メインコンテンツにスキップ
必要な工具と部品
ビデオの概要
この分解は修理ガイドでは ありません。 お持ちのiPhone 7 Plusを修理する際は、iFixitの修理ガイドをご利用ください。
  1. iPhone 7 Plus Teardown, iPhone 7 Plus Teardown: 手順 1、 1の画像 1
    • There's a lot to learn about what's hidden inside the "best, most advanced iPhone ever"—but first, let's take a moment to review what we already know:
    • Apple A10 Fusion processor with embedded M10 motion coprocessor
    • 32, 128, and 256 GB onboard storage capacity (jet black model not available in 32 GB)
    • 5.5-inch multitouch IPS Retina HD display with 1920 × 1080 pixels (401 ppi)
    • Dual 12 MP wide-angle and telephoto cameras with f/1.8 and f/2.8 apertures (respectively), 2x optical zoom, and 10x digital zoom
    • 7 MP FaceTime HD camera with f/2.2 aperture and 1080p HD recording capability
    • Solid-state Home button with Touch ID, driven by new Taptic Engine
    • 802.11a/b/g/n/ac Wi‑Fi + MIMO Bluetooth 4.2 + NFC
    Which carrier phone is this
    deepu272 - 返信
    The iPhone 7 plus is much deferent than iPhone 6 and iPhone 6S. The lack of antenna lines especial at the jet black version, the lack of earphone jack, the dual lenses and dual speaker make it distinguishable. I personally like it very much and I will soon buy the iPhone 7 plus jet black 256GByte model. The only thing I dislike is that I won't be able to store my iOS apps on my hard disk as I am doing with my old jailbroken iphone 6 plus. So the 256 Gbytes are more than necessary.
    Agnostos Gnostos - 返信
    @Agnostos Gnostos
    "The only thing I dislike is that I won't be able to store my iOS apps on my hard disk..."
    You can do that using iTunes without jailbreaking. You always could.
    alex - 返信
    I want to make my iphone at home , but from where i should get the parts ???
    can you help me?
    please
    reply me
    Nakul Phulwade - 返信
  2. iPhone 7 Plus Teardown: 手順 2、 3の画像 1 iPhone 7 Plus Teardown: 手順 2、 3の画像 2 iPhone 7 Plus Teardown: 手順 2、 3の画像 3
    • The dimensions of the iPhone 7 Plus are identical to those of its predecessor, at 158.2 mm × 77.9 mm × 7.3 mm—and yet it's slightly lighter, at 6.63 oz (vs. the 6s Plus at 6.77 oz). Hopefully Apple didn't remove anything important.
    • The 7 Plus is also stamped with a new model number: A1785.
    • For those more inclined to the dark side, Apple is now offering matte black and scratchable jet black versions of the iPhone 7 Plus, in addition to the already available silver, gold, and rose gold colors.
    • The 7 Plus also drops some of those unsightly antenna lines of old, in favor of a more subtle appearance.
    • Perhaps the most noticeable difference is the Lightning to 3.5 mm headphone jack adapter included in the box. It's going to take some courage for us to move on from the headphone jack. Sorry baby adapter. It's not you, it's us.
    Quote: "6.63 oz (vs. the 6s Plus at 6.77 mm)"
    I know you meant, "6.77 _oz_"!
    biowizard - 返信
    have you done a baby teardown on the baby adapter ? Does it have a DAC in it ? If so which one?
    Jasraj Vaidya - 返信
    The DAC is in the iPhone. How it's for the speakers too.
    George A. -
    No, it's not me, it's "baby adapter" Dongles were a thing of the past, and hated them as much as they will be hated now.
    scottwilkins - 返信
    The dimensions of the iPhone 7 Plus are identical to those of its predecessor, at 158.2 mm × 77.9 mm × 7.3 mm—and yet it's slightly lighter, at 6.63 oz (vs. the 6s Plus at 6.77 oz). Hopefully Apple didn't remove anything important.... They removed the headphone jack and assembly.
    Emma - 返信
    I have no courage. I also have no Apple Music because I have no reason to trust Apple with my content.
    Dave - 返信
    oz... what is oz... You are measuring in mm, so do in Gram, too... 99% of the world does it metric...
    Skimmy - 返信
    Yes. you're right!
    Ricardo Rodríguez -
    How about 3.5mm powered accessories like the square? Is square going to ante up for the lightning interface?
    refd123 - 返信
    I don't believe that the jet black color is so prone to scratches. I generally baby my phone and protect them with cases and glass membranes. So it's not a real issue. The lack of earphone jack isn't a problem. I bet that every manufacturer very soon will produce earphones with lighting jack. Those with very expensive conventional earphones will find the earphone adapter annoying but that isn't a big issue. After all when you are buying a phone at 800 dollars you can spent 100 dollars for decent earphones. Apple as always is removing parts from its iPhones. People forget that the earphone jack of the first generation iphone was small and deep inside. It didn't allow many earphones.
    Do the new antenna lines in the 7 plus iPhone improve the signal reception in poor transmission areas
    gaylestan - 返信
    @dave.
    "I have no courage. I also have no Apple Music because I have no reason to trust Apple with my content."
    Apple music is a subscription streaming service. You don't own the content. So you don't need to trust them.
    I keep my own content on iTunes match. I do trust them. But it's all safe on my Mac, and backed up too.
    alex - 返信
    @refd123
    'How about 3.5mm powered accessories like the square? Is square going to ante up for the lightning interface?"
    The square works off the headphone jack. If they use it to spec, then it should work off the adapter.
    alex - 返信
    Don't know about A1785,
    but on Apple's iPHone specs page they specifiy two 7+ model #'s as A1661 & A1784.
    One of them supports CDMA, the other does not.
    macnosy - 返信
  3. iPhone 7 Plus Teardown: 手順 3、 3の画像 1 iPhone 7 Plus Teardown: 手順 3、 3の画像 2 iPhone 7 Plus Teardown: 手順 3、 3の画像 3
    • Before we dig into this three-eyed monster, we indulge ourselves with a sneak peek thanks to our friends at Creative Electron.
    • Stay tuned for more views of the new iPhone's internals courtesy of our X-ray X-perts!
    • What advantage does the superpower of X-ray vision grant?
    • For starters, we can see that the headphone jack got kicked out to make space for more Taptic Engine.
    • Closer inspection shows a new, second lower speaker grille that leads... nowhere? Interesting.
    • We can also see the new third eye in the camera array of the iPhone 7 Plus. What wisdom and vision does it hold? Let's find out!
    Please x-ray the Lightning to 3.5mm jack adapter so we can see if there's a DAC and AMP built into the cable. Otherwise you're going to have to cut it open, and that won't be pretty.
    iPostIt - 返信
    I second this!
    Dan Parsons -
    I wonder if you could use the Lightning to mini jack adapter on one of the older iPhones as a way around having to replace the mini jack when it goes within the phone.
    Dan - 返信
    The adapter's store page lists it as compatible with every iOS device with a lightning port. Looks like that should work.
    Chaz Larson - 返信
    The adapter will work with all devices running iOS 10+
    You can also use the lightning headphones with any iOS 10+ device as well.
    As iOS 10+ only supports the lightning connector they will work with and are backwards compatible with any capable of running it.
    paul - 返信
    The X-Ray photos that iFixit publicly show are fantastic. I don't think that Apple will be happy with such deep intervention into its hardware. However I am sure that all major phone manufactures are using similar technics of inspection.
    Well it looks like the Mini to Lightning adapter has its own DAC! Here's a teardown: iPhone 7 headphone dongle boasts amazing insides
    Dan - 返信
  4. iPhone 7 Plus Teardown: 手順 4、 3の画像 1 iPhone 7 Plus Teardown: 手順 4、 3の画像 2 iPhone 7 Plus Teardown: 手順 4、 3の画像 3
    この手順で使用する道具:
    iSclack
    $24.99
    購入する
    • Apple may have gotten rid of the headphone jack, but clearly stays loyal to the Pentalobe. Two now-familiar screws guard each side of the Lightning connector.
    • Eager to see past the rose gold exterior, we perform some forceful iSclack-ing and a great deal of prying to get past the intense adhesive.
    • The adhesive strip sealing the 7 Plus is considerably stronger than the strip we found in its predecessor. Could this be our first sign of waterproofing?
    Does it make sense noting the best location to set the iSclack onto the iPhone so not to rip the cable connection shown in Step5 below? Or the best pattern to lift the cover off.
    Dan - 返信
    Apple could easily have avoid screws on iPhone like it does with iPads and iPod touch. This is an indications that Apple wants their phone to be serviceable by experienced foreigners. But not easily ben opened by ordinary users. The adhesive strip is a good idea. I wouldn't like an iPhone with a wobbling battery inside.
    It's not waterproof, it's water-resistant. Similar, but not the same.
