Gas line pops off of carburetor when pressing primer bubble
Gas line pops off of carburetor when pressing primer bubble. What causes this?
@chrischand74500 the primer bulb should push only air back into the fuel tank when depressed. As it now re-inflates it sucks fuel from the tank into the carburetor. If it pushes your fuel line off, then it is pushing quite a bit of air. Could just be a fuel line that is to loose. Make sure that your carburetor bowl is fuel and the float and needle valve are okay.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 8
