学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Wireless speaker doesn't turn on:
There may be issues with your wireless speaker if it does not want to turn on.
Is your wireless speaker not turning on even when it's charging?
If your wireless speaker does not want to turn on make sure the charger's cable is plugged into the speaker. If the charger's cable is plugged in and the speaker still doesn’t turn on, replace the battery. Replace using this link: Heyday Wireless Bluetooth Speaker 9979 Battery Replacement.
No audio from speaker:
When you aren't able to connect to Bluetooth you might not be pressing the right buttons.
Device not paired
If you are trying to connect a device to the wireless speaker and the Bluetooth is not going through, you might want to reset the Bluetooth connection on the speaker. If that does not work you can also remove the speaker Bluetooth through your device by going to Bluetooth setting and clicking on the name and it will say “unpair” or “remove the device.” After you remove or unpair you can try to pair your device to the wireless speaker again to see if the Bluetooth works.
The wireless speaker does not sound loud:
Are the buttons not adding any volume to the speaker.
Speaker is too far from source device
If the speaker's audio sounds warped, it may be that the device synced to the speaker is too far away. Therefore don’t take your device out of the speaker's zone. There could also be something interfering with the speaker so make sure nothing is in the speaker's way. If nothing is working, try to turn off the speaker. Turn it back on and sync the BlueTooth to your device. Use this link Heyday Wireless Bluetooth Speaker 9979 Volume Technique.
The wireless speaker's microphone does not work:
Are you unable to hear a person on the phone through the wireless speaker.
Does the audio sound fuzzy?
First, connect your device to the Bluetooth speaker. Then talk to your voice helper, for example, “Hello Siri.” If you don't hear anything back then there could be an issue with your microphone that needs replacing.
2 件のコメント
Hey, I have had my heyday speaker for a while now and it has never bugged out like this. It works one minute and the next it’s offline. I tired holding the power button down and it turned on for two seconds and as soon as I put the speaker down on the table it turned right back offline. It’s plugged into the wall all the way and that chord is plugged into my speaker all the way. I’ve tried everything it feels like. What else will help.
Judge.09 - 返信
I'm having the same problem, how'd you solve this issue? Thanks
Jovanna Shummon - 返信