    Aristarco Palacios - 返信
    Can anyone confirm are the pentalobe screws identical (diameter and shaft length) to those of the 6 plus's?
    Cooper Chase - 返信
    How are the pentalobe screws protected from water? Is there rubber gusket?
    Apple - 返信
  5. iPhone 7 Plus Teardown: 手順 5、 2の画像 1 iPhone 7 Plus Teardown: 手順 5、 2の画像 2
    • What is this madness? The 7 Plus bizarrely opens to the side, despite the familiar clips at the top of the phone that help align the display as in previous models.
    • We got lucky and didn't rip the display cables along the middle-right side. Thankfully, the top cable has some slack.
    • Subtle design changes like this are where repair guides come in handy.
    • Opening the 7 Plus reveals lots of black and white gooey adhesives running along the perimeter of the phone.
    • Our bet is that this penguin-themed stickiness is part of Apple's efforts to add water resistance. Then again, Apple's engineers might just really love glue.
    Interesting, threes no button, yet it looks like there is? and the metal peice on the side transfers teh taptic? ... Can you go more into this?
    Mark - 返信
    That's the TouchID sensor.
    fastasleep -
    Is the White gasket material less or more sticky than the Black? It does look like its thicker than the black (has more viscosity)?
    Dan - 返信
    You guys act like APPLE hasnt already said that the new iPhone has waterproofing. Which they did and there are plenty of videos showing it works
    Jarrett Moering - 返信
    I like your writing style! ..."Then again, Apple's engineers might just really love glue." And then a fanboi moron adds comments! Fake Geniuses' would never learn!
    orion2000 - 返信
    The Glue is silicone ferrite add with adhesive to deflect Cellular transmission effectively
    Loli Pop - 返信
    The iSclack is more than necessary. This cables can be broken easily. One of the reasons I love iFixit. From my experience all iPhones since iphone 4 were a little waterproofing. I didn't have problems with lightly rain or with wet hands or very sweaty faces. Now with the new iPhone I will use it safely at the beach. However waterproofing is a subjective issue. The iphone 7 is less waterproof than the second Apple watch.
    What Apple Enginners love the most was screw. They take all size of screws, probably they have to get used to different 2 different bosses. Lol...
    HSY3 HSY4 - 返信
    I'm sure that very soon, you will be loving selling us replacement waterproof sticky seals.
    alex - 返信
    Yeah where can we get "genuine Apple" seals?
    gleeglee217 -
    As long and convoluted as the prox has become, there should've been a close-up.
    mstein - 返信
  6. iPhone 7 Plus Teardown: 手順 6、 2の画像 1 iPhone 7 Plus Teardown: 手順 6、 2の画像 2
    この手順で使用する道具:
    Mako Driver Kit - 64 Precision Bits
    $39.95
    購入する
    • Inside we find an army of courageous tri-point screws guarding the cable bracket that covers the battery connector and two of the display cables.
    • A year ago we went out on a limb and added the Apple watch screw to our 64-bit toolkit. Boy, what a good thing we did.
    • A second platoon of tri-points secure the bracket for the long and springy upper component display cable.
    • Tri-point screws are uncommon. While you could make the argument that tri-point screws are less likely to strip, we assume if it was a choice of mechanical advantage, we'd see them throughout iDevices. It's pretty clear that they are here to simply hinder the two most common user repairs: battery and screen replacements.
    • We dispatch our own weaponry screwdriver and force the bracket to surrender so we can continue our mission into the heart of the iPhone 7 Plus.
    There is space for audio jack up there!
    victortaykw - 返信
    Audio Jack and Water Resistance strike me as being somewhat mutually counterproductive. I, for one, am very happy to see the poxy 3.5mm Jack consigned to history.
    biowizard -
    Another possibility for the reasoning behind the tri-point screws is that Apple knows these are the most common screws to need to be removed, and chose to go with something less likely to strip for their "geniuses" to work with.
    Bryan Schwartz - 返信
    The Phillips screw is a terrible screw drive design. According to McFeeley's, it was invented and promoted because the driver will cam out when torque increases. I'm skeptical about the motivation, but Phillips screws cam out or strip out with alarming frequency, especially in smaller sizes. I would love to never see or use a Phillips screw.
    If you want to ding Apple for picking obscure drivers, fine. But you should also ding them, and everyone else, when they use the horrible Phillips screws.
    Derek Roff - 返信
    Then why not use Torx?
    Chris Prendergast -
    The reason tri-lobe screws are used is because a Torx drive socket on a screw that small wouldn't work. The tri-lobe is like a Torx profile and has the same advantages, but with two less lobes. In addition, tri-lobes are used because it can be put on a screw with a thinner head, where other drive types wouldn't work. The thinnest screw heads (0.3mm and below) require tri-lobe.
    Do people really think nefarious apple engineers are intentionally trying to keep users from doing repairs? They could care less. Besides, if anyone's gotten that far, a screw type with an uncommon head is not going to stop them.
    John Connor -
    Bryan is right. They are tri-point because they are the most common to remove and therefore you don't want to strip them. Why all the screws aren't tri-point I'm not sure of.
    Shaun Stelley - 返信
    But what size of tri lobe is it? Like apple watch y0.6?
    Piotr - 返信
    I never could understand why Apple is bothering with so many different type of screws. At the age of ebay and iFixit every screw can be opened safely. Maybe another method to discourage users that don't know iFixit to mess with the the internal hardware
    Lets add more screw variant each new release....
    taexyz - 返信
    Be careful on this part, I did rip one of the cables in the middle. There are actually 2 and the one I broke was for the home button...
    Brent Thompson - 返信
    Is there a way to remove stripped screws
    mlclarke303 - 返信
  7. iPhone 7 Plus Teardown: 手順 7、 3の画像 1 iPhone 7 Plus Teardown: 手順 7、 3の画像 2 iPhone 7 Plus Teardown: 手順 7、 3の画像 3
    • In place of the headphone jack, we find a component that seems to channel sound from outside the phone into the microphone... or from the Taptic Engine out.
    • No fancy electronics here, just some well-designed acoustics and molded plastic.
    • Teardown Update: According to Apple, this plastic component is a barometric vent. With the added ingress protection afforded by the watertight seal, the iPhone uses this baffle to equalize the internal and atmospheric pressures in order to have an accurate altimeter.
    • Mechanical buttons are a thing of the past when you have a Taptic Engine! This sleek engine uses haptic feedback to simulate the push of a button, without having a real button.
    • Anyone familiar with the touchpad in the Retina MacBook 2015 has already experienced haptics from the Taptic Engine.
    fake speaker port????
    Stan Chua - 返信
    If it's like ours (Chipworks), there's a microphone on one end of it , so it could be some sort of sound channeling chamber for that.
    BHD2 - 返信
    Touchpad is also in the latest MacBook Pro laptops
    Nathanael - 返信
    Apple doesn't waste space. The left port is for the microphone. It isn't a fake speaker port. And that speaker like component is a sound chamber - like our outer ears.
    James Katt - 返信
    I agree, likely used to cut down on wind noise (low frequencies) the mic could pick up.
    Dan -
    Seems apple wasted space here. That "Taptic" engine seems to have a lot of air in it ( in the middle where it's not needed). Wonder if they could have made that a tad less wide and included the audio jack after all???
    scottwilkins - 返信
    The two things you have to think about is the mass and the throw you have within the Taptic engine when you design it. You need enough mass that can kinetically offset the mass of the device you have it in, as well as the amount of energy to throw of the mass so you feel it.
    It appears Apple has used a slightly larger unit (comparing the images). It would nice if someone could weigh the mass and measure the opening size between the iPhone 7 & 7 Plus Taptic engines and the 6 iPhone vibrators
    Dan -
    Looks a lot like that a "speaker port" for the Taptic Engine, for the home button to not only feel but also sound clicky.
    What you described as a sound chamber doesn't seem to actually have any connection to the microphone, but to the Taptic Engine.
    MrUNIMOG - 返信
    A Taptic could also be used as a subwoofer, due to its low resonant frequency of about 190Hz
    The Speaker Guy - 返信
    Are there pins on both sides of the Lightning port.
    iPostIt - 返信
    I don't understand it.? No other product is taken apart except Apple products. We don't tear apart Samsung, Teslas, GM cars or any other computer type gadgets. Are people that fascinated with only Apple products? Come on stop it. Enjoy the technology. There's plenty of whiz bang products out there try tear them down too. Otherwise, this is iPhone 7, not iPhone 1 give it a break. I want to know more about the hidden features built into the software.
    Cg10 - 返信
    First day on ifixit? That tore down a lot of other stuff too.
    Tom Chai -
    iFixit does not NEED to take apart the newer Samsung devices. They are quite capable of doing that themself...
