学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
The Tablet Turns Off Unexpectedly
The tablet shuts down during use without being prompted to.
The Battery is Drained
Plug your tablet into a working outlet with the proper cord and allow time to charge.
The Battery is Corrupt
If your device won't hold a charge and shuts down often, the battery may need replacing. Batteries have limited lifespans and the device will often outlast the battery. Use this guide to replace the battery.
The Tablet Doesn’t Charge
The tablet doesn’t charge when plugged into a working outlet.
The Charger is Broken
If your device is not charging or charges erratically, the charging cord may be broken. Cords have limited lives and need to be replaced once broken. Try using the cord to charge a different device, and if the other device won't charge or charges erratically again, plan to replace the cord. Low quality and cheaper cords will often have shorter lifespans than ones distributed straight from the device manufacturer.
The Charging Port is Damaged
Check the charging port for water damage.
Check the cord for missing pins or frayed ends.
Hold down the power button for 3-5 seconds to ensure device doesn't turn on.
Try an alternate manufacturer approved charging cable or wireless charging pad.
Check out this charging port replacement video for a similar device.
The Screen is Damaged
The device screen is cracked, smashed, or broken.
The Glass is Broken
If the display underneath is intact and the image is distorted by broken glass, then only the glass cover is broken. However, the glass cover and LCD (liquid crystal display) function as a unit and must be replaced together. Use this guide to replace them.
The LCD is Broken
If the glass screen is intact but the image beneath is distorted, then the LCD (liquid crystal display) is broken. However, the glass cover and LCD function as a unit and must be replaced together. Use this guide to replace them.
The Glass and LCD are Broken
If there is damage to both the glass screen and the image beneath, then both the front glass and the LCD (liquid crystal display) are broken. The glass cover and LCD function as a unit and must be replaced together. Use this guide to replace them.
The Tablet Won't Recognize the SD Card
The SD card does not show up in the device, or no files appear.
The SD Card is Not Properly Seated
Remove the SD card holder with the included pin, or use a paperclip. Once the holder is removed, ensure the SD card is clean and properly seated before reinserting.
The SD Card isn't Formatted
To format the SD card click on settings. Next, go to storage. After this, click on SD card options and then format SD card.
The SD Card is Faulty
Try putting the SD card in another device such as a computer or a different tablet. Ensure the card is readable and shows up in the device. For Windows, the SD card should show up as removable storage.
If the card does not show up in another device, replace it with a new SD card.
The SD Card Reader is Faulty
If the SD card shows up in other devices but not the device in question, replace the SD card reader using this guide.
The Camera Cannot Take Photos/Videos
The error message “Warning: Camera Failed” appears upon opening the camera app and the camera cannot take photos or videos.
The Camera App Glitches
If the error message appears upon opening the camera application, it could be a false alarm and single occurrence. If this happens, you can restart the camera app and reopen it.
The Device has a Full Cache
If the error message continues to come up after restarting the app, the cache may be full. The camera app cache holds pieces of information to run more efficiently. You can safely clear the cache without deleting any pictures or video. Go to Settings. Tap “Application Manager” and find the “Camera” app. Hit “Force Close” to close the app before this process, then go to Storage. Tap “Clear Cache” and tap“Clear Data.”
The Smart Stay Feature Causes the Error Message
The Samsung Smart Stay feature has been known to unintentionally cause the error message in the camera app. Disabling Smart Stay can fix the problem. Go to Settings. Under Apps, tap “Disable Smart Stay.”
The Device Data is Corrupted
If nothing above fixes the problem, it could be corrupted device files which are causing the camera error, and you must hard reset your device to fix the problem. A hard reset will restore the device to factory default, so be sure to backup your data before you do this. Open Settings. Tap “Backup and Restore” then “Factory Data Reset.” Tap “Reset Device” and “Erase Everything.”
The Camera Hardware Malfunctioned
If no software remedies work, it is likely the camera hardware itself is broken and you will need to replace it in order to fix the problem. Use this guide to replace the camera.
The Tablet Freezes, Slows, or Crashes Unexpectedly
The tablet shows signs of freezing, has an unexpected low frame rate, or turns off and crashes.
The Tablet Needs to be Restarted
If tablet freezes and there is no response, perform a soft restart. First press and hold power and volume keys down for 10 seconds. Wait until Device powers off and restarts.
The Tablet Has Low Memory
To fix low memory, it is necessary to clean up memory cache. To clear up the memory cache navigate to settings. Then applications, tab on application manager then clear memory on the necessary apps.
The Motherboard is Malfunctioning
If the tablet is crashing for no apparent reason, the motherboard may need replacing. Replacement of this board will renew the life and function of your device. Use this guide to replace the motherboard.
5 件のコメント
I have Tab S2 813. A friend described it as “a Friday afternoon job“. Nearly 2 years old, it's never worked as it should. It going back to Samsung for the 5th time. I doubt I'll be fixed. A 9yo can see the problems, but apparently a Samsung “engineer” cannot.
Freezes several times per day for about 2 minutes at a time. Switches off occasionally, probably a time out whilst frozen. Google Calendar crashes multiple times per day, well into double figures, whether Calender is in use or not. Takes Samsung Calendar down with it. Calendar has to be forced to update sync with phone/Samsung Cloud. Disconnects from Wi-Fi for no reason during internet and FB use, even when next to the router. Power port is too large for use with most USB-c leads, so unreliable, possible fire risk, charging.
dave.westover - 返信
Same problems. Battery seems to hold charge,but continually reboots. This tablet is lightly used. A piece of trash
f stavins - 返信
Unable to access wifi
Colin McLellan - 返信
Hello
My tablet Samsung s2 has developed a problem. When switching it on it just keep on switching on off on off on off I don't know what the problem is please help
Oscar D Phiri - 返信
How long have you had it discharged for, if the screen is flickering and severely discharged, open up your device and remove the screen, it takes a crapload of of the battery. However, i think this is common, ive had it happen with my Samsung Galaxy Tab E 32GB aswell.
no. -
