メインコンテンツにスキップ
2019年3月に発売されたSamsungの10世代になるGalaxyの新モデルです。OSはAndroid 9.0 (Pie)。
71回答 すべてを表示
My phone has a black screen but not when charging
I dropped my phone 18 months ago and its been fine until a small fall yesterday. I picked it up and the screen was black and 2/3 where flickering white. I put my phone on the power pad and my screen started to work. It was flickering at first but I turned my brightness up it stopped. Even when I take my phone off the pad it still works but if I lock it it black screens again and wont work until I charge it.
I know ive damaged my LCD screen as it now has a white line where the crack is.
I have just over 3 months left before I can upgrage my phone. Im wondering if I do a soft or hard reset if it will stop my phone black screening and get me through the next 3 months as I use my phone alot for work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
If there is physical damage to the device, no amount of software changes can fix that. I’d recommend taking it to a repair shop if you need it for work and are unable to upgrade for a few months. Besides getting a full display replacement, you can’t do much to fix a problem like that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
@nonnahs probably not. Samsung screens are very finicky and you will see that the damage will get worse. I suggest you replace the display assembly and continue to use your phone until you update. After that you can sell your phone and recover the cost for the repair. Working phones sell a lot easier than the ones that need fixing. Samsung Galaxy S10 スクリーンの交換
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shannon さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 84
今までの合計 1,251