    Ruurd Pels -
    Tearing down Samsung products is too dangerous. They explode.
    alex -
    The taptic home button is extension of the 3D touch. Where on the 6S the haptic feedback signaled a single "pop" out menu, the home button feedback happens on keypress and keyup. :)
    Peter Shen - 返信
    I had a problem with the central button of iPhone 4. Now with the touchpad central button of iPhone 7 the reliability is increased. However the taptic engine is too big. I think that it takes valuable space from the battery. Beside the reliability issue the classic button should be better. I don't like the taptic engine of new MacBooks.
    Why do you say the Taptic Engine is too big? Do you think they made it bigger than it needed to be to function the way they wanted?
    pgoodwin1 - 返信
    When playing audio, can the Taptic Engine act as a passive bass radiator?
    pgoodwin1 - 返信
    Cam someone just tell me the list of screwdriver sizes needed to take a iphone 7 apart
    chfreeman73 - 返信
    • What do you do when things get shaky? You X-ray everything that moves. And that is exactly what we did with the Taptic Engine.
    • "Taptic Engine" sounds like something found on an intergalactic warship. In truth, we really are just working with a tiny linear actuator and some zig-zag springs that shake a weighted core.
    • To be fair, this is the largest piece of mechanical machinery that we've seen in a smartphone.
    • The Taptic Engine translates the pressure on the new solid state home button into finely controlled vibrations.
    • We all love the sensation of clicking a button. The Taptic Engine's precise oscillation is designed to provide many types of tactile feedback, including the sensation of pressing a mechanical button.
    • Why not just use a regular button with a haptic addition like the iPhone 6s? Well, one less button is one less place for water to sneak in.
    So is this a voicecoil+magnets actuator? Or a piezo device?
    (I'm guessing voicecoil based on the X-Ray.)
    atlant - 返信
    AH-HA! Moving Parts!
    Just Johnny - 返信
    The central button could have been integrated on the screen. However it is a different component below screen that now it isn't moving. I hope in the future Apple will produce screens with a virtual central button.
    In case of jailbrake the central button shouldn't be operational like it used to be with previous iPhone jailbrake methods.
    So this is the device that replaced the audio jack?
    Michael Balzer - 返信
    This "button" is cool, but to remove the audio jack is not. Seems Apple needs to find a middle ground. Smaller taptic device and room for the audio jack. Not sure why this wasn't considered on the "Plus" size.
    scottwilkins - 返信
    What X-Ray equipment do you use? Do you sell this device?
    Yan Li - 返信
    As a new owner of iPhone 7 plus i think a Linear oscillator is a mixed bag - pluses are quite well known so I'll just point out one big minus - when phone silenced is left on the desk it's almost inaudible. I've already missed some calls and alarms. :( - (it's case that covers camera bump so it lays even flat on desk)
    Treku - 返信
  8. iPhone 7 Plus Teardown: 手順 9、 2の画像 1 iPhone 7 Plus Teardown: 手順 9、 2の画像 2
    • We're glad to see Apple sticking with the tradition of including pull tabs for the battery adhesive.
    • It's time for some battery yoga. We stretch each of the three adhesive pull tabs to release the battery and our tensions about difficult battery removal.
    Maybe the trickiest part of iPhone repairing. In the case of an early brake of the battery adhesive, tools must be used for removing the battery. Tools that may puncture the battery and cause fire. I suggest a totally discharged iPhone in case of battery replacement.
    And how are we to do that? Let it run down normally? Seems like thatd take a while.
    Tom Jackson -
    If you rub the haptic feedback sensor in just the right spot it will vibrate continuously and drain the battery quickly
    J Goog -
    4 years later, and I a first time teardown of iPhone, I ask, what sort of tools would ease the removal of the battery in case the adhesive is broken?
    Tay W - 返信
  9. iPhone 7 Plus Teardown: 手順 10、 2の画像 1 iPhone 7 Plus Teardown: 手順 10、 2の画像 2
    • And here's the big bad battery itself!
    • The battery is rated at 3.82 V and 2900 mAh, for a total of 11.1 Wh, a slight upgrade over the 10.45 Wh (3.8 V, 2750 mAh) of the 6s Plus, and on par with the 11.1 Wh, 2915 mAh cell found in the 6 Plus.
    • Apple claims battery life will be up to one hour longer than the 6s Plus—that is, 21 hours of 3G talk time, approximately 15 hours of Wi‑Fi internet use, or up to 16 days on standby.
    The new efficiency of the iPhone 7 plus allows a smaller battery and lighter weight.
    James Katt - 返信
    I don't see how "1.11Wh" can be considered a step down from "1.11Wh"! They are identical numbers. The trouble with comparing mAh values, is that they are meaningless without knowing the voltage. And (knowing that W = VA) ...
    3.82V * 2.900Ah = 11.078Wh (iPhone 7 plus)
    3.80V * 2.915Ah = 11.077Wh (iPhone 6 plus)
    Which means they are exactly the same, bar the least significant digit (which is in the 7's favour)!
    [comment resubmitted to correct typo!]
    biowizard - 返信
    I wondder if Apple ever considers using Quick Charge technology from Qualcomm ? My Iphone6 charges at barely over 1A using Apple adapter and cable (slightly lower if using generic cable), whereas QC 3.0 is known to charge at 2A or higher. What gives ?
    hn1964 - 返信
    Apple as far as I know have a tradition of good batteries except the first generation of iPod nano which wasn't a big issue. I hoped for years that a manufacturer would produced a replacement battery for iPhones with bigger capacity. However Apple has proved that is using the best batteries on the market. And after samsung Galaxy note 7, Apple has the advantage on this factor.
    What voltage can iPhone 7 plus charge at? I see many portable charger claims that they allow voltage boost for iPhone. What exactly it is for me to judge whichever portable charger is best suit for iPhone 7 plus?
    Kevin Yip - 返信
    Will I be able to use iphone 7 plus or iphone 6 plus battery into my iphone 6splus
    shrini23 - 返信
    So the iPhone 6 plus had 2915 mah battery and 6s plus had 2750 mah battery and now iPhone 7 plus have 2900 mag battery they be scamming people
    dandre832 - 返信
  10. iPhone 7 Plus Teardown: 手順 11、 3の画像 1 iPhone 7 Plus Teardown: 手順 11、 3の画像 2 iPhone 7 Plus Teardown: 手順 11、 3の画像 3
    • Apple's got us seeing double as we pull out the camera array with two separate sensors, two lenses, and two little connectors.
    • The two 12 MP cameras—one wide-angle with Optical Image Stabilization (OIS), just like in the iPhone 7, the second a telephoto—allow for optical zoom.
    • Both cameras also sport a new image sensor that Apple claims is 60% faster and 30% more energy efficient than previous iPhones.
    • The upgraded cameras almost make it worth the bigger exterior camera bump—now built into the chassis in another suspected waterproofing/dust-fighting tactic.
    • We use our X-ray vision to initiate a staring contest with the camera array. Without blinking, we can see four metal pads around one camera. We're guessing these are the magnets that enable OIS.
    • Analog Devices AD5842 OIS driver
    Two sets of OIS?
    The telephoto lens has OIS?
    Not sure about that one
    jetlitheone - 返信
    Yes it indeed does
    yazdanbanaji - 返信
    Is there any chance anybody can take calipers to both lens assemblies and find us an actual height?
    evilspoonman - 返信
    I'm hoping it does but most rumors said no.
    maquinn1978 - 返信
    It really doesn't seem like it. Look at the voice coils. the smaller 56mm unit only has ones that are lined up to move the lenses back and forth for focusing. the 28mm one has magnets and coils that allow it to move from side to side and up and down for stabilization.
    garyliao2001 - 返信
    I agree with you. I don't think the telephoto has OIS.
    jetlitheone -
    Looking at the two camera assemblies it sure looks like the 56mm camera does NOT have OIS. This is consistent what reviewers with units have written so far.
    sam123 - 返信
    Also, are these sensors 6mm diagonal? (1/3-inch sensors)
    evilspoonman - 返信
    I think 1/2,6" the first one. EXIF data suggest tele sensor is 1/3,2"...
    maurizionatali -
    Doesn't look like it has OIS on the 56MM
    http://imgur.com/a/6lrPW
    max - 返信
    I believe those magnets you are indicating on the 28mm optical housing interact with the electromagnets on the face of the sensor assembly. The orange plate with wire traces on all four corners. I agree with your assessment that the 56mm lens is just a focusing voice coil and is not stabilized.
    evilspoonman -
    "the second a telephoto —allow for optical zoom" Really? Isn't it only for Focus?
