メインコンテンツにスキップ
PlayStation 5 Slim Fan Replacement
必要な工具と部品
  1. PlayStation 5 Slim Fan Replacement, Prepare your PlayStation for disassembly: 手順 1、 3の画像 1 PlayStation 5 Slim Fan Replacement, Prepare your PlayStation for disassembly: 手順 1、 3の画像 2 PlayStation 5 Slim Fan Replacement, Prepare your PlayStation for disassembly: 手順 1、 3の画像 3
    • Before starting your repair:
    • Shut down your console.
    • Unplug all cables and accessories.
    • Remove any stands supporting your device.
  2. PlayStation 5 Slim Fan Replacement, Lay your PlayStation down: 手順 2、 1の画像 1
    • Lay your PlayStation on its side so the right side covers are facing up.
  3. PlayStation 5 Slim Fan Replacement, Remove the fan and SSD cover: 手順 3、 3の画像 1 PlayStation 5 Slim Fan Replacement, Remove the fan and SSD cover: 手順 3、 3の画像 2 PlayStation 5 Slim Fan Replacement, Remove the fan and SSD cover: 手順 3、 3の画像 3
    • The upper cover is secured with hooks along the back edge and clips along the front edge.
    • Firmly pull up the front edge of the cover to release the clips.
    • You'll hear distinct "pops" as the clips disengage.
    • Remove the cover.
    • To reinstall the cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the two clips.
  4. PlayStation 5 Slim Fan Replacement, Remove the fan cables cover: 手順 4、 3の画像 1 PlayStation 5 Slim Fan Replacement, Remove the fan cables cover: 手順 4、 3の画像 2 PlayStation 5 Slim Fan Replacement, Remove the fan cables cover: 手順 4、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    購入する
    • A piece of plastic covers the fan cables connector.
    • Use your fingers to remove the plastic cover.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  5. PlayStation 5 Slim Fan Replacement, Free the fan cables: 手順 5、 2の画像 1 PlayStation 5 Slim Fan Replacement, Free the fan cables: 手順 5、 2の画像 2
    • Gently pull the fan cables out from under their plastic clip on the frame.
  6. PlayStation 5 Slim Fan Replacement, Disconnect the fan: 手順 6、 3の画像 1 PlayStation 5 Slim Fan Replacement, Disconnect the fan: 手順 6、 3の画像 2 PlayStation 5 Slim Fan Replacement, Disconnect the fan: 手順 6、 3の画像 3
    • Firmly grip the fan cables white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  7. PlayStation 5 Slim Fan Replacement, Remove the fan screws: 手順 7、 2の画像 1 PlayStation 5 Slim Fan Replacement, Remove the fan screws: 手順 7、 2の画像 2
    この手順で使用する道具:
    FixMat
    $36.95
    購入する
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 11.6 mm‑long screw
    • One 31.2 mm‑long screw
    • Two 21.3 mm‑long screws
  8. PlayStation 5 Slim Fan Replacement, Remove the fan: 手順 8、 2の画像 1 PlayStation 5 Slim Fan Replacement, Remove the fan: 手順 8、 2の画像 2
    • Use your fingers to grab the fan by its vents, and lift it straight up to remove it.
    • Lift the fan straight up and remove it.
    • If you're using this guide to clean your fan, use compressed air and a clean cloth to remove any dust or dirt.
    • During reassembly, insert the fan so its cables are near their connector.
終わりに
作成者
2人の作成者と共同で作成されました。
Spencer Day
メンバー登録日: 09/14/22
55,149 ポイント
408のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,410のガイドは作成済み
コメント 1 件
Cooling Fan Replacement For Sony PS5 Slim 19 Blades check kasynparts
gameparts - 返信
コメントを追加
統計データ:
過去 24時間: 19
過去 7 日: 127
過去 30 日: 608
今までの合計 2,479
