メインコンテンツにスキップ
Sonyのベストスマートフォン、Xperia Z Ultraは2013年に発売された”ファブレット”スタイルのデバイスです。
20回答 すべてを表示
Sleep of Death -Power button Display Issues
Support,
I bought a Sony Xperia Z Ultra phone on 9th August through Flipkart (online stores) In India, and upgraded to build number- 14.1.B.1.510 on 30th August. After this upgrade the phone display started going on and off every 10 seconds. Then I power it off, since then I could not restart the phone. The phone is dead!
I have pressed the power botton many times, but it was not fruitful.
The battery was 100%, still I put it on charging, but it is not showing any charge light. I tried to connect to my computer, that too doesnt work.
Is there any way I can power this phone ON again?
I m in Lagos, Nigeria. I have contacted Sony centre, but they confirmed there is no Xperia service centre here.
please help!
Jay
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 30
14 件のコメント
My Xperia Z Ultra is dead too... 4 days after I bought it. Grr
さんによる
Did you try to reset it with the red button on micro SIM card slot?
さんによる
Yes, I tried the Hard reset button (inside SIM card tray). but that doesn't work!! even sony service centre stopped answering me!
さんによる
Hi,
It is the battery.
さんによる
A friend told me to recharge the phablet plugged into on my computer. That fixed the problem for me.
さんによる
9件以上のコメントを表示
コメントを追加
25件の回答
最も参考になった回答
This is like playing the piano.
We connect the charger (USB)
pressed the button on / off simultaneously with VOL +, the mobile phone after 8 sec. will vibrate once and spent another 5 sec. vibrating three times.
Quickly we dropped just the on / off button and turned off the usb cable, the red LED turns off and the device restarts.
Once the Sony logo appears we dropped the VOL + button and turn off the phone by pressing the on / off button.
Now is the unit off completely.
Now just connect ... and good luck
このアンサーは役に立ちましたか?
スコア 25
24 件のコメント:
thank you... really helpful!
さんによる
Yes !!!! It worked.. I was going crazy with the brand new phone..Thanks a lot gugatb.. exactly this method worked. But, one question, why did this happen ?????
さんによる
Doesn't work
さんによる
sorry please need quick response it does not work.
さんによる
hi, realy its work,thanks
さんによる
19件以上のコメントを表示
コメントを追加
Hi,
It is the battery.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
No, it's not.
さんによる
コメントを追加
I experienced similar issue. all I do is just pressing the tiny red button near sim tray and all is done. I use my point butterfly knife (balisong) btw, and I press it for like 8 seconds and voila.
I think you should try to press and hold it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
yes. done. tqvm
さんによる
コメントを追加
Hi there, i had the same, phone did not turn on and power led was blinking every 3 secs when i connect charger and didnt turn on :( checked the following:
-pushed mini "hard reset button" beneath the sim card cover didnt work
-pushed vol down and connected usb cable didnt work (should start with android system menu)
Pls do below on your own risk.
-took a heat gun (a hair dryer will work also but more time is consumed). Heat back cover till your palm feels quite hot (but not so hot to prevent touching, dont go that hot). Took a very thin "-" screw driver or guitar pick and opened back cover. Found battery connection and removed connection (not the battery) and waited 10 secs. Replugged battery and connected charger. Phone turned on :) :) :) :) :) pls watch "how to replace sony xperia z ultra battery" video on youtube. It is really easy than expected.
Thanx
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I used a small screwdriver to remove the back, removed the water inside and disconnected and reconnected the battery connector and now its charging and fully fixed. THANK YOU SOOOOO MUCH, I was so worried I would have to buy a new one but it now works perfectly!
さんによる
コメントを追加
It look like Sony make bad product . I read every where that Power button, head phone jack ,and charge no work . Sony never fix this big problem at all. Believe me. I sent to them 1 time, then it work for 3 days, then dead again. That day out of warranty. My 400 buck is trash
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
xperia c6602dead...... treid evrything ...... - + keys .. flashtool.... pc companian.... still same problem restart every 4 ,5 second and red light on front
さんによる
Suises broken
さんによる
コメントを追加
My friend and I had the same issue as well. I just pressed the rest button near the SIM card slot and the phone vibrated thrice. After that, I pressed the power button and it worked.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I did everything it doesn't work
さんによる
コメントを追加
I have Sony T2 ultra and power button made same problem as it is mentioned abow. I tried many things. 1. reset 2. factory setting 3.Reinstalling with sony pc companion 4. buttonning near simcard tray.