    Masa - 返信
    One camera is a 28mm F1.8 with OIS and sensor, the other is a 56mm F2.8 normal lens with no OIS and it's own sensor, read, not telephoto that optically doubles ( 2x ) the magnification of the two cameras in use. I am not sure how it is dealt with when in between 1-2X but beyond 2x is "digital zoom" which is essentially cropping the native file of the longest lens. There is no real "telephoto" lens in the iPhone 7+, it is just marketing speak. However, the combination of a 28mm and a 56mm lens is not a weak addition to the already great iPhone camera platform. I plan on using it a lot and making a lot of great images with it when not using my professional gear, for my profession.
    dphotobayer - 返信
    what kind of sensor ? IMX????
    badnessboy83 - 返信
    I know it's Apple's term, but the non-wideangle camera is not, by any definition, "telephoto". It's actually a "standard" lens, roughly equivalent to a 55mm lens on a 35m camera.
    biowizard - 返信
    Technically it is a telephoto as are all phone lenses - telephoto means that the lens is shorter than its effective focal length whereas on slrs wide angle lenses have to be reverse telephoto to clear the mirror. It is a telephoto of normal focal length, like the pancake lenses fitted to a number of digital cameras.
    Martin Bacon -
    A telephoto lens has a focal length longer than that of the track length of the lens assembly. Apple is using the term correctly.
    mcm - 返信
    where is gyroscope sensor? and accelerometer? thanks
    hector - 返信
    I'd like to know what the camera module is, and what the pixel size is. In the announcement, they stated "bigger pixels" but never said how big.
    skydivertak - 返信
    Could you please tell us what the image sensor is? I'm hoping for IMX260 or IMX377, probably the two best smartphone chips on the market today; if the nominal rated size of the main chip is "1/2.6" at 12 MP, the closest match I'm aware of in the Exmor lineup would be the 260 given unless its something brand new, that's the closet match to the specs given (at ~1/2.5 and 12 MP), and Sony only makes a few 1/2.6 chips, none near 12 MP, as well as the 260 being the sensor used in the also dual camera V10. I can't see any obvious candidates for the second sensor; the only 1/3.2 sensors Sony has are the 8 MPs. And I don't see any discussion of the front sensor here, though perhaps I'm just missing it.
    CAM Gerlach - 返信
    Which is the maker of these sensors?
    Techno Golo - 返信
    What's the baseline between two camera?
    kaiyeh0913 - 返信
    Hello guys,
    Have you figured out who is the sensor manufacturer?
    Miguel Ferreira - 返信
    Smartphones even iPhones suffer from image noise during low light shooting. They use very small image sensors which can't gather enough light fast. So the software amplifies digitally the ISO creating image noise and deteriorating colors.
    I would prefer a bigger camera with a bigger image sensor with better image stabilization instead of two cameras. Ordinary users are impressed more from the two cameras and don't know the benefits of bigger image sensors.
    I think Sony should be the manufacturer, OIS is not available for the telephoto lens.
    gr8sujit - 返信
    The comments below this article indicate the telephoto lens does indeed have OIS. But the comments above my post say otherwise. What is the final conclusion? Does the iP7+ have OIS on all lenses/cameras?
    speedlever - 返信
    Can the camera glass be replaced?
    parshnib - 返信
    Would there be a way to turn off the hardware OIS by doing into the machine? Some people with stabilizing gimbals are finding the hardware OIS troublesome by causing jitters on video capture. Apple has not enabled a way to completely turn off hardware OIS.
    timdlr - 返信
    Any chance of being able to replace the camera glass? It's built into the chassis but looks like it could be removed and replaced.
    phnxdemon24 - 返信
    How do you troubleshoot the camera system when only the 2x camera will work? Replacing the camera didn’t effect the situation - still the same. Any suggestions?
    Rich Tefertiller - 返信
  11. iPhone 7 Plus Teardown: 手順 12、 2の画像 1 iPhone 7 Plus Teardown: 手順 12、 2の画像 2
    • Before we can dig the logic board out of the rear case, we have to remove portions of the antenna assembly—including the antenna flex cable, which acts as a bridge between antenna pathways.
    • With the antenna flex cable removed, we focus our attention on the top left Wi-Fi antenna.
    These both appear to be Squelch pads. The second image is the shielding cover over the second. The antenna is the upper case its self.
    Unlike the iPhone 6 series which had two antenna's in the top case this series shares the same antenna for both cellular and WiFi. Its possible they also have so attenuator logic here as well.
    Dan - 返信
    What's with all the tooling marks in the pink? I thought the back is supposed to be as beautiful as the front?
    Charles Reese - 返信
    I hope the the new iPhone 7 with smaller visible antennas will have the same sensitivity as previous models.
  12. iPhone 7 Plus Teardown: 手順 13、 2の画像 1 iPhone 7 Plus Teardown: 手順 13、 2の画像 2
    • Plucking the logic board from the 7 Plus is much easier than with its predecessor. There's no need to flip over the logic board to remove the final connections.
    • It may seem like a small victory, but we're still encouraged—even small design changes can make a difference in terms of repairability.
    • Peeling up the EMI stickers, we spy what might be some additional heat management.
    • Could that be the A10 under there?
    That EMI stickers are destroyed when are peeled off? Can they be reused with the same efficiency? Can they be replaced by better quality and more safe ones?
    You guys seem to have ignored the above comment. But really is the EMI sticker replaceable? If so where can we get it ?
    Thdnks
    Musa Bah - 返信
  13. iPhone 7 Plus Teardown: 手順 14、 1の画像 1
    • The shields are down! The logic board is clear and ready for inspection. Let's see what this puppy is packing!
    • Apple A10 Fusion APL1W24 SoC + Samsung 3 GB LPDDR4 RAM (as denoted by the markings K3RG4G40MM-YGCH)
    • Qualcomm MDM9645M LTE Cat. 12 Modem
    • Skyworks SKY78100-20 Power Amplifier Module
    • Avago AFEM-8065 Power Amplifier Module
    • Avago AFEM-8055 Power Amplifier Module
    • Universal Scientific Industrial O1 X4 (likely the M2800 "Trinity" SIP)
    • Bosch Sensortec BMP280 Barometric Pressure Sensor
    Anyway to tell if there are enough antennas support 4x4 MIMO?
    Nick Roosevelt - 返信
    The blue chip is bigger than the small one, so it can't be same.
    The blue one is an Avago AFEM-8055 Power Amplifier Module.
    Cheers,
    Sebastian Beyer - 返信
    Blue one should be 8055 from the picture?
    torlies - 返信
    What's the part at the right location of the blue avago chip?
    torlies - 返信
    The Qualcomm Snapdragon X12 LTE modem indeed does support 4x4 MIMO, 256-QAM downlink, 64-QAM uplink
    Source: https://www.qualcomm.com/products/snapdr...
    tuanchoang - 返信
    It supports 4X4 MIMO, but the physical antennas have to be installed by the manufacturer, in this case, Apple would have to be sure to include the antenna set. It is supposedly supported via software update, so it seems that might also depend on Apple.
    Nick Roosevelt - 返信
    The chip below the green one looks like a Murata one. It has its marker "M" with a circle.
    Jie Zou - 返信
    So Apple is advertising a 450 Mbps maximum downlink throughput (cat 9 or 10) but Qualcomm chipset (at least, no idea for intel LTE baseband used) is capable of Cat 12 , i.e up to 600 Mbps throughputs ? Maybe Apple is advertising 450 Mbps because only Qualcomm chipset support it ? Maybe it is firmware locked to ue cat 9 or 10 ?
    Basile Carle - 返信
    Looks like there is another chip hidden. Left side of A10chip, in between capacitors - try to xray or remove the material
    humanresourceac - 返信
    You mean the inductor coil?
    Dan -
    3 GBytes Ram on iPhone when the 4Gbyte Ram of new macbook are considered enough by Apple. This phone is a real beast. The one Gbyte of iPhone 6 plus isn't enough for multitasking with the new updates of apps. A really huge step forward. The gap between iPads and iPhone is closing.
    The Avago chips are really Broadcom chips. Avago announced its intention to acquire Broadcom in May 2015. The acquisition was completed in February 2016. Avago decided to exist under the Broadcom name, as it was more well known than the relatively new Avago (which formerly was part of Agilent, which itself was a spin-off from Hewlett-Packard).
    bobmcd50 - 返信
    It is not "MDM9645M". It is MDM9645.
    JJ Wu - 返信
    52RD.com is showing the Invensense 773C chip on the same board. http://img.mp.itc.cn/upload/20160919/734...
    Geeky1 - 返信
    Here is also a link to the translated article. http://www.microsofttranslator.com/bv.as...
    Geeky1 - 返信
    Very surprised that Ifixit would miss such an identifiable chip. Especially after having so much time to correct it. Could something foul be afoot with the politics in which they "teardown"?
    dseigel - 返信
    Can't say for certain. I just find it bizarre that no US teardown has identified this chip but several others internationally have.
    Geeky1 -
    what is inside "Universal Scientific Industrial O1 X4"? There are two similar parts on the main board.
