Red line on screen
It shows red lines and red dots on screen
@suhask without seeing it and only going by your description, this sounds like a bad display. Of course you always want to check the flex cable as well as the connector. Check for corrosion, tears and bend/broken pins. Use this guide to work on it Pocophone F1 IPS LCD Screen & Digitizer Replacement
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 10
