はじめに
Xiaomi Mi Mix 2 is easy to repair. If you got your Mi Mix 2 broken by accident, you can repair it by yourself. This video show you how to disassemble Mi Mix 2 step by step.
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 11,129
3 件のコメント
I wish this guide was step by step.
BootlegScarce - 返信
can I replace the battery without first removing the motherboard?
Danny Di clemente - 返信
I would like to recommend not to disconnect the signal cables unless it is absolutely necessary . The screen can be replaced whithout disconnecting them. I learned it the hard way ,once two connector broke ,one on the mainboard and another on the cable, I had to remove them and solder the cable directly to the mainboard
Albert Teix - 返信