    JJ Wu - 返信
    很有用的拆解!对于初学者有很大的帮助,谢谢!
    Ivan Xie - 返信
    i want to know what is the middle ic of ( green/yellow/blue/ )
    Under the Avago AFEM-8065 Power Amplifier Module ic
    what ic is that ..i want to replace that ic .. coz i have buy a iphone 7 plus with 3g 4g issue ..and someone remove that ic from the m.board ..plzzz help me to find that ic..thanks
    kasun ruwanga - 返信
    There are 2 antenna connector at the bottom of the front logic board. Can someone ID what are the two for? One plug into a signal cable from the loud speakers and the other came from the thin film lightning connector assembly. Why the loud speaker have a signal/antenna cable?
    tandylan - 返信
  14. iPhone 7 Plus Teardown: 手順 15、 1の画像 1
    • Round the back now: another field of ICs!
    • Toshiba THGBX6T0T8LLFXF 128 GB NAND Flash
    • Murata 339S00199 Wi-Fi/Bluetooth Module
    • NXP PN67V NFC Controller
    • Dialog 338S00225 Power Management IC
    • Qualcomm PMD9645 Power Management IC
    • Qualcomm WTR4905 Multimode LTE Transceiver
    • Qualcomm WTR3925 RF Transceiver
    Which SKU of iphone7+ are you tearing down? Does it support CDMA?
    sameer vora - 返信
    The wifi module is done by Murata again. And it seems to provide another chip above the blue one?
    BTW where is the motion sensor, i.e., the accelometer and gyro?
    Jie Zou - 返信
    Sameer Vora - There is only one. The iPhone has been CDMA+GSM since the "World Phone" of the iPhone 4S
    Steven Gergus - 返信
    Not true - The 7 now has 4 part numbers: 2 for the CDMA (7 & 7+) and 2 for the GSM (7 & 7+) . IIRC - the GSM only models have Intel Modems - but no CDMA support.
    Nikon1 - 返信
    TLC again! Is it a 3D NAND?
    Yifan - 返信
    How is the Bluetooth antenna compared to the one on the 6S Plus? Bluetooth performance is particularly important for me since I've invested in wireless earbuds with a weak RX. 6S Plus works fine but there's always room for improvement.
    nametemp - 返信
    Has anyone noticed the lack of an envelope tracker on the Qualcomm version of the iPhone 7??
    Anshel Sag - 返信
    Of course there isn't place for an FM analog radio receiver. I will die and iPhones will still snob the traditional free analog radio. Mobile carriers love people paying for listening radio during commuting. Apple doesn't even produce an adapter for radio. One of the few topics that android phones are betters.
    The model is A1785 according to the first post. This means this is the Japan model. If what I hear is correct, this means that the chips in this model are different than those around the world. This has to do with the FeliCa chip that Apple said would be available in "iPhones sold in Japan." What I would like to know is what a teardown of a non-Japanese iphone 7 has in terms of NFC chips. I wonder because there would be a difference of "We only advertise FeliCa in Japan (but the hardware is there)" as opposed to "We only include the hardware for FeliCa in the Japanese SKUs, A1779 (iphone 7) or A1785 (iPhone 7 Plus)." As someone who travels to Japan (and has Suica/FeliCa cards), this would be useful to know.
    Charles Rosenberg - 返信
  15. iPhone 7 Plus Teardown: 手順 16、 1の画像 1
    • But wait, there are even more ICs on the back!
    • Apple/Cirrus Logic 338S00105 Audio Codec
    • Cirrus Logic 338S00220 Audio Amplifier(x2)
    • Lattice Semiconductor iCE5LP4K iCE FPGA
    • Skyworks SKY13702-20 Diversity Receive Module
    • Skyworks SKY13703-21 Diversity Receive Module
    • Avago LFI630 183439
    • NXP Semiconductor CBTL1610A3 Display Port Multiplexer (likely)
    it should be lattice iCE5LP4K . what is the purpose for this ? any advantage with it ?
    william0312 - 返信
    Thanks for the Audio Codec and Amplifier info!!
    Barry Wilson - 返信
    As usual Apple exept the panel of iPhone, purchases everything from third suppliers.
  16. iPhone 7 Plus Teardown: 手順 17、 2の画像 1 iPhone 7 Plus Teardown: 手順 17、 2の画像 2
    • Just a few last ICs on the back of the logic board:
    • TDK EPCOS D5315 Antenna Switch Module (likely)
    • Texas Instruments SN2400AB0 Battery Charger IC (likely)
    • Texas Instruments TPS65730A0P Power Management IC
    • Texas Instruments LM3539 Backlight Drivers
    • Texas Instruments SN61280 Power Management
    • ON Semiconductor DC-DC Converter (likely)
    • And as always, thanks to our silicon experts at Chipworks for helping identify the key ICs at play! Head over to their teardown page for an in-depth analysis of the iPhone 7 control hardware.
    Is there any dimension numbers?
    Hmil2017 - 返信
  17. iPhone 7 Plus Teardown: 手順 18、 3の画像 1 iPhone 7 Plus Teardown: 手順 18、 3の画像 2 iPhone 7 Plus Teardown: 手順 18、 3の画像 3
    • Raising the roof loudspeaker out of the phone, we find some nice spring contacts and some mesh with ingress-protection!
    • Sharing design similarities with the speakers in the 6 Plus and 6S Plus, the speaker in the 7 Plus also bears a familiar antenna appendage.
    If the lightning port is not smooth with the body the phone will fail when submerged in water?
    Bubs - 返信
  18. iPhone 7 Plus Teardown: 手順 19、 3の画像 1 iPhone 7 Plus Teardown: 手順 19、 3の画像 2 iPhone 7 Plus Teardown: 手順 19、 3の画像 3
    • Tiny ribbon cables attach the Lightning connector assembly to the microphones, which are firmly adhered to the speaker grilles.
    • As predicted, the speaker grilles have ingress protection to keep the internals nice and dry.
    • And in case you haven't noticed, this Lightning connector assembly is huge! Like previous generations, it is moderately adhered and readily removed from the rear case.
    • This cable assembly also features the most substantial gasketing we've seen on a Lightning connector. While last year's models used foam adhesive to keep out water and dust, this one features a full-on rubber gasket, capable of holding back a 50 meter column of water.
    I think the 50m water resistance is apple watch 2's feature, not iphone 7's.
    ruoungon - 返信
    QUOTE: "capable of holding back a 50 meter column of water"
    Really?! I thought the iPhone 7 models were IP67 - meaning they should withstand ingress from 1m of water for 30 minutes
    biowizard - 返信
    I think I found the baro sensor, it's underneath the lower left mic, sharing the same port.
    Tom Chai - 返信
    The gasket itself perhaps can hold back a 50m column of water.
    Rick Bargerhuff - 返信
    Me thinks steps 18 & 19 got swapped
    coodie - 返信
    Whoops! Fixed, thanks!
    Andrew Optimus Goldheart -
  19. iPhone 7 Plus Teardown: 手順 20、 3の画像 1 iPhone 7 Plus Teardown: 手順 20、 3の画像 2 iPhone 7 Plus Teardown: 手順 20、 3の画像 3
    • Water resistance has been touted as a big new feature in the iPhone 7 Plus—but what actually makes it water resistant? The evidence is everywhere:
    • Figures 1 and 2: a plastic SIM eject plug with a rubber gasket.
    • Figure 3: a rubber gasket on the SIM tray.
    • Rubber gaskets and plugs aren't new technology, but they are effective at keeping liquids and dust out of your phone. But there's a cost—when you replace a component you'll need to make sure you get the gasket in place and that it creates a good seal, which tends to be an extra, finicky step.
  20. iPhone 7 Plus Teardown: 手順 21、 1の画像 1
    • Pausing our rear case excavation, we take a moment to examine the display assembly and its respective bits.
    • From the front face, it looks identical to the 1920-by-1080 displays we've popped off the iPhones 6 and 6s, but there are some notable changes: This guy supports a wider P3 color gamut than its older siblings, and is 25% brighter.
    • We also notice a water damage indicator hanging out on the left edge of the display EMI shield. This gadget may be water resistant, but it looks like Apple won't be on the hook when you take your phone for a swim.
  21. iPhone 7 Plus Teardown: 手順 22、 3の画像 1 iPhone 7 Plus Teardown: 手順 22、 3の画像 2 iPhone 7 Plus Teardown: 手順 22、 3の画像 3
    • After we free a few standard Phillips screws, the earpiece speaker practically falls out from under the front-facing camera.
    • This new earpiece speaker does double duty—for the first time, it also serves as a loudspeaker, giving the iPhone stereo sound for those times when you need to rock out and you might not have any place to plug in your headphones.
    • The front-facing camera cable assembly is a little more of a handful. Normally when we're served something this tangled up, it comes with meatballs.
