If device will not turn on, your internal headphone adapter may need to be removed and replaced.
This device is powered by the iPod or iPhone device it is plugged into, so if device will not turn on, your internal battery may need to be removed and replaced.
If the device is on but you cannot see anything on the LCD display, the wiring of the backlight may need to be replaced or mended or It is possible that the entire LCD needs to be removed and replaced.
If you cannot get the radio to play on your device, you may have low radio detector responsiveness.
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 266
