メインコンテンツにスキップ
OnePlus 6 Motherboard Replacement
必要な工具と部品
  1. OnePlus 6 Motherboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Motherboard Replacement: 手順 2、 2の画像 1 OnePlus 6 Motherboard Replacement: 手順 2、 2の画像 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Motherboard Replacement: 手順 3、 2の画像 1 OnePlus 6 Motherboard Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Motherboard Replacement, Battery: 手順 4、 2の画像 1 OnePlus 6 Motherboard Replacement, Battery: 手順 4、 2の画像 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
  5. OnePlus 6 Motherboard Replacement, Midframe: 手順 5、 2の画像 1 OnePlus 6 Motherboard Replacement, Midframe: 手順 5、 2の画像 2
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the screw at the bottom left is marked wrong in this picture. The actual 10th screw is actually underneath the round white sticker. Do not remove the screw marked at bottom left, but strip over the white sticker which has a screw underneath it. Otherwise you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
  6. OnePlus 6 Motherboard Replacement, Motherboard: 手順 6、 1の画像 1
    • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
  7. OnePlus 6 Motherboard Replacement: 手順 7、 2の画像 1 OnePlus 6 Motherboard Replacement: 手順 7、 2の画像 2
    • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
    • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
    • The cameras should lift up with the motherboard.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
John Steven Trammell
メンバー登録日: 09/28/21
804 ポイント
4のガイドは作成済み
チーム
Clemson, Team 4-3, Hunter Fall 2021 Clemson, Team 4-3, Hunter Fall 2021人のメンバー
CLEM-HUNTER-F21S4G3
5 メンバー
14のガイドは作成済み
コメント 1 件
Can you repair my One plus 6. It's one IC of motherboard is damaged.
AMIT PANWAR - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 39
過去 30 日: 112
今までの合計 3,355