    • All told, the upper components number:
    • Front-facing camera
    • MEMS Microphone
    • Stereo-enabling speaker
    • Proximity sensor and ambient light sensor
  22. iPhone 7 Plus Teardown: 手順 23、 3の画像 1 iPhone 7 Plus Teardown: 手順 23、 3の画像 2 iPhone 7 Plus Teardown: 手順 23、 3の画像 3
    • More tri-point screws secure the home button and LCD shield plate.
    • But luckily, there's no adhesive on the LCD shield plate—and the cables are nicely managed.
    • There's not much to see here, so we quickly remove the shield plate and head for home, i.e. the home button.
    Has the possibility to swap the flat button extender home like the iphone 6s
    atlantisgfx - 返信
    为什么中国的iPhone7 LCD屏盖板上有粘合剂?把屏幕排线和盖板粘在了一起
    FlyingPig - 返信
  23. iPhone 7 Plus Teardown: 手順 24、 3の画像 1 iPhone 7 Plus Teardown: 手順 24、 3の画像 2 iPhone 7 Plus Teardown: 手順 24、 3の画像 3
    • Last to leave the display assembly: the home button.
    • It's more like the home touch sensor really. No buttons about it.
    • Analog Devices AD7149 Capacitance Sensor Controller
    • For those of you waiting with bated breath, it appears that the new solid state home button is removable. It won't be a simple procedure, with tiny tri-points and light adhesive on the cable—but there is no longer a delicate gasket to replace. Overall, it is a step in the right direction.
    • A replaceable home button is great news for consumers. The mechanical home button has been a point of failure on past iPhones. While our data shows that the reliability of the home button is better in the 6 and 6s compared to the 5 and 5s, we’ve still had close to 100,000 people use our iPhone 6 home button repair procedure.
    • Additionally, the move to a non-mechanical button should improve overall reliability and reduce the need for replacement. Not to mention, it looks great under an X-ray.
    How is the home button waterproofed? It looks like it just sits on top of the glass but that can't be right...
    Steven Gergus - 返信
    The home button acts like a plug, with wedged sides pressing on the screen from above. The screw actually pulls the button in to seal tightly.
    Tom Chai -
    If it doesn't 'move' for normal operation, why is the home button removable? I'm anxious to feel these in action.
    lwwells - 返信
    The home button still implements the touch ID circuitry so it needs to be removable in order to replace.
    Rick Bargerhuff -
    If I recall, not everyone can replace the home button on the previous iPhone because there was a chip on the cable that has some data that's tied to the specific motherboard (apple citing that it was a security feature). Only a reprogram at Apple can "pair" a new home button to a phone. I wonder if this is like that? But without any moving parts, it's a lot more reliable of course.
    Ryo Saeba - 返信
    Yes the home button needs to be paired so after replacing my screen and new home button. It doesn’t work. And it’s $399 for apple to fix it without Apple care
    Daniel L - 返信
  24. iPhone 7 Plus Teardown: 手順 25、 2の画像 1 iPhone 7 Plus Teardown: 手順 25、 2の画像 2
  25. iPhone 7 Plus Teardown: 手順 26、 2の画像 1 iPhone 7 Plus Teardown: 手順 26、 2の画像 2
    • The grand finale! With the iPhone 7 Plus torn to bits, we line up our prizes for inspection.
    • But not for long—we have another cutting edge gadget from Cupertino coming your way soon. Stay tuned for more!
    • Special thanks to our friends at Nikkei for lending us their office space in Tokyo to do what we do best!
    Did/could you guys put the phone back together into working order. Did ya fix it?!
    fullard108 - 返信
  26. まとめ
    • The battery is straightforward to access. Removing it requires specialty screwdrivers and knowledge of the adhesive removal technique, but is not difficult.
    • The solid state home button eliminates a common point of failure.
    • Improved water and dust protection greatly reduces the need for repairs associated with environmental damage and accidental spills (but also makes some repairs more difficult).
    • The display assembly continues to be the first component out, simplifying screen repairs, but the procedure has grown more complicated with improved waterproofing measures.
    • With the addition of tri-point screws, many iPhone 7 Plus repairs will require up to four different types of drivers.
    リペアビリティのスコア
    7
    10点中7点のリペアビリティ
    (10点が最も修理しやすい指標です)
153 件のコメント
%#*@ i was so eagerly waiting for this ! I'm like ifixit hasn't uploaded the first set of teardown and here we go
yazdanbanaji - 返信
Me too! Love their work.
Colin Baines -
Has anyone tried to remove the home "button" yet? Worried about being able to transfer touch id to replacement screens......
rneeley - 返信
I think the home button is still transferrable to replacement screen based on the screws right under its plate, it should have a small connector to the LCD assembly itself.
iTechshark MO -
That it what I am hoping based on the video that came out Wednesday, but then they did not remove it. I own a repair shop, I am sitting on the edge of my seat here ;)
rneeley -
Same thing here lol
iTechshark MO -
Somebody in China beat ifixit to it and did a full teardown. The home button is transferable.
Tom Chai -
Tom - Do you have a link?
rneeley -
Re Home "button" replacement. I was under the impression a new "button" still needs to be calibrated to recognize all previous finger prints. I am not completely positive this is still the case. (?)
jchagman -
If you save your original home button and swap it to the new screen before you close it up, it is still paired to the motherboard. Sometimes the Touch ID won’t work but it’s hit or miss.
Daniel L -
Are you going to teardown model A1784 to see if it does indeed have an Intel modem?
andrewdavidharvey - 返信
It's all about the modem here. Big thing is for me: if Qualcamm, what model, X12? How many antennas, 4x4?
Nick Roosevelt -
Yes, its Qualcomm LTE Cat 12 modem which is capable of 650Mbps downlink speed. But stupid Apple folks have restricted it to 450 Mbps to match with inferior Intel modem on some models. Intel is Cat 10 modem capable of max 450Mbps
shreyassv123 -
I'd be interested to know if iPhone 7 not sold in Japan contains "FeliCa Type-F NFC contactless technology,"
http://www.apple.com/newsroom/2016/09/ap...
msulistio - 返信
I second this! Look forward to maybe hearing from you guys.
Sam Lewis -
The same NXP 67V04 chip is installed also in the AT&T model.
http://www.chipworks.com/about-chipworks...
koyama -
what is the difference of this iPhone compared to the one they sell in USA?
george allo -
It appears the Home button is screwed in. The LCD shield looks like it will be fun to remove since the display cable is now in the middle left of it instead of at the top.
Kevin Stuckey - 返信
I am zooming in trying to find a cable, so far I can't find one coming off the button. I know the folks at iFixit have to take their time and do a complete teardown (and upload and type out info), I just wish they would skip ahead a little ;) - We all know the logic board will come out ;)
rneeley -
Thats pretty much same layout of LCD/Digitizer in iPad Air located on the lower right side with the addition of another flex for front facing cam on iPhone 7 series.
iTechshark MO -
The cable might be routed under the LCD back plate and thats what I am hoping, Apple will be insane having the home button built in the LCD assembly, maybe next year but not that year lol
iTechshark MO -
Ya, It does have a resemblance to the iPad Mini 4 too (oddly enough did two of those this week, of four total I have seen). We should all know very soon hopefully. We all know the fruit company would like to kill all the small repairs shops off and force people to their stores, but then again I am in a fairly large city with no store for 2.5 hours in any direction...
rneeley -
Will this iPhone have USB 3.0, like the iPad Pro?! Haha.
hyperintel13 - 返信
no, Lightning port on iPhone 7 does not have pins on both sides like iPad Pro 12.9" https://twitter.com/ingulsrud/status/776...
joel -
The flex cable appears to go off on the right of the Home button and there seems to be an extension cable that connects to it near the rightmost screw. You can see a small bubble in the cable between the LCD shield and Home button shield??.
Kevin Stuckey - 返信
You are right, thats what I was saying a minute ago.
iTechshark MO -
Also I am kinda feeling that the home button/touch ID will be easier to transfer than previous model with no adhesive, it seems its just a plate screwed in the button.
iTechshark MO -
Also if you look at the photo closely, there is a flex on the right side of the home button ( its on the left side on the 6 /6S series ) so I am kinda positive that the home button/touch ID is transferrable based on a close up of the photo with a zoom in the right side of the home button.
iTechshark MO - 返信
I agree with you!
Kevin Stuckey -
OK, I see what your talking about. Their is also a little hump on the right that is probably the connection point. Looking at the screw in the center of the button, maybe it comes out the front like the track-pad on a macbook. That shield should be lots of fun, I am betting the LCD flex is glued over.
rneeley -
Yup that sounds right except that the screw is just sitting to hold the button on place and not to adjust its tactile feedback since its not mechanical.
iTechshark MO -
"Two separate sensors, two lenses, and two sets of optical image stabilizers." So OIS on both lenses/sensors?
