はじめに
It's been two years since the Mac mini's last appearance on iFixit's teardown table, but a newly revised version joins Apple's lineup this week. Is this truly a refreshed mini, or merely a mini-refresh? Stay tuned to find out just what two years of innovation has to say for itself—it's Mac mini teardown time.
Follow us on Facebook, Instagram, or Twitter for the latest teardown news.
必要な工具と部品
ビデオの概要
Apple's "affordable powerhouse" offers a range of hardware configurations (but no gold color option, so you can't configure for bling). Our unit's internals include:
1.4 GHz Dual-Core Intel Core i5 (Turbo Boost up to 2.7 GHz) with 3 MB L3 cache
4 GB of 1600 MHz LPDDR3 memory
500 GB Hard Drive
Intel HD Graphics 5000
802.11ac Wi-Fi + Bluetooth 4.0
OS X Yosemite
Gone are the handy thumb indents and indicators. This mini doesn't appear to have twist-off bottom cover!
A flick of our
bottle openerplastic opening tool pops this (lower) cap off. -
Well that was nice! But now we're greeted with something new: a solid door where there was once handy access to the RAM and fan.
We're starting to feel like the locks on our apartment changed and we weren't given the new keys...
Time to break down the door and see what's changed inside. The plastic bottom cover snaps onto three screws—three TR6 Torx Security screws. Really? Rude.
This is the smallest Torx Security screw we've ever seen—our kits go down to T7 Security, so we asked our tool design team to get improvising.
Thanks, Apple.
Upon removal, the fan seems identical to the one from the previous model—but let's not be too quick to judge a fan by its cover.
Advanced Hydraulic Bearing
Hmm. Interesting. What exactly is Advanced Hydraulic Bearing? Let's find out. According to Asia Vital Components:
AHB "consists of a polished steel shaft, a sintered bearing and fluid lubricant." In this system there "is no contact between shaft and bearing" and thus "the bearing load is carried solely by a film of fluid lubricant."
The AirPort card is dispatched after removing one screw and disconnecting two more antennas from their sockets.
Let's take a look at the ICs found on the AirPort card:
Broadcom BCM4360KML1G 5G WiFi 3-Stream 802.11ac Gigabit Transceiver
Skyworks SE5516 Dual-Band 802.11a/b/g/n/ac WLAN Front-End Module
RF Micro RFFM4293 2.5 GHz FEMS and RFFM4591 5 GHz FEMS
Broadcom BCM20702 Single-Chip Bluetooth 4.0 HCI Solution with Bluetooth Low Energy Support
この手順で使用する道具:Mac mini Logic Board Removal Tool$4.99
Using our handy hand-powered Mac mini logic board removal tool, we handily remove our Mac mini's handsome logic board.
While past Mac minis have featured two SATA ports, allowing users to upgrade their base model with an extra hard drive, this year we only get one.
However, this empty socket over here may well be a spot for a PCIe cable, enabling the installation of a blade SSD.
True to our word, we cracked open a Fusion drive equipped Mac mini, and it looks like our suspicions were accurate.
The empty connector is now filled—by a PCIe cable, glued to the top of the hard drive tray.
The SSD matches the one we found in the MacBook Air 13" Mid 2013 with the same chips:
Samsung S4LN053X01-8030 (ARM) flash controller
8 x Samsung K9LDGY8SIC-XCK0 16 GB flash storage
Samsung K4P2G324ED 512 MB RAM
Let's have a look at the ICs on the logic board:
Samsung K4E8E304EE-EGCE 8 Gb LPDDR3 DRAM (8 Gb x 4 = 32 Gb = 4 GB)
Cirrus Logic 4208-CRZ Audio Codec (a returning champion from a bevy of recent Apple products including the Mid 2013 MacBook Air and Mac Pro)
Broadcom BCM57766A1KMLG Ethernet PCIe Controller with SD3.0 Card Reader and ASF 2.0
Intel DSL5520 Thunderbolt 2 Controller
Delta Electronics LFE8904C-F Discrete LAN Filter
NXP 6142F and NXP PCA9501BS 8-bit I/O Expander
The IC party continues:
Microchip Technology 1428-7 420BE5A BMY System Management Bus (SMBus) Temperature Sensor
Cypress Semiconductor CY7C63833 LTXC enCoRe II Low Speed USB Peripheral Controller
Texas Instruments TPS51916 DDR3 Memory Power Solution Synchronous Buck Controller
Texas Instruments 58873D Synchronous Buck NexFET Power Block MOSFET Pair
The IC after-party:
Intel Core i5-4260U Processor with Intel HD Graphics 5000
Texas Instruments/Stellaris LM4FS1EH Microcontroller
Parade PS8401A HDMI Jitter Cleaning Repeater
Macronix MX25L6406E 64 Mb CMOS Serial Flash
Intersil 958 26AHRZ M419VL
We've got the power (supply) at the tips of our fingers. It's an easy extraction, even if it took a while to get here.
We get a slight rush before we realize it is the same as the 2012 model...which was the same as the 2011 edition.
Before we go, let's pull out the hard drive tray and take a look at the platter drive our mini came loaded with.
Tucked under the tray: a 500 GB, 5400 RPM HGST hard drive, coming in at 2.5" wide and 7 mm thin.
And on the top of the tray, a promising mounting point for a blade-style PCIe SSD, presumably what we'll find in a Mac mini equipped with Fusion Drive.
Mac mini Late 2014 Repairability: 6 out of 10 (10 is easiest to repair).
There's no glue anywhere inside that needs to be removed while disassembling the mini.
With the proper tools, disassembly is straight-forward and simple.
T6 Torx Security screws are intended to lock you out of your mini, and make it hard to clean the fan or replace the hard drive.
The CPU is soldered to the logic board and not user-upgradeable.
The RAM is now also soldered to the logic board, and not user-upgradeable.
65 件のコメント
Is there an obvious size or accessibility issue that forced them into soldering the RAM down? I know Apple is all about sleek and slim, but was this necessary? 8GB isn't bad for a small workstation, but you can't ever have too much RAM. The option for the future would have been nice.
I think Apple was going for the simplest solution with the least amount of connections that could become loose. With the security screws, Apple obviously doesn't want anyone inside even though it appears to be easy to replace the hard drive, power supply, and fan. I see this as a commodity item where you replace instead of repair. I know that doesn't fit the mold of iFixit but at least they didn't glue it shut. If this model becomes the replacement for server farms, I would like to know how many Mac mini's are actually repaired when they fail and how many are simply replaced with new ones and fired back up (old ones either repaired or tossed).
plink53 -
Will iFixit be tearing down one of the higher spec mini models? I'm curious whether they have a secondary SATA connection and how replaceable are their SSDs.
I'm usually positive about new products but totally bummed about the Mac Mini line. I recently upgraded the ram on my Quad Core i7 Server to an undocumented 16GB, just by onscrewing the base and slipping 'em in. Felt great and made her run a lot more smoothly. Now I better take good care of her, because there'll be no more Quad Cores and no more user-upgradeable memory. And Apple couldn't give a shrimp. :-(
