メインコンテンツにスキップ
Pocophone F1 Back Cover Removal
必要な工具と部品
  1. Pocophone F1 Back Cover Removal, Remove the SIM tray: 手順 1、 3の画像 1 Pocophone F1 Back Cover Removal, Remove the SIM tray: 手順 1、 3の画像 2 Pocophone F1 Back Cover Removal, Remove the SIM tray: 手順 1、 3の画像 3
    • Before you begin, switch off your phone.
    • Insert a SIM eject tool or a paperclip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  2. Pocophone F1 Back Cover Removal, Unfasten the back cover screws: 手順 2、 1の画像 1
    • Remove the two 2.7 mm-long Torx T3 screws from the bottom edge of your phone.
  3. Pocophone F1 Back Cover Removal, Insert an opening tool: 手順 3、 3の画像 1 Pocophone F1 Back Cover Removal, Insert an opening tool: 手順 3、 3の画像 2 Pocophone F1 Back Cover Removal, Insert an opening tool: 手順 3、 3の画像 3
    • Insert an opening tool between the screen and the back cover at the bottom edge of the screen.
    • Slide the opening tool to the bottom right corner to release the plastic clips holding the back cover in place.
  4. Pocophone F1 Back Cover Removal, Release the clips: 手順 4、 3の画像 1 Pocophone F1 Back Cover Removal, Release the clips: 手順 4、 3の画像 2 Pocophone F1 Back Cover Removal, Release the clips: 手順 4、 3の画像 3
    • Slide the opening tool around the bottom right corner.
    • Slide the opening tool along the right edge of the Pocophone F1 to release the plastic clips.
  5. Pocophone F1 Back Cover Removal: 手順 5、 2の画像 1 Pocophone F1 Back Cover Removal: 手順 5、 2の画像 2
    • Slide the opening tool along the top edge of the phone to release the plastic clips holding the back cover in place.
  6. Pocophone F1 Back Cover Removal: 手順 6、 3の画像 1 Pocophone F1 Back Cover Removal: 手順 6、 3の画像 2 Pocophone F1 Back Cover Removal: 手順 6、 3の画像 3
    • Slide the opening tool along the left edge of the phone to release the remaining plastic clips.
    • Try not to remove the back cover all the way yet, the flex cable of the fingerprint sensor is still connected to the motherboard.
  7. Pocophone F1 Back Cover Removal: 手順 7、 3の画像 1 Pocophone F1 Back Cover Removal: 手順 7、 3の画像 2 Pocophone F1 Back Cover Removal: 手順 7、 3の画像 3
    • Carefully fold the phone assembly to the left side of the back cover like you'd open a book page.
    • Avoid tensioning the fingerprint flex cable during this procedure.
  8. Pocophone F1 Back Cover Removal, Unfasten screws: 手順 8、 1の画像 1
    • Remove the ten 3.2 mm-long Phillips screws.
  9. Pocophone F1 Back Cover Removal: 手順 9、 3の画像 1 Pocophone F1 Back Cover Removal: 手順 9、 3の画像 2 Pocophone F1 Back Cover Removal: 手順 9、 3の画像 3
    • Slide an opening pick under the bottom left corner of the motherboard cover.
    • Slide the opening pick around the corner and along the left edge of the motherboard cover to release the plastic clips holding it in place.
    • Use the opening pick to pry up the motherboard cover.
  10. Pocophone F1 Back Cover Removal, Remove the motherboard cover: 手順 10、 2の画像 1 Pocophone F1 Back Cover Removal, Remove the motherboard cover: 手順 10、 2の画像 2
    • Remove the motherboard cover.
  11. Pocophone F1 Back Cover Removal, Remove the back cover: 手順 11、 3の画像 1 Pocophone F1 Back Cover Removal, Remove the back cover: 手順 11、 3の画像 2 Pocophone F1 Back Cover Removal, Remove the back cover: 手順 11、 3の画像 3
    • Use the flat end of a spudger to pry up and disconnect the fingerprint flex connector.
    • Remove the back cover.
終わりに
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
204,869 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,410のガイドは作成済み
コメント 1 件
Thank for the help
Ellusion - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 44
過去 30 日: 184
今までの合計 9,353
