Kyocera Oystr TroubleShooting
Kyocera Oystr is a flip phone made by Kyocera Communications Inc.
-Shine light on phone screen, if display still shows up then your backlight on your phone may be out, if it doesnt then you may need a brand new screen
-Check to see if you have Kyocera certified battery
-Check if you have certified phone charger
-Replace Battery
- If your phone is going straight to voicemail and you have good service and sufficient power then you may to to contact your provider to reset your voicemail
- Press button below "Keyguard," then press 123 or the "OK" key to unlock the Keyguard feature. The phone will display "Keyguard Disabled."
-Contact Kyocera
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 840
