メインコンテンツにスキップ
Wi-Fi付きの初代Apple iPadは16,32,64GBから選べます。モデル番号はA1219。修理は複雑な作業はなく、ヒートガンなどは不要です。
130回答 すべてを表示
Is it possible to build an Ipad out of parts from online?
Hey Guys,
I was wondering if it's possible to build an ipad out of parts ordered from online?
LIke i found a few sites where you can get the LCD and the case, but i'm wondering if it's possible to order other parts like the logic board and the speakers. etc.
Would it be possible?
- Ez
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
6件の回答
ベストアンサー
Parted out an iPad will probably cost double what a brand new one does.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
That is unless you buy used parts. Also you'll have to pay shipping on every single part, not just one unit.
さんによる
Buy one with a broken screen, then buy one with water damage.... Profit?
さんによる
mayer is right!
The PCBs and the chips are expensive in small volume!
さんによる
コメントを追加
it is possible but it cost a lot that it might not worth it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
and the best bit is, apple would not repair it, if something goes wrong...
i was going to buy one with cracked screen. i first was told by apple care "just bring it in, and we will fix it for you". then i have dug a bit deeper and have asked another apple care professional, if it really is replaceable in apple stores, he said to me, i would be turned away... i am not going to do anymore business with apple anymore. this iPhone is also the last one...
the way they make things is simply not good enough for me. if glass can be shattered so easily, why the $&@$ no one makes it out of plastic? i know, i am barking at the wrong tree...
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
If you don't like Apple engineering just wait till you open an Acer ;-)
さんによる
Open an ipad it not built all that good just like all other stuff coming from asia
さんによる
Open an acer???, open an HP!!!!! The HP had like 3 tons of duct tape in it.
Apple engineering is actually pretty elegant compared to most other stuff out there.
さんによる
コメントを追加
I bought %70 of the parts needed to build one myself. But the eprom chips have the preloaded software from Apple. And not to mention the flash hard drive. What I did do was order from A web site called Dealextream about %50 of the unit. We in Toronto Ontario Canada have a mall called Pacific mall. In it has about 200 small china like stores with the rest of the imports for the Ipad. You are almost assured that most stores only carry Ipad 1 parts in stock. Cost to date is about $300
Good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
There are many iPads available on eBay that are bricked by what is called an "iCloud" lock and others which are cheap because they have shattered glass, etc. So Apple is checking serial numbers before it lets your machine work, or download apps, making building from scratch a non-starter. But swapping id from a physically broken machine into a locked chassis might be a doable project to get a cheap iPad.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How about taking the parts of a broken iPad screen with screen and attaching it to a larger touch screen for something like a diy touch table.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Esmond Ruslim さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 38
今までの合計 22,675
