メインコンテンツにスキップ
必要な工具と部品
ビデオの概要
この分解は修理ガイドでは ありません。 お持ちのSamsung Galaxy S5を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Samsung Galaxy S5 Teardown, Samsung Galaxy S5 Teardown: 手順 1、 1の画像 1
    • It's good to have a galaxy to play with, 'cause we're gonna need a lotta space for all this hardware:
    • 5.1” Super AMOLED display (1920 x 1080, 432 ppi)
    • 16 MP rear-facing camera with 4K video at 30 fps; 2 MP front-facing camera with 1080p video and wide-angle lens
    • Sensors for fingerprint, heart rate, gestures
    • 2.5 GHz quad-core Snapdragon 801 processor, 2 GB LPDDR3 RAM
    • 16/32 GB internal memory, plus microSD up to 128 GB
    • LTE, NFC, Bluetooth 4.0 BLE, Micro-USB 3.0, 802.11/ac MIMO Wi-Fi
  2. Samsung Galaxy S5 Teardown: 手順 2、 3の画像 1 Samsung Galaxy S5 Teardown: 手順 2、 3の画像 2 Samsung Galaxy S5 Teardown: 手順 2、 3の画像 3
    • Our initial sensor sweep reveals no life signs—just lots of life-sensing equipment.
    • From fingerprint scans to interpretive gestures, this phone shows signs of high-level interaction with an advanced civilization. Also, dimples.
    • Visible beneath the 16 megapixel rear camera: a heart rate monitor. Useful when you need to monitor your heart rate from your smartphone. So basically all the time.
  3. Samsung Galaxy S5 Teardown: 手順 3、 3の画像 1 Samsung Galaxy S5 Teardown: 手順 3、 3の画像 2 Samsung Galaxy S5 Teardown: 手順 3、 3の画像 3
    • Port ho! This silver bay is a Micro-B USB 3.0.
    • And it's open. Down to the battery at least. Tears of joy fall silently around the teardown table.
    • Peeling the back off this phone is easier than peeling a banana; the only tool required is an opposable thumb.
    • Despite negative reviews of the case design, the ease of removal is a big plus for us.
    • What's that, no battery?
    • Samsung seems to be promoting the DIY lifestyle. Not only is this battery replaceable, it needs to be user installed. That deserves an internet high-five.
  4. Samsung Galaxy S5 Teardown: 手順 4、 1の画像 1
    • No need to hitchhike to the edge of this galaxy to find the back case; it's free and clear.
    • We're guessing that this strange shape in the case is not a remnant of space creatures, but a rubber gasket. Samsung chose the minimalist's approach to water and dust resistance over more problematic methods.
  5. Samsung Galaxy S5 Teardown: 手順 5、 3の画像 1 Samsung Galaxy S5 Teardown: 手順 5、 3の画像 2 Samsung Galaxy S5 Teardown: 手順 5、 3の画像 3
    • We briefly glance at the warnings as we pull the battery out of its fancy packaging.
    • Questionable batteries will apparently explode when installed.
    • This is a 3.85 V, 10.78 Wh battery. Samsung touted a better battery-saving mode, but failed to specify the life of this guy in its advertising—listing the battery spec as 2800 mAh.
    • This is a slight upgrade from the S4's 3.8 V and 2600 mAh (9.88 Wh) battery. Advertised at 7 hours of talk time, and up to 12.5 days of standby.
    • We install the new battery. Then, we take it back out. This teardown has places to be and they're under that battery pack.
    • For those keeping track at home, that took a grand total of 10 seconds. Beat that, HTC.
  6. Samsung Galaxy S5 Teardown: 手順 6、 3の画像 1 Samsung Galaxy S5 Teardown: 手順 6、 3の画像 2 Samsung Galaxy S5 Teardown: 手順 6、 3の画像 3
    • Samsung has stacked the deck in our favor—the deck of microSD + SIM cards, that is.
    • "Galaxy S5" may be catchier, but for those who prefer a more formal designation, SM-G900A is the model number you seek.
    • What's behind door number R1?
    • So far as we can tell now, just random connectors, and certainly not the screws we were hoping for. Stay tuned, because we've got a feeling this will be important...
