学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Computer Won't Turn On
Laptop does not respond and shows no sign of turning on. It will either not boot, says that there is no drive to boot from, or you are unable to access BIOS
Bad Charger
Make sure the charger is plugged in all the way. Make sure the light indicating the adapter is attached is lit. If the adapter is plugged in and the light is off, the charger is most likely faulty.
Bad Battery
If the charger is plugged in and the light is on, assure that the charger is plugged in. If the only time the computer turns on is when the charger is connected then the battery is most likely no longer holding a charge.
Hard Drive Problems
If the device cannot access the boot drive, then there may be a problem with the hard drive.
Computer Cannot Access BIOS
If the computer starts up and only stays on the splash screen, then the motherboard is most likely faulty.
Keyboard/Keys Don’t Work
The keys on your keyboard are not responding or appear to be broken or missing
Bad Keyboard
If the entire keyboard is not taking input, then the keyboard is most likely either faulty or has a bad connection.
Screen Is Blank
If you turn the laptop on and the screen is blank but all other components work, then the screen may have a faulty connection or there could be a problem with the video drivers.
Laptop Makes Noise While Running
The laptop is making a loud noise from the fan, or the laptop is making a grinding noise from the hard drive.
Noise Coming From The Fan
There may be dust, hair, or something obstructing the fan from spinning properly, which may cause the computer to overheat.
Computer Making a Grinding Noise
The hard drive may be scratched on the inside. This will cause the computer to fail to boot up or some files to be lost.
Laptop Is Turning On And Off Irregularly
While using your laptop it turns off with no notice, and no instruction
Memory Problem
If the computer continuously turns on and off with no notice, then the memory(RAM) may be loose and losing connection to the motherboard.
Faulty Motherboard
If the computer is constantly having problems starting up, and it is not a loose memory connection, then the motherboard may be faulty and/or have a short circuit somewhere on the board.
Laptop Freezing
The laptop runs properly but without notice shuts down. When it happens the bottom feels hot and the fan runs louder than usual.
Fan May be Blocked
If the fan is blocked and making loud noises, then the fan may have dust or other foreign objects stuck in it.
0 件のコメント
