学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Camera will not power on
Camera fails to power on when pressing the power button.
Missing Battery/Card
Open the battery/card compartment and check to make sure a battery is installed. If you do not have a battery installed, insert one and check to see if the camera will power on.
Battery has no charge
Check the battery to make sure it is fully charged. If not, charge the device for at least an hour and check to see if the camera will power on.
Faulty battery
If the camera still does not turn on, you may have a faulty battery. You may need to purchase a new battery.
Pictures will not save
Camera will not save pictures or shows that memory is full.
Memory card not present
Check Card compartment and make sure a memory card is inserted. If not, insert a card and attempt to take a picture again.
Memory card is full
If the camera still states the memory is full, erase unwanted pictures on the card after downloading pictures to the computer.
Monitor is difficult to see
Trouble seeing the display on the screen.
Condensation
Condensation may have occurred. Turn off the power, and wait for the camera body to become acclimated to the surrounding temperature and dry out before taking pictures.
Light is caught in the picture
Shooting with flash in dark situations results in an image with many flash reflections on dust in the air.
Water Damage
The inner parts of your device might have been affected by the presence of liquid, in which case you will need to replace the LCD screen.
Camera flash is not working
Photos are coming out dark. Camera flash isn’t working.
Object may be blocking the flash light
An object might be in the way of your subject and the camera. When holding the camera, make sure you do not cover the flash with your fingers.
Flash option is not activated
Check the flash is activated. To use the flash when shooting, press the flash button located on the right of the arrow pad. Use the arrows on the left and right of the arrow pad to select a flash mode and press OK.
Unable to Take Photos
No picture is taken when the shutter button is pressed.
Camera may be on sleep mode
The camera automatically goes into sleep mode and the monitor powers off if there is no operation for 3 minutes. No picture can be taken if the shutter button is pressed while the camera is on sleep mode. To restore camera, operate the zoom lever or other buttons.
Sticky buttons
Food, liquid or debris might have blocked the shutter button. Clean the camera buttons before proceeding to take a picture.
Camera may be powered off
Press the ON/OFF button to power the camera back on after 5 minutes of inactivity.
5 件のコメント
My Olympus TG-3 recently started making a clicking noise when powered on. It seems to come from the speaker, but I could be mistaken. The clicking starts slow and slowly gains speed. At first 1 click every 5 seconds, building up to about 6 clicks every second. It's causing the camera to warm up quickly, with the temperature warning appearing after about a minute of clicking. Everything else still works fine. Any ideas?
Timothy Crowley - 返信
I have the same clicking noise on my TG-4. From what I hear, it’s the AF and there’s nothing that can be done about it. What I don’t understand is that it has worked for years without that noise, and now, the video part of the camera has useless audio.
Marcus Thompson - 返信
als ik een foto (verticaal, portrait) wil trekken met mijn camera olympus tg-3 dan krijg ik een zwart scherm. Als ik een gewone foto (landscape) wil trekken, kan ik wel gewoon door het schermpje zien.
Mijn vorig exemplaar had dat ook. Iemand een idee hoe dit komt en wat er aan gedaan kan worden?
stoempeke - 返信
My camera was working fine, but now when I try to turn it on it makes the normal sound, but the screen doesn’t go on and there’s a long beep … then nothing.
Help?
johnandluluclark - 返信
When I turn on my TG3 , it powers up, a “set up” screen appears with date etc, and a digital bell rings… and the camera shuts down… Any ideas? should I update the software?, I see it is avaialbe on line… the last time used it was fine, I gettin uoff a boat with a big step to shore, to make sure I had two hands availabe, I gently tossed the camera on to the adjcent plush lawn. Your thoughts please…
Bill Martz - 返信