  7. Samsung Galaxy S5 Teardown: 手順 7、 2の画像 1 Samsung Galaxy S5 Teardown: 手順 7、 2の画像 2
    この手順で使用する道具:
    iOpener
    $19.99
    購入する
    • Suddenly, things are looking grim. The S5's forefather, the S4, took to the teardown table like a protocol droid to an oil bath.
    • This time though, it seems the entire display assembly stands in the way of any further tinkering.
    • With no other recourse, we call in our fixer muscle, iOpener and Opening Pick—perhaps better known by their street names, Heat and Force.
    • This is looking dire. What happened, Samsung? I thought we were friends.
    • Have you been hanging out with the Kindle Fire HDX?
  8. Samsung Galaxy S5 Teardown: 手順 8、 3の画像 1 Samsung Galaxy S5 Teardown: 手順 8、 3の画像 2 Samsung Galaxy S5 Teardown: 手順 8、 3の画像 3
    • Time for the final pry op—
    • ...aw, nuts. CABLE.
    • Cable booby traps are like finding a pit of snakes between you and the treasure you are after. To make matters worse, Harrison Ford is nowhere to be found.
    • After spudging past the cable, we begin to free the display assembly. Unfortunately, Samsung seems to think that the only way to get into this phone should be glass-first.
  9. Samsung Galaxy S5 Teardown: 手順 9、 3の画像 1 Samsung Galaxy S5 Teardown: 手順 9、 3の画像 2 Samsung Galaxy S5 Teardown: 手順 9、 3の画像 3
    • With the display thusly removed, we just have to convince it to part with its home button. We let our plastic opening tool do the talking.
    • Say goodbye to the sticky adhesive tape holding the screen down. Reinstalling your display will most likely require a fresh set of adhesive.
    • This little display assembly cable has a lot of bits to ferry. It's helped out by a Synaptics S5100A touchscreen controller.
    • This is a fairly radical change in design for the S-series. We're used to seeing internal components riding on the back of a large display assembly. The S5 turns this on its head and sandwiches the components between the display and the battery, in their own difficult-to-access compartment.
  10. Samsung Galaxy S5 Teardown: 手順 10、 3の画像 1 Samsung Galaxy S5 Teardown: 手順 10、 3の画像 2 Samsung Galaxy S5 Teardown: 手順 10、 3の画像 3
    • Oh Samsung, we were hoping we might be going about this all wrong. But alas, here are the screws we needed—on the other side of the phone. Sigh.
    • We've reached a point of debate on Galaxy nomenclature. The consensus says we're removing the midframe from the um, midframe.
    • Confused? Yeah. We were, too.
    • Here's the deal: after peeling off the rear case, you encounter a midframe. And between that (first) midframe and the display assembly, there's this second midframe. So there you have it: double the midframe.
  11. Samsung Galaxy S5 Teardown: 手順 11、 2の画像 1 Samsung Galaxy S5 Teardown: 手順 11、 2の画像 2
    • So, to recap:
    • On the left we've got the interior midframe, with the motherboard and daughterboard
    • On the right we've got the exterior midframe, with a plethora of spring-contacted components
    • We're already on a first-name basis with the other bits in here: headphone jack, speaker, buttons, etc.
    • Identity crisis averted. Repairability crisis, TBD...
    • Also now visible, just beneath the massive rear-facing camera, Samsung's all-new heart rate monitor, powered by the Samsung SM-G900S biosensor.
  12. Samsung Galaxy S5 Teardown: 手順 12、 3の画像 1 Samsung Galaxy S5 Teardown: 手順 12、 3の画像 2 Samsung Galaxy S5 Teardown: 手順 12、 3の画像 3
    • Remember door number one's mystery connector? Surprise—it was the home button cable!
    • This discovery is a bonus to the S5's repairability (and a classic lesson in the need for repair manuals)—disconnecting the home button cable from the start would have made the display removal much easier, and will certainly aid in reassembly.
    • Present and accounted for is the expected fingerprint scanner tech. The control chip is labeled 1200P E43F2.
    • Some say getting this print sensor to actually work requires a bit of persistence.
