学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Laptop Will Not Boot
Laptop does not turn on
Uncharged Battery
If the laptop does not boot while it is not connected to a power supply, then the laptop battery might be uncharged. In order to charge the laptop battery, plug the laptop to its power adapter, then check if the laptop switches on.
Malfunctioning Hard Drive
If the laptop does not boot correctly, the hard drive may have malfunctioned. Check the laptop’s hard drive; if it requires replacement, please refer to the Hard Drive Replacement Guide.
Malfunctioning RAM
A malfunctioning RAM also prevents the laptop from booting correctly. Check the laptop’s RAM of the laptop to see if a replacement is required. If so, please refer to the RAM Replacement Guide.
Laptop Shuts Off When Unplugged
When the laptop is unplugged the device will not turn on.
Battery is Dead
If the battery is dead, the computer will not hold the charge, or work without the power cord. The laptop will still operate if it is connected to the power cord. To remove or replace the battery, refer to the Battery Replacement Guide.
Laptop Will Not Charge When Plugged In
When the charger is plugged into the laptop, it does not charge.
Laptop Charger is Broken
Replace laptop charger.
Malfunctioning Display Screen
When the laptop is turned on, the LCD Display Screen is black, cracked, or has colored lines running through it.
Screen Locked
Press FN and F7 together to toggle the display on and off.
Broken LCD Screen
If the LCD screen is broken, it will require replacement. Please refer to the Screen Replacement Guide.
Speakers Do Not Emit Audio
Audio does not play when using programs that are supposed to play audio.
Laptop is Muted
Locate mute button, on the front side of the laptop, next to the wireless switch and toggle the switch until audio is heard.
Open volume mixer in Windows and make sure volume is not muted.
Volume is Too Low
Locate volume switch, on front side of laptop, next to the mute button. Push the volume toggle switch up until sound is audible.
Open volume mixer in Windows and make sure volume slider is not low.
Malfunctioning Speakers
Refer to the Hardware Replacement Guide for replacing speakers.
No Wireless Internet Connection
My computer cannot find any wireless Internet connections.
The Wireless Network Hardware Switch is Off
Check if the wireless network hardware switch is off. When this switch is off, your computer will not have any wireless Internet access. Push the switch to the “on” position (to the right) to allow your computer to have wireless Internet access.
The Wireless Network Antenna is Disconnected
Confirm the wireless network antenna is fully plugged in. If the antenna is not fully plugged in, then your computer will be unable to have a wireless Internet connection. The antenna is located on the computer’s top right panel. Firmly press the antennas circular base into the computer to plug the antenna in.
The Network Antenna is Broken
If the wireless network hardware switch is on and the wireless network antenna is fully plugged in, and your computer is still unable to detect any Internet connections, then your antenna may be broken. Refer to the Wireless Network Antenna Replacement Guide to learn how to replace the antenna.
CD Drive Will Not Open
When trying to eject the CD tray, it will not open as if the tray was jammed.
CD Drive is Stuck
Locate the small pinhole sized hole on the CD drive and insert a small scribe, or other small pointing tool into the hole. Apply pressure until the CD drive opens. This hole is a manual force eject and could require a lot of pressure, especially if the drive is jammed.
CD Drive Needs Replacement
Refer to Hardware Replacement Guide for replacing the CD drive.
Unresponsive Keyboard
Keyboard and touchpad does not work.
Keyboard Needs Replacement
Refer to our Keyboard Replacement Guide for replacing the Keyboard.
0 件のコメント
