学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Bissell Bolt ION 2-in-1 Cordless Vacuum
Troubleshoot for the Bissell Bolt ION 2-in-1 Cordless Vacuum
Vacuum Will Not Power On
The Bissell Bolt ION may not power on due to the wrong charger being used or not being fully charged.
Use the Charger that Came with the Product
The manufacturer box should contain the correct charger.
Charge Vacuum
The vacuum should be first charged for 4 hours before use.
Vacuum has Low Suction Power
There may be problems with the dirt container, the filters, or the foot.
Dirt Container Maintenance
The dirt container may have to be cleaned or positioned correctly for suction power to resume.
Filter Maintenance
The filters may need to be replaced and changed.
Foot is Loose
The foot is loose and may need to be readjusted and secured it in its position in its body.
There is an Obstruction
There can be something obstructing the foot. The foot needs to be detached from the body and have the obstructions removed. Place the foot back in its position.
Dust/Dirt Escaping Containment Bag
The dirt container may be full of debris or the dirt container or filter might be installed incorrectly.
Dirt Container is Installed Incorrectly
Empty the dirt container and put it back in its position. The dirt container may be installed incorrectly, so secure the dirt container in the correct position.
Filter is Installed Incorrectly
If the problem is not with the dirt container, then it might be the filter. The filter must be installed correctly.
Vacuum Won't Charge
It is important to use the correct charger.
Correct Charger
Only use the charger that came with the vacuum.
Vacuum Brush Replacement
The brush roll may be jammed or needs to be reset.
Brush Roll is Jammed
The obstruction in the brush roll needs to be removed.
Brush Roll Reset
Turn off the brush roll and remove the obstruction. Wait 15 seconds for cool down and turn the power on.
12 件のコメント
my vacuum just all a sudden quit while running..well i charged it till it quit blinking tried turning on…no power!!!plug back in it starts blinking…so if the battery shot or is it the system?? oh not to mention this is the fourth time we have used
jake - 返信
Call Bissell customer service! Mine did that after a yr and I’m on vacuum 3 of the replacement vacuums cause they kept doing that same thing. Charged over night and boom not turning on! I refuse to use the outlet that I had been plugging them into at all now.
ppltiffanyb -
Mine did the same and it was the very 1st use! I cant even use it..junk!
banfield_beer -
this just happened to mine. I’ve used mine a few months on my hardwood floor. Won’t turn on!
Joanne - 返信
If you remove the vaccum from the stick while it is on. It will render the vaccum usless.
Vincent - 返信