Holger - 返信
Yes indeed ! You got the right mate ! Despite people's claims on the telephoto lens not having the OiS it's crystal clear from this teardown that it indeed does have one
yazdanbanaji -
Based on Apple , its just one mechanical OIS and the second one is just software controlled so its just one OIS as far as I can tell.
iTechshark MO -
No I don't think so, the electromagnetic coils of the 56mm unit only move the lens back and forth for focusing. The 28mm unit you can clearly see the coils and the magnets that allow it to move side to side.
garyliao2001 -
You are right, didn't notice the coils at all.
iTechshark MO -
I can confirm that the touch ID/home button is screwed in a plate with 3 screws to pull it off and the button itself is screwed to the middle of the shield with one , cheers guys, its gonna be transferrable :)
iTechshark MO - 返信
Good! Now I can sleep soundly tonight knowing I still have a job for the next year :)
Kevin Stuckey -
We all have businesses for another year then Ed :) -- Can not wait to see the pictures, and especially do my own teardown (I am on the east cost of the US, so I have 8-9 hours to wait on Fedex still.)
rneeley -
Haha you are %#*@ right, one more year in repair business lol
iTechshark MO -
Not like many of us get much Samsung business anymore... Most of my customers faint or hang up when I tell them how much to fix an S7 Edge screen... Looking into the freezing technique, but not eager to spend a could grand on a maybe....
rneeley -
Awesome job ifixit. $&@".?
Alber Einsten - 返信
You are always so professional
Dorothy - 返信
Great work!! Can't wait to see the speaker on the top !
Barry Wilson - 返信
Please do provide a detailed review of the new NFC chip that features FeliCa technology exclusively for the Japanese model A1784.
Thanks!
AKari Kamigishi - 返信
Please also tear down the 3.5mm to lightning cable to determine what type of DAC it uses
Pasko - 返信
Yes, please do this someone!
Dan Parsons -
And the earphones ~~ DD
Henryplusone -
Are we sure this uses a DAC and the lightning port isn't just capable of outputting an analog signal?
lwwells -
Indeed I am also dying to know what the DAC situation is!
Foo Bar -
I've had one of these adapters since Thursday -- if I had know it was going to take this long, I would have just torn mine down and published the results on my own blog! The reveal of the third amp is a serious indicator Apple has modified its MFi specs, and now allows analogue output from Lightning. That's a HUGE deal.
Mac 128 -
Yes also very keen to find this info out. Chop-chop ifixit (literally)!
shrike8 -
I'd like to see the SIM tray portion that this mechanism is how to achieve water resistance IPx7.
ao11oaray - 返信
Nice teardown!
How about gyro?
STM or Invensense?
john smith - 返信
I am guessing the rectangular chip besides those front-end modules in step 14 is the gyro/accelometer. It becomes such a weird shape because Apple wants both a low-energy 3-axis and an accurate 6-axis in one module. If my theory is right, the marker on that chip hints STM.
Jie Zou -
It is the latest INVN chip
Someone who knows -
Hey someone who knows why are you so sure? In the 6 there were two separate gyros, a Bosch 3-axis and an Invensense 6-axis: http://www.chipworks.com/about-chipworks... Is this a new part (combo 3 and 6-axis)?
John -
It is 6-axis Invensense and yes, I am very sure for reasons not related to this article.
Someone who knows -
7 and 7 plus accelerometer response is different ,so wonder if 7 still use Bosch acce like iphone 6.
john smith -
It appears to be an invensense chip. You can see it on the Chinese version... http://www.microsofttranslator.com/bv.as...
Geeky1 -
Since the other link is now dead here is another! https://translate.google.com/translate?h...
Geeky1 -
So what is reparability score ?
Fahad Muneeb - 返信
Would like to see what's going on inside the 3.5mm adapter.
Paul Weston - 返信
+1! And there are chips in earphones, too. Crack it!~ DD
Henryplusone -
What is the model number of this phone ?
Sathish S - 返信
skemhey -
Apple A10 Fusion APL1W24 SoC - made by TSMC or Samsung?
Lets teardown A1784..
skemhey - 返信
100% made in TSMC. That is old news.
Jie Zou -
Wow, amazing. The battery is the same of 6 Plus.
Marco Tini - 返信
I wonder, if I teardown and reassemble again will it be water resistant after re-assembly? as I can see there were some glue while opening the phone.
dhanesh shastri - 返信
Who supplied the gyroscope and accelometer? Traditionally it is near those front-end modules.
Jie Zou - 返信
Any changes to the proximity sensor and front camera?
tohff7 - 返信
%#*@! this is beautiful!
Satyajeet Vishwakarma - 返信
You complimented them.
ayushiagrawal42 -
Are you sure home bouton is transferable : supplier in china send me some photo and it s appear the home home flex is laser soldered on the metal frame
sylvainA FR - 返信
skemhey - 返信
How does Apple get stereo from only one speaker? Or does the photo of the speaker in step 19 show a divider in the middle that "separates" two small speakers? If so, how does one call this "stereo" when the two speakers are so close together? And why do the diagrams on Apple's website show lines pointing to the two grilles on the bottom of the phone, with the legend describing them as "Stereo speakers", when the iFixit teardown shows that the left-hand grille doesn't actually have a speaker behind it, contrary to Apple's diagram? And why do some of Apple's own diagrams point to a supposed second speaker towards the top of the phone, though the iFixit teardown found no such speaker there?
johnsawyercjs - 返信
The receiver speaker - that is, the speaker you hold up to your ear when you make a phone call, is the "second speaker" they're using for stereo sound now.
Dan Parsons -
Thanks. It took me a while to figure that out.
So it seems that the second speaker is a beefier version of the ear speaker at the top of the phone, shown above the display in step 5. If so, since this speaker is front-facing, and the speaker at the bottom is downward/side-facing, this might not give a normal stereo image, but it has the advantage of delivering sound along two planes instead of one, so that whether you're facing the front of the phone or its lower end, you'll still have one speaker pointed towards you, which should deliver better clarity than having neither speaker pointed towards you. Of course, if you have the phone sitting on a table and you're facing one of the two sides or the top end of the phone, you won't have a speaker pointed towards you, but you'll still have the front-facing speaker emitting sound up and out, and sound reflecting upward off the table from the bottom-facing speaker, so there will still be good diffusion of sound, and some stereo separation.
johnsawyercjs -
Looks like iPhone 7 Plus has Qualcomm Modem on both CDMA and non CDMA versions !!
shreyassv123 - 返信
But where is the screen teardown??
edenadinar - 返信
It seems more modular than 6s and earlier. Are there more easily replaceable parts?
John Gough - 返信
Unanswered question, what model, if any, uses Intel Modem.
Is there really a specific NFC-F ( Felica ) hardware or is it all software?
K Sec - 返信
Any thoughts about "BENDGATE" - as this phone is lighter than last year's model, will it be bendy, like the original 6-plus? Or pretty rigid, like the 6S-plus? What type of aluminium have they used this year?
biowizard - 返信
It's extremely rigid.
max damage -
Anybody know who makes the 'Proximity sensor and ambient light sensor' shown in step 21?
PrettyFlyWiFi - 返信
What about the 3.5mm adapter? Does it contain a dac?
George Papamichail - 返信
can you measure the different dimensions of the two camera sensors?
simonesala - 返信
This Looks like much easier display-replacement - right?
Naderio LP - 返信
Tear down the adapter please! Dac and amp info needed!
John - 返信
Repairability: Madness
Ivan - 返信
So Felica is available for all iPhone models. I wonder if tourists can use Felica in Japan?
Staubchen - 返信
iFixit! Where can we get hi-res images of these?
mooo - 返信
IPhone 7
Audio ICs
The iPhone 7 still uses the same Apple/Cirrus Logic 338S00105 Audio Codec as in the iPhone 6S, but the Audio Amplifier has changed to the new 338S00220. (previously 338S1285).
We found not just 2 but 3 Audio Amplifiers - we speculate there is one audio amplifier for for each of the two speakers, and the third amplifier is for the headphone via the Lightning port.
The third Audio amplifier is situated next to the Applications Processor Module with 3 black blobs on it. It was discovered during de-soldering of the A10 applications processor. When the blob was scraped off, it was an ‘oh wow, there are 3 audio amps!’ kind of discovery. Chipworks has a Basic Functional Analysis Report of the Apple/Cirrus Logic 338S1285.
Note******** ifixit teardown report only lists 2 audio amps ....Chipworks discovered the third amp
https://www.chipworks.com/about-chipwork...
marty - 返信
Could you measure the dimensions of the A10 Fusion chip? That would be very useful calculation die size! Also, high-res photo's of the A10 would be much appreciated :)
Ewout - 返信
anyone knows something about light and proximity sensors?
