Device scanner malfunctioning
Device is running into walls/furniture, or missing parts of the room.
Lidar Scanner may be covered
The Lidar Scanner may be covered by something. Wipe it off and check to see if it works. The Lidar Scanner appears as a little bump on top of the device.
Lidar Scanner may be broken
Your Lidar Scanner may be broken. The Lidar Scanner is what the device uses to scan its surroundings. If wiping off the Lidar Scanner doesn't fix the issue, then replace the Lidar Scanner here: [Insert Link to Lidar Scanner replacement guide here]
Device won't connect to Internet
App says device isn't connecting to the Internet
Problems with the app
Make sure that you have the app downloaded and all the settings properly set. Make sure you're connected to a 5GHz network.
Problems with your internet
The Cybovac L20 will have trouble with connecting to internet if the WiFi Network if:
There are Emojis, Special Characters, or Symbols in the name or password of the WiFi.
If the WiFi requires authentication through a web page.
If the WiFi has a hidden name.
If the WiFi is using a proxy server or VPN.
If it is a private WiFi network.
If the device still won't reconnect, then uninstall and reinstall the app.
Problems with the Motherboard
If nothing else works, then there may be issues with the Motherboard and you will need to replace it here: [Insert link to Motherboard Repair here]
Failure to charge
The device is not charging
Charging contacts may not be aligned properly
Your charging contacts may not be aligned with those on the base. Make sure to align charging contacts located on charging base with those on the device itself.
Charging/Dust collecting contacts may be covered
Check for any dust or obstruction that may be built up on the charging surface or dust collecting contacts. Clear off the obstruction, and try again.
Dead Battery
If there's no obstruction on dust collecting contacts, and charging contacts are aligned with those on the device itself, then battery may be faulty. Proceed to replace it.
Main brush doesn't work
Main brush does not spin as usual
Brush struggles to spin
There may be debris interrupting the functionality of the brush. Check to see if a foreign object is disabling the brush to spin.
Brush fully does not spin
If the brush does not spin, check if the device is on and the brush is visibly clear. If problem persists then change the brush.
Side brushes don't work
Device is cleaning a smaller width.
Brush does not spin effectively.
Remove the side brushes to remove any debris that may be holding the brushes back.
Broken brush
The side brush may be chipped, and or broken. Replacing the side brushes will be necessary.
0 件のコメント
