学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Common PS Vita Slim Problems
Diagnose and fix the most common problems plaguing your PlayStation Vita Slim handheld console with these step-by-step DIY troubleshooting guides.
4 Solutions | PS Vita Slim Not Charging |
The device refuses to charge despite being plugged in. Potential causes include software not functioning, hardware not registering charger, improper charger connection, faulty AC charger, and software error. | |
2 Solutions | PS Vita Slim Cannot Connect to WiFi |
The user is having trouble getting the device to sync to any WiFi source. Potential causes include a blocked system access point, a need to reconnect, DNS error causing the device to not find the router, device failing to find the router, and a software error introduced in an update. | |
2 Solutions | PS Vita Slim Unresponsive Joysticks or Buttons |
The device is not responding to any inputs, and the joysticks cannot be used. Potential causes include sticky and dirty buttons or a broken joystick. | |
1 Solution | PS Vita Slim System Can’t Find Memory Card |
The system regularly fails to access the memory card. Potential causes include a memory card that was bumped out of place. | |
2 Solution | PS Vita Slim Unresponsive Black Screen |
The device displays a black screen and refuses to show any active inputs. Potential causes include a dead battery, or a system glitch. |
Didn't find your problem?
Check out the Answers forum if you need more troubleshooting help for your specific issue. Maybe someone has already solved the same issue you are experiencing.
8 件のコメント
Hi My Vita is dead in the water tried everything there is no sound and touch screen not working and screen is dead but i can switch the vita on and off but doesn’t want to do anything else.Help please!!!
Ruan Dirker - 返信
sounds like a softbrick, which cannot be undone at this time. sorry for your loss pal :(
Owen Davies -
my vita power on and display the playsation logo then it turn off
saligaM - 返信
Why when playing baseball , the defense players dive toward the ball instead of running…what would cause this and flickering the teams, schedules. It’s doing it on its own, very aggravating.
franbhorne - 返信
Hi, my son dropped his Ps vita into water and I did dry immediately. Then it won’t turn on. I opened it and used charger to connect , the indicator is orange . I pressed the power button , and turned on when connected charger. I charged for battery for a hour. But it won’t turn on when I disconnected the charger. Is there any problem or damage for motherboard or ?? Please give me the advise or any idea ? Thank you
Johnson - 返信