  13. Samsung Galaxy S5 Teardown: 手順 13、 2の画像 1 Samsung Galaxy S5 Teardown: 手順 13、 2の画像 2
    • Near the center of the Galaxy we find a black hole the motherboard. With the hard work done, we pop it out and start scouring for evidence of intelligence.
    • Our first sign comes via the camera.
    • Anxious for a staring contest, we use our trusty plastic opening tool to pry it out for a better look.
  14. Samsung Galaxy S5 Teardown: 手順 14、 2の画像 1 Samsung Galaxy S5 Teardown: 手順 14、 2の画像 2
    • On the left, we have Samsung's 16MP 1/2.6” rear-facing camera.
    • Touting new, faster auto-focus, this camera should enable users to finally catch a real UFO with photographic evidence.
    • Safe and sound in the main cam's backpack is a control chip: QDA41 L1010 R412.
    • Standing next to the main camera is the Hobbit selfie stunt-double, a 2.0 MP front-facing camera.
    • This little wide-eyed wide-angle lens shoots with a resolution of 1920 x 1080.
  15. Samsung Galaxy S5 Teardown: 手順 15、 1の画像 1
    • Some galaxies have stars. Others have chips:
    • Elpida FA164A2PM - The same 2 GB RAM package we found in the HTC One (M8), and different from the 2 GB Samsung chip found in Chipworks' analysis. Quad-core 2.5 GHz CPU likely layered beneath
    • Samsung KLMAG2GEAC-B0 16 GB on-board memory
    • Avago ACPM-7617 multi-mode, multi-band RF front end
    • Murata KM4220004 (likely Wi-Fi module)
    • 1412 (C1N75R UMR3) (C1N78B YMP4)
    • Maxim Integrated MAX77804K (System PSoC) and MAX77826
    • STMicroelectronics 32A M410
  16. Samsung Galaxy S5 Teardown: 手順 16、 1の画像 1
    • SWEP GRG28 antenna switch module (thanks Chipworks)
    • Qualcomm WTR1625L RF transceiver (another encore from the HTC One M8) and...
    • Qualcomm WFR1620 receive-only companion chip
    • Qualcomm PMC8974 power management IC
    • Lattice iCE40 LP1K low-power FPGA
    • Invensense MP65M (MPU-6500M) gyroscope/accelerometer
    • Qualcomm WCD9320 audio codec
    • SIMG 8240B0 mobile HD-link transmitter and NXP 47803 NFC controller
  17. Samsung Galaxy S5 Teardown: 手順 17、 2の画像 1 Samsung Galaxy S5 Teardown: 手順 17、 2の画像 2
    • With the motherboard out of the way, we find ourselves short of parts. All we have left is a lonely little daughter board.
    • Home to the charging port, a closer examination of this daughter board reveals cables for the bottom buttons, as well as a smattering of ICs:
    • Cypress CY8C20075-24LKXI CapSense capacitive touch-sensing controller
    • RFMD RF1119 antenna controller
    • S1221 primary microphone
  18. Samsung Galaxy S5 Teardown: 手順 18、 2の画像 1 Samsung Galaxy S5 Teardown: 手順 18、 2の画像 2
    • Samsung Galaxy S5 Repairability Score: 5 out of 10 (10 is easiest to repair).
    • The battery is incredibly easy to remove and replace.
    • The display is now one of the first components out, making replacements a little faster. However, it is held in with a significant amount of adhesive and requires very careful and persistent prying and a considerable amount of heat to remove without cracking the glass or cutting cables.
    • Once you get the device open, several components are modular and fairly easy to replace, such as the cameras, headphone jack, vibrator motor, and speakers.
    • Replacing anything other than the battery requires first removing the display, risking extra damage on the way to a repair.
27 件のコメント
what is the 802.11ac chip?
curious - 返信
it's the wi-fi chip. 802.11 is a norm at IEEE ;)
Thomas -
was the lcd glued to the frame? i mean that reddish foil, did it come
off easily without heating it up? thanks
elvirs - 返信
LCD and touchscreen is fused together. Which reddish foil are you referring to?
adnan amru -
I think he means the copper-coloured backside of the display assembly. And I have the same question, was the backside of the display assembly glued to the midframe, or was it just the sides that were glued to the frame?
Audun -
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 78
過去 30 日: 285
今までの合計 512,333