None of them worked and finally I opened lid and i got a neddle then poked the mecanism of power button by means of needle then i turned to normal. Now it is working properly.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
THANK YOU THANK YOU THANK YOU THANK YOU SOOOOOOOOOO MUCHHHH!!!! It worked for my t2 ultra too!!!!!! Was poking randomly at the mechanism and all of a sudden, issue resolved..
さんによる
コメントを追加
i had same problem on my zl, i know the phone is fine cause when i hook it up to hml i can see the sreen on my tv, the back light powers up but no picture. rest does nothing, nothing is working to get my picture back.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Did you fix this by any chance?
さんによる
コメントを追加
Just had a similar problem although the light on the right top was blinking like my z ultra was working hard on something reset button didn't work but power and vol+ did. now it looks fine.... worth trying
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi guys,,,if you have problem with ur xperia z (C6603) like power on not working but red light is still working....just me message me up or add me in facebook heres my email arnelcabal43@yahoo.com
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
I have a same problem. Can you help me to repair? It doesn't charge and switch, but the red lights is still working... How can I fix it? Please
さんによる
Same problem here the red light is working but it cannot boot. I tried power+ volume+ and the reset button it doesnt even work :( help us guys.
さんによる
I have the same problem, can you help plz
さんによる
I also do have the same problem. Were you guys able to find a solution?
さんによる
コメントを追加
Hi.I have sony xperia ultra Z and from yesterday it is not getting charge.
How I can fix
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have the same prob. here !
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a Sony Experia Ultra Z, tried updating the operating system from Kit Kat to Lollipop with Sony PC Companion. Now the phone/pablet will not boot up I have tried resetting through holding red button beside Sim, (which does not work)so pushed and held vol up and power button this vibrated three times but phone will still not boot up. 'Sony Experia' glides across the screen as before but that is it.
Please help
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
good day,
i didnt do below particularly on sony devices but on samsung which i hope helps. (i had killed my samsung because of PC app "samsung kies" while trying to update OS)
-google for sony ROM burning program.
-download ROM from sony forum websites
-install the program and select downloaded ROM on it. It will say "OK" (otherwise you must download another ROM) ROM is abt 600mb
-hold vol up hen connect USB cable.
-program will detect the phone and go ahead burning new rom
it will take about 15 minutes and DONT PLUG USB OUT and dont touch yourphone untill it turn on an home screen comes.
even samsung service they said "your phoneis dead" but i saved my device this way :) :) haha :)
i have no links to thoseprograms and roms :(
さんによる
コメントを追加
pls advise, if you want to sell your dead phone,
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Anybody wants to sell his/her dead z ultra, pls let me know.
さんによる
I would be interested in selling my ultra z. The phone occasionally boots but is stuck with a red blinking light
さんによる
コメントを追加
Hi i have the same problem i tuck my phone to replace the motherboard becose it was don no power notin i replace the motherboard and now is warking
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i connect to charger and 1% charging then automatic not charging whats a problem plz help me
my contact no 08461033222
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Your battery is damaged or charger
さんによる
コメントを追加
Guys i have purchased a new battery through internet and replaced it by myself and my problem is solved. pls youtube it for replacing the battery it is really simple!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
xperia c6603 dead...... treid evrything ...... - + keys .. flashtool.... pc companian.... stilll same problem restart evry 4 5 second nd red light on front
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I pressed the red button near the sim and it turns my phone off now I can't turn it back on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Guys I have this problem too I dropped my phone and when I plug it in the red light is on but the Sony logo keeps turn on and off non stop can someone please help me? I will greatly appreciate your help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Suises broken
How to repair suise
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How to repair
さんによる
コメントを追加
change display ,,to solve your problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Power button is not warking
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I purchase Sony experia M5 mobile at saudia arab. speaker problem first day no out going sound. i check mobile market saddar karachi. mobile wale ne repair k bjae mobile dead kar dia. sirf charging light show ho rahi he. please solve my problems.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Take out your sim card let it be boot automatically, then insert the sim card then press power bottom till it vibrate.
For more details you can call me +91862202762
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jayakanth さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 36
今までの合計 130,881
