find the replacement parts for side buttons here.
You can find the button replacement guide here.
OnePlus 6 Will Not Turn on
When you press the power button, nothing happens.
Battery is Depleted
The OnePlus 6 phone will run out of battery if not charged regularly. It uses the cUSB cable which can be purchased at any electronics store. Plug in the phone and it should charge and turn on within 10 minutes.
Charger is Faulty
The issue may actually be with the charger and not the phone. Use the charging cord to another device and see if it works. You can also test out multiple USB c cables with the OnePlus 6.
Motherboard is Toast
If the OnePlus 6 does not turn on after following the previous recommendations, it is likely that the motherboard is toast and needs to be replaced.
You can find a replacement motherboard here.
You can find the motherboard replacement guide here.
コメント 1 件
qualcom crushdump error
Thiru Pharmacy - 返信
