学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Laptop Turns On and Off By Itself, Without A Display Appearing
The computer turns on, but then turns off by itself, and repeats this, without a display appearing.
Memory Failure
The RAM may have failed and needs replacing, or be loose and needs to be reseated.
Motherboard Failure
If the RAM has been reseated/replaced and the problem is still happening, then the motherboard is not working, and needs to be replaced.
Laptop Makes Rattling or Grinding Noise While Running
When the laptop is on, there’s a strange rattling or grinding noise happening.
Faulty Hard Drive
If the cooling fan is not spinning, and the noise is persisting, the hard drive is probably the cause of the sound, and needs to be replaced.
Faulty Cooling Fan
The cooling fan may be dusty, or needs to be replaced. If the fan is dusty, use a compressed air duster to blow the dust off of the fan. If this does not resolve the issue, try replacing the fan.
Battery Will Not Charge
The battery is not charging while plugged into the charger.
DC Power Connector Failure
If the battery charges when the laptop is plugged into the power adapter, but only after the power adapter is adjusted, or in a certain position, then the DC power connector has failed and needs to be replaced.
Battery Failure
Try reconnecting the battery, by removing it and replacing it. If the battery still doesn’t charge, remove the battery, and plug the laptop into the power adapter. If it runs fine while plugged in, then either the battery or the motherboard are faulty and needs to be replaced.
Motherboard Failure
If the battery is not the cause of the problem, the motherboard will need to be replaced.
Distorted Image or Strange Colors Appearing on the Screen
The image displayed on the laptop screen is very distorted, or there are strange colors appearing.
Video Cable Failure
Test the laptop by plugging it into an external monitor. If the image on the screen is normal on the other monitor, then the video cable may not be properly connecting to the motherboard, or needs replacing.
Graphics Card Failure
If the distorted image persists when the laptop is plugged into an external monitor, then the graphics card has failed and needs to be replaced.
0 件のコメント
