必要な工具と部品
Apply a heated iOpener all around the edge of the screen to loosen the adhesive under the display.
Lift the display with a suction cup and insert a thin object to separate the screen from the frame.
Slide the fine object along the entire edge to cut the adhesive.
Raise the display.
Remove the 6 Phillips # 00 screws.
With a spudger or with your fingernails, lift the two connectors.
Lift the connector underneath.
Disconnect the display connector.
Raise the display.
Unscrew the 4 Phillips # 00 screws.
With a spudger or fingernails disconnect the two rear camera connectors.
Remove the rear camera.
With a spudger or fingernails to disconnect the three connectors that connect the front camera.
Remove the front camera.
With a spudger or fingernails disconnect the battery holder connector.
Unscrew the 3 Phillips # 00 screws.
Remove the battery holder.
With a spudger or fingernails disconnect the rear camera flash connector.
Unscrew the 2 Phillips # 00 screws.
Remove the rear camera flash.
Unscrew the 2 screw holders with the suitable screwdriver.
With a spudger or fingernails to disconnect the SIM card holder connector.
Remove the SIM card holder.
Remove the 2 Phillips # 00 screws.
With a spudger or fingernails disconnect the 3 battery connectors.
Unscrew the screw holder with a standoff screwdriver for iphone.
Remove the film with a spudger.
Remove the logic board.
Remove the 2 screw holders with a standoff screwdriver for iphone
Remove the taptic engine connector with a spudger or fingernail.
Remove the taptic engine.
Unscrew 6 Phillips # 00 screws.
Remove the 4 screw holders with an iPhone standoff screwdriver.
Remove the charging port.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
4 件のコメント
I don't see any mentioning of the microphone, Is the Microphone an integral part of the charging port harnes?
This guide is missing A LOT of steps
This is definitely not a US iPhone 12! e careful as the antenna can tear easily and potentially ruin a motherboard.
