Glass Only
4件の回答 1 スコア |
Can I fix a popping out screen with superglue |
43件の回答 87 スコア |
Flickering screen on low back light |
22件の回答 436 スコア |
Can't sign in to Samsung account after factory reset |
3件の回答 22 スコア |
pop up saying NFC tag type not supported |
ドキュメント
モデル
AT&T (G900A), Boost Mobile (G900B), Europe (G900F), Sprint (G900P), T-Mobile (G900T), Verizon (G900V)
トラブルシューティング
デバイスに問題がある場合は、 Samsung Galaxy S5 troubleshooting pageをご覧ください。
製品情報と背景
The Samsung Galaxy S5 is the fifth generation of the Galaxy S phone series. It was released April 11th, 2014 to replace the popular Galaxy S4. This iteration of the phone series features a larger screen than the S4, a textured back, and a charging port cover. This update also equips the phone with USB 3.0 compatibility, water proofing, heartbeat sensor, and a larger screen.
Samsung made it easy to identify this phone from its predecessors by placing text on the rear cover that says "Galaxy S5." Unlike previous models the rear cover is not smooth plastic, it has bumps that resemble a band-aid's texture. Despite the home button having a fingerprint sensor, it does not look different compared to the Galaxy S4.
技術仕様
- 5.1インチ スーパー AMOLED ディスプレイ (1920 x 1080, 432 ppi)
- Android 4.4.2 (Kitkat)
- 16 メガピクセルMegapixel rear-facing camera capable of recording 4k video at 30 fps
- 2.0 メガピクセル正面カメラ front-facing camera with 1080p video recording and wide-angle lens
- LTE Cat.4 (150/50 Mbps)
- WiFi : 802.11 a/b/g/n/ac VHT80, MIMO(2x2)
- LTE + WiFi simultaneous reception
- NFC, Bluetooth®: 4.0 BLE / ANT+
- Micro-USB 3.0
- IrLED
- Sensors: Accelerometer, Gyro, Proximity, Compass, Barometer, Hall, RGB ambient light, Gesture, Fingerprint, Heart Rate Sensor
- 2.5 GHz quad-core Snapdragon 801
- 2 GB LPDDR3 RAM
- 16/32 GB user memory + microSD up to 128 GB
- 2800 mAh リチウムイオンバッテリー
- サイズ: 142.0 x 72.5 x 8.1mm
- 重量: 145g
- IP67 certificated Dust & Water Resistant
追加情報
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
