メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのiPod Nano 1st Generationを修理する際は、iFixitの修理ガイドをご利用ください。
  1. iPod Nano 1st Generation Teardown, Open The iPod: 手順 1、 2の画像 1 iPod Nano 1st Generation Teardown, Open The iPod: 手順 1、 2の画像 2
    • 1. Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool up to the connection point. This should pop the case off. Note that force will need to be used.
    Holy cow! That battery is bulged!
    Lucas Hoekstra (Lucas9810) - 返信
    That's one spicy pillow!
    Ben Capehart - 返信
  2. iPod Nano 1st Generation Teardown: 手順 2、 1の画像 1
    • 2. Remove the circuit board by unscrewing the 3 screws (there is 1 more screw but dont unscrew it, it holds the headphone jack) that hold it down. Note that specialised screwdrivers may need to be used.
  3. iPod Nano 1st Generation Teardown: 手順 3、 2の画像 1 iPod Nano 1st Generation Teardown: 手順 3、 2の画像 2
    • 3. Carefully remove the connected wires underneath the motherboard to disconnect the clickwheel and the screen.
    Is it just me or does it look like that battery is about to burst?
    TuxRug - 返信
    Wow, yeah that thing is toast.
    Andrew Bookholt -
    Do I remove the yellow tape?
    shads - 返信
  4. iPod Nano 1st Generation Teardown: 手順 4、 3の画像 1 iPod Nano 1st Generation Teardown: 手順 4、 3の画像 2 iPod Nano 1st Generation Teardown: 手順 4、 3の画像 3
    • 4. The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover.
  5. iPod Nano 1st Generation Teardown: 手順 5、 3の画像 1 iPod Nano 1st Generation Teardown: 手順 5、 3の画像 2 iPod Nano 1st Generation Teardown: 手順 5、 3の画像 3
    • 5. Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply and carefully pull them off.
  6. iPod Nano 1st Generation Teardown: 手順 6、 1の画像 1
    • 6. Finally you should have the ipod dismantelled and you should be able to put the ipod back together.
作成者
3人の作成者と共同で作成されました。
Craig Lawrence
メンバー登録日: 03/11/10
444 ポイント
1ガイドが承認済み
6 件のコメント
when i put the rear cover back on, the charging station doesn't line up correctly and the charging station sticks out a bit. any advice?
krnchang - 返信
is the batter swollen
Derek King - 返信
Yes, happened to a Zune 80 I have
CTCL -
Thank you for this - took the fear factor out of changing battery on my much loved Nano!
jimbradshaw - 返信
It’s extremely hard to connect LCD and Button cables. I screwed it up while reconnecting the cables. IF, you want to disassemble this machine by fun, don’t ever try it.
Sizun Cho - 返信
While opening I have broken the touchpad strip. Any leads from where can I get it. This iPod nano was very close to me.
If someone can help, do mail me at alirafique@hotmail.com
Ali Rafique - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 130
今までの合計 28,639
