学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Camera won’t charge
You have plugged your camera in and it is not charging.
Wrong Charger
You may be using an incorrect charger or a charger that does not provide enough power. Refer to the user manual to locate the correct charger.
Broken Charger
The charger may be broken and in need of replacement.
Bad Outlet
The device may be fully functional make sure that the outlet you are using works by using another device or plugging the charger into a different outlet.
Battery orientation
The battery may have been inserted backward, following the Battery Access Guide and then to take the battery out, match the contact points of the battery with the contact points in the camera, and put it back in.
Dead battery
If the lithium ion battery is unable to hold a charge or won’t charge, follow the Battery Access Guide to replace it.
Camera is unresponsive
Camera is not turning on or otherwise responding.
Missing battery
Check to see if the battery is in the camera
Battery has no charge
Charge the device for an hour or more to see if the battery is just dead and in need of a charge
Dead battery
Camera has water damage
Faulty or dirty seals have allowed water into the device and the device will need cleaned or replace. Replace the seals using the Seal Replacement Guide.
Damaged or non-functional screen
The screen is black or not displaying correctly or it has been damaged.
Broken Screen
If the screen is broken due follow , LCD Screen Replacement guide to replace the screen.
Screen not turning on
'The screen is black, but the camera seems to be on.''
This is likely caused by water damage to the unit, follow LCD Screen Replacement guide to replace the screen.
=== Screen has dirt or other debris between the outer and inner screen, follow LCD Screen Replacement guide to remove the screen for cleaning.
Camera buttons not working
The buttons are not responding when pressed or are responding only part of the time.
Sticky Buttons
If the buttons on the back panel become sticky from food, liquid or debris, follow the Back Panel & Button Access Guide to remove that back panel and inspect and clean the buttons.
Buttons are unresponsive
If the buttons stop working completely they can be replaced by following the Back Panel & Button Access Guide or the Shutter Button Access Guide depending on the buttons affected
Camera won’t take pictures
If you depress the shutter button when the camera is on and nothing happens, follow the Shutter Button Access Guide to inspect and clean the shutter button.
Camera is leaking
The camera is allowing water in.
Broken or Damaged Seals
If a seal has been damaged or has lost its waterproofing capability follow the Seal Replacement Guide to access the damaged seals.
Broken Camera Shell
The shell of the camera may have been compromised if it has experienced severe trauma.
Lens Problems
Dirt or some other article is showing up in pictures or Lens is damaged or not functioning correctly.
Debris or dust in pictures
If damage to the camera has allowed particles in, follow the Lens Box Access Guide to remove the lens box and inspect the device
Lens is not focusing
To replace the lens box, follow the Lens Box Access Guide.
7 件のコメント
Hi..im having a little problem with my camera, when I look back at my videos I recorded..some green blurred lines pop up once in a while..everything else works good! Does anyone know whats going on with my camera?
martinezjanet3 - 返信
I am having trouble on turning on my camera. When I press on it gives me the USB option with noise then it shuts off and on repeatedly. When it turns on, it does not move to other given option.
Lourdes Mayao - 返信
Same here did u work it out
Gary Clee -
High I’m having trouble charging mine! I tried the 240V charger that came with camera that doesn’t work and have charged via my computer twice and now it won’t charge at all.
Richard Minchin - 返信
Big problem-my Olympus Tough TG 2 does not open in Olympus Viewer 3-so how do I get that sorted?
wetrock.start - 返信