Gianluca Bertuzzo - 返信
which ram is right for 7plus ?2gb?3gb?
wei wang - 返信
Wow you guys are like display mate for tearing down phones.
rafaelbreban - 返信
"Hopefully Apple didn't remove anything important." haha
Dylan - 返信
Will you guys tear down the 3.5mm adapter?
rafaelgil2006 - 返信
Does anybody know if the 7 plus is using saphire glass? Or is it (like it was shown in a video earlier on the regular 7) only using Gorilla Glass.
han - 返信
You missed a third audio amplifier. Directly above the "A" in "A10" on the processor, there is a chip with 3 black blobs on it. It's the amplifier for the lightning port to headphone adapter.
spaceywilly - 返信
Yes, that third amp is a significant discovery implying a major change to Apple's MFi specs. In which case its a huge reversal of position, and will lead to a flood of cheap analogue audio products previously not possible, not to mention significant confusion as to just exactly what a "Lightning" equipped product means. My adapter didn't work on my SE until I updated to iOS 10. That shouldn't have been necessary as Apple already has published Lightning audio specs -- unless they changed something significant. So suddenly its not an inexpensive digital adapter with a DAC and amp, its a very expensive port connector changer.
Mac 128 -
Great job! Very interesting and informative! Like your lite hearted easy to read writing!
orion2000 - 返信
Nice teardown.... Looks like we have most of the tools available @RadioShack. Ah tri-wings... just like the McDonalds toys.
Radio Shack SLO - 返信
Can somebody help crack my iPhone 6S encryption?? I forgot my passcode and only 2 more attempts before lock out.
hdtv720p - 返信
what is the difference on the 1784 model?
I see everyone asking for a teardown. Is it better than the rest of them?
george allo - 返信
Any idea what the part is between the RF front-end (between the Skyworks part and Avago PAMs)?
Harold - 返信
The stereo speakers function in such a way, that if you do watch a video on your phone or if you tilt your phone sideways, there will be a left and right speaker, both working to create a stereo sound. Most people do use their iPhone sideways to view videos, so this will certainly be noticeable to them.
Jose Toscano - 返信
I'd love to see a review of this. I can't imagine how they are going to make two different speakers sound the same, much less where one faces the listener, and the other points of to the side.
Mac 128 -
What about reassembly? It looks like a lot of the waterproofing is either a) lost, or b) significantly disturbed from the teardown. With reassembly, do we have to completely remove the waterproofing and reapply? If not, does it go back together imperfectly, due to gobs of the waterproofing building up during disassembly?
I wonder if you couldn't spray the entire internals with waterproofing, after the fact? It would make future mods/repairs basically impossible, but would improve/restore the initial waterproofing.
To all the rocket surgeons and techies out there, what're your thoughts?
bsquirdoff - 返信
Can anyone explain why Apple keeps changing their screw heads? I'm genuinely curious to know how this is better than torx or pentalobe.
Ivy Wlrs - 返信
The homebutton is almost the same venkat from harithatech.com
venkatramt - 返信
I was wondering if phones get taken apart for repairability grading, do any of these phones get put back together? :)
Peter Shen - 返信
How about the flash lights? They claimed to be 4 LEDs.
WPG - 返信
why 4 different types of drivers? star for the bottom two screws, tri point for the new type and the obvious normal screw?
Krayzee - 返信
Hello there ,
I have a question , what size are the tri-points screws (Y000, 1 or 2)??
because i have the classic Pro tech toolkit and i just want to make sure if i have the right tools or not!
Thank you guys
Ibrahim - 返信
Did you specify the IMU package?
Is this the new IPS LCD panel from JDI? I have read it uses the second generation Low Temperature Polysilicon backplanes, which in another article fueled a rumor that a higher resolution panel was going to used due to the power savings.
Is the lightening port data throughput the same as the previous iPhone 6s Plus, or the updated standard used in the iPad Pro?
Have you confirmed that there is analog audio available now from the lightning port?
Michael Balzer - 返信
How about the flash lights? They claimed to be 4 LEDs. http://txlcd.com
txlcdsupplier - 返信
I have a question. Did Apple use any technology from printed electronics, like silver ink, in the latest iPhone?
lol - 返信
If history is any guide as ALL Apple products have InvenSense gyros then we will see an integrated single 6 Axis from InvenSense. The Apple Watch must use a single 6 axis for everything to reduce power.
The only question is did Apple use InveSense GPS navigation Software?
Apple obviously has reduced GPS run time and rides the 6 Axis to reduce power consumption by up to 80% off time. This is what InveSense software specializes in and it has to be in the iWatch.
Will Apple do their own dead reconning algorithms or use InveSense SW?
KrisCo - 返信
I found a write up on a Chinese site that shows the Invensense Chip. http://www.microsofttranslator.com/bv.as...
Also here is a pic of its location: http://img.mp.itc.cn/upload/20160919/734...
Geeky1 -
Can anyone confirm if the camera lens cover and Home button are still sapphire? A few people have said, well, that they aren't.
Chris Brighton - 返信
Can a 6+ or 7+ battery suitable on a 6s+
shrini23 - 返信
Porque vocês não me dar um iphone, ao invés de quebrar-lo
fabinhod500 - 返信
Porquê vocês não me dar um iphone ao invés de quebrar-lo
fabinhod500 - 返信
I never understand why it takes so long for folks to figure out the accelerometers / gyros... It's nice to see that others have already identified the InvenSense 773C but I wish iFixit had figured it out first. Is this a living document? Will additional chips and information be added as the rest of the world figures it out? Regardless, great teardown guys! Thank you for doing this year after year!
Bob Powers - 返信
It would be interesting to know who makes the microphone(s). That's a small but important piece that few ever take much notice of.
Bob Powers - 返信
Is the camera sensor same as on 6s plus? I'm asking about the pixel and resolution. Not just the 12 megapixel total resolution. I know there is a new image processor. That's not the question. I want to know if this new sensor resolves for a better image quality than the iPhone 6 s plus. Practically speaking, is it (the 7 plus camera image sensor) a better film? Better pixels? Knowing the optics are improved for better optical resolution.
gwwakim - 返信
Compared a 7+ Jet Black to and 7+ Black and find the lightning connector is not flush on the Jet Black. Has a sharp edge protruding past the phones surface. Is this normal?
Bubs - 返信
If your lightning port is not flush it is not IP67?
Bubs - 返信
Does anyone know if there is any place that sells the parts of the IPhone 7 plus? I am a new repairer so I want to know where I can find these parts and also the screws and screwdrivers that were used to assemble this. I tried searching this online but most online shops have only iPhone 6s plus parts at the most.
Thanks!!!
Gypsum Chen - 返信
iPhone 7 and now Google Pixel...which smartphone is best for us?
Just purchased the iphone 7 recently from wantITbuyIT and now im waiting for google pixel. The battery life is good unless you are doing something that involves a lot of processing power.
Jenny Jonson - 返信
More importantly did apple FIX the problem that causes Touch Disease in the iphone 6Plus and 6sPlus? you guys never took close photos of the chips to show if they had the epoxy potting that they should have.
timgray1 - 返信
A question: the power button has the rubber around or something for the waterproofing, like the sim tray?
Michele - 返信
There are indeed gaskets in the buttons, you can see them in the iPhone 7 teardown!
Sam Goldheart -
感谢你们翻译成中文来点视频
Gaonan - 返信
Does anyone know what series of aluminum the iPhone 7 plus uses? Thanks.
Albert B. Lopez - 返信
after replacing the touch pad of the 7plus the gps seems to jump around when on google map?
Riaan - 返信
I want to know the place of ic Audio plz !?
s12.s13 - 返信
Where is the GPS in the I phone seven
Robert Graves - 返信
I was replacing an iPhone 7 Plus screen and when I opened the phone up all the screws looked stripped. So I had to figure out any which way to get the screws out. I did and then I replaced the screen. The magnetic cover that covers the phone’s battery/ and screen connectors bent a little. And I noticed that the silver screw female end that is supposed to be attached to the logic board wasn’t on the logic board it was attached to the cover would this cause the phone not to turn on?
Devin Jordan - 返信
My iphone 7 plus screen recently broke and I’ve been told that the IC chip needs to be replaced. The phone won’t turn on. Will this affect the data (photos) stored on the phone?
Karishma Ahuja - 返信
a cosa servono i 2 cavi coassiali ? quello dello speacker e quello de gruppo lightning?
thunderinparadise - 返信
Translation: What are the 2 coaxial cables for? That of the speaker and that of the lightning group?
Dan -
Can y’all post how to fix a iPhone 7+ battery
Trap Sol0 - 返信
My iPhone keep turn off without stopping
Vanessa Adjessa - 返信
Best to create a question here Answers
Dan -
コメントを追加
統計データ:
過去 24時間: 37
過去 7 日: 280
過去 30 日: 1,187
今までの合計 996,122
