メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
We disassembled this iPod on September 13, 2006.
この分解は修理ガイドでは ありません。 お持ちのiPod Nano 2nd Generationを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Before we take it apart, here's some images of the new packaging. Here's the sexy, new, 52% less volume packaging Steve was so excited about.
    • Before we take it apart, here's some images of the new packaging.
    • Here's the sexy, new, 52% less volume packaging Steve was so excited about.
  2. The new packaging is innovative. Plastic retainers hold the iPod on top and bottom, and you must flex the plastic packaging to get the iPod out.
    • The new packaging is innovative. Plastic retainers hold the iPod on top and bottom, and you must flex the plastic packaging to get the iPod out.
  3. Meet the family. From left to right: Mini, new blue Nano, new black Nano, old black Nano.
    • Meet the family. From left to right: Mini, new blue Nano, new black Nano, old black Nano.
    • Ah, what to call it? iPod Nano Gen 2? iPod Mini Gen 3? Remastered iPod Nano? We vote for 'that little blue music thingy.'
  4. Goodies! Left to right:
    • Goodies! Left to right:
    • iPod
    • Fold-out quick start guide (includes two small white Apple stickers)
    • Plastic 'dock'
    • New earbuds
    • USB docking cable
    • The center button is concave, as opposed to the old Nano (flat), and old Mini (convex).
  5. It may be thinner than the old Nano, but it's sure not by much.
    • It may be thinner than the old Nano, but it's sure not by much.
  6. The back shouldn't scratch instantly anymore.
    • The back shouldn't scratch instantly anymore.
  7. On to the disassembly!
    • On to the disassembly!
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    • Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
  8. Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top. Be careful not to damage the soft plastic with your tool.
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top. Be careful not to damage the soft plastic with your tool.
    • The new Nano more closely resembles the old Mini design than the previous Nano generation.
  9. Lift the top bezel off of the iPod.
    • Lift the top bezel off of the iPod.
  10. Pry the bottom bezel off using the same technique as the top.
    • Pry the bottom bezel off using the same technique as the top.
  11. Lift the bottom bezel off. It's glued on using a mild adhesive, so some force may be required.
    • Lift the bottom bezel off. It's glued on using a mild adhesive, so some force may be required.
  12. Remove the two Phillips #00 screws from either side of the dock connector.
    • Remove the two Phillips #00 screws from either side of the dock connector.
  13. Remove the two Phillips #00 screws from the top of the iPod.
    • Remove the two Phillips #00 screws from the top of the iPod.
  14. Pry out the headphone jack slowly with a spudger. Do not remove the headphone jack entirely, as it is connected via a fragile ribbon connector to the click wheel.
    • Pry out the headphone jack slowly with a spudger. Do not remove the headphone jack entirely, as it is connected via a fragile ribbon connector to the click wheel.
  15. Once you have pulled the headphone jack out of its slot, remove the Phillips #00 screw formerly concealed beneath it.
    • Once you have pulled the headphone jack out of its slot, remove the Phillips #00 screw formerly concealed beneath it.
  16. Remove the metal bracket surrounding the docking connector.
    • Remove the metal bracket surrounding the docking connector.
  17. Disconnect the headphone and click wheel cable from the logic board. It's tricky to see what you're doing, so you'll have to feel the connector inside the iPod with the spudger.
    • Disconnect the headphone and click wheel cable from the logic board. It's tricky to see what you're doing, so you'll have to feel the connector inside the iPod with the spudger.
    • You need to pry the connector toward the front of the iPod until it comes loose from the logic board.
    • Do not entirely remove the headphone jack. The cable is still connected to the click wheel.
  18. Use a spudger to push the logic board assembly out of the casing. The click wheel and headphone jack should remain in the iPod.
    • Use a spudger to push the logic board assembly out of the casing. The click wheel and headphone jack should remain in the iPod.
    • Be careful not to catch the headphone jack and click wheel on the logic board as you remove the logic board and display.
  19. Completely remove the display and logic board from the iPod.
    • Completely remove the display and logic board from the iPod.
  20. We got it apart!
    • We got it apart!
    • The casing is certainly more scratch-resistant than the previous Nano. We were careful and didn't scratch the case at all.
  21. Pry the metal bracket off the back of the display. Make sure you only pry off the bracket and not the clear shielding on the rear of the display.
    • Pry the metal bracket off the back of the display. Make sure you only pry off the bracket and not the clear shielding on the rear of the display.
  22. Lift up the display and use a spudger to flip up the black plastic retaining bar holding the display ribbon cable in place.
    • Lift up the display and use a spudger to flip up the black plastic retaining bar holding the display ribbon cable in place.
  23. Slide the display ribbon out of its connector and lift the display off of the logic board.
    • Slide the display ribbon out of its connector and lift the display off of the logic board.
  24. Left: new Nano logic board and battery.
    • Left: new Nano logic board and battery.
    • Right: old Nano logic board and battery.
    • The new battery is thinner, but significantly larger.
    • The new Nano uses Samsung flash memory, just like the previous model.
    • Whatever you do, don't throw your new iPod into a fire!
  25. Close up of logic board. Here's some extra-large top and bottom logic board photos. Notice the Apple logo on the ARM chip. The numbers on it read: 33753291 8701 N02R5Q5 0627 ARM.
    • Close up of logic board. Here's some extra-large top and bottom logic board photos.
    • Notice the Apple logo on the ARM chip. The numbers on it read: 33753291 8701 N02R5Q5 0627 ARM.
    • That's it, folks! We sell parts for iPods (including this one), so check out our iPod parts store to fix up your old and broken iPods.
2 件のコメント
sera que lo puedo pintar su skin es plomo pero quiero que sea azul.
Myriam Sarango - 返信
I can’t do this as my iPod has dents where the screws are
Mix Vidios - 返信
コメントを追加
統計データを表示:
過去 24時間: 7
過去 7 日: 56
過去 30 日: 238
今までの合計 131,786
