メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのXboxを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Xbox Teardown, Taking of the Top: 手順 1、 1の画像 1
    • Flip over the Xbox to where it shows the bar codes. Take of the black grips. Also scratch around where it has the stickers to find the screws there are a total of six, 2 of the screws are within the stickers.
  2. Xbox Teardown, The Top: 手順 2、 1の画像 1
    • (This photo is not mine it was from another ifixit and i will use 5 photos from them since i couldn't find the ones i took)
    • When you get the screws off use the spudger to get it open by finding a crack that goes all around the xbox
  3. Xbox Teardown, Removing the Hard Drive pt1: 手順 3、 1の画像 1
    • After you take of the top you will see all the circuits.
    • Look around and you will find 3 screws that are holding down the disc drive and remove them.
  4. Xbox Teardown, Removing the Hard Drive pt2: 手順 4、 1の画像 1
    • When you do that just take off the disc drive depending on what you are trying to fix just unplug the wires going to it and set it aside.
  5. Xbox Teardown, Removing the Disc Drive: 手順 5、 1の画像 1
    • Unplug any wires that seem to be poking out then take out the disc drive which should just come out.
    • Same thing if its not your focus just put it to the side.
  6. Xbox Teardown, The Ribbon: 手順 6、 1の画像 1
    • The rest are my pictures
    • Remove the ribbon carefully
  7. Xbox Teardown, The Rainbow Wire: 手順 7、 1の画像 1
    • Somewhere on the motherboard there will be a multi-colored wires that are together and just simply unplug it.
  8. Xbox Teardown, Removing the Transformers: 手順 8、 1の画像 1
    • To the left of the Rainbow wire there are a lot of transformers which we will need to take out.
    • There will be screws holding it down so just look around the transformers.
    • Disconnect any wires that are connected to it before picking it up.
    • Set it aside if its not what you are going for.
  9. Xbox Teardown, The Motherboard: 手順 9、 1の画像 1
    • When the transformers are gone look around the motherboard which should be the last electronic left.
    • There also will be screws around,when you find them unscrew them and all you have to do know is carefully take out the motherboard
    • Then your done at taking out the motherboard.
作成者
3人の作成者と共同で作成されました。
Justin Moreno
メンバー登録日: 11/08/16
219 ポイント
1ガイドが承認済み
コメント 1 件
you forgot to mention the fan shroud, which, if i remember correctly is a bit tricky to remove
pantsaremyfriend - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 62
今までの合計 6,521
