メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのXboxを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Xbox Teardown, Xbox Teardown: 手順 1、 2の画像 1 Xbox Teardown, Xbox Teardown: 手順 1、 2の画像 2
    • The Xbox, not as pretty as it was when I bought it 7 years ago.
  2. Xbox Teardown: 手順 2、 2の画像 1 Xbox Teardown: 手順 2、 2の画像 2
    • To begin dissasembly, flip the console so it is upside-down.
    • Remove the 4 rubber pads with a flathead screwdriver, or a heavy duty spudger. It takes a little force to get them off.
  3. Xbox Teardown: 手順 3、 3の画像 1 Xbox Teardown: 手順 3、 3の画像 2 Xbox Teardown: 手順 3、 3の画像 3
    • Doing this should reveal 4 T10 Torx Screws, But, there are 2 more hidden by stickers.
    • The hidden screws are shown in yellow.
    • Removing the 2 screws hidden by stickers will void your warranty, even though I'm sure that your warranty has already expired.
    On my Crystal Xbox the screws on the bottom (Step 3) were T20 screws not T10 screws
    Christopher S - 返信
    @Yaro
    Now that Microsoft and Sony are both veterans in the console market, your allegation that x86 would only be chosen by an inexperienced newcomer doesn't hold up. My guess is you know less about the issue than you think you do--not about the motivations behind choosing an architecture nor about the performance considerations involved.
    Further, Apple didn't switch to Intel to ease developer pains. At the time and for a long time afterward (still a problem today, in fact), writing software that compiles to native code for both OS X and whatever else remained a problem. It had little to do with developers; after all, in the high-level languages developers spend most of their time in, the target microarch is of little consequence. Rather, it had to do with IBM repeatedly failing to meet performance milestones. Their PowerPC products of the era simply weren't keeping up with Intel's x86.
    For immediate applications, that PPC can do better doesn't matter when it is not doing better.
    James Beach - 返信
    Who are you talking to?
    Aspect22 -
  4. Xbox Teardown: 手順 4、 2の画像 1 Xbox Teardown: 手順 4、 2の画像 2
    • Remove the 6 T10 Screws.
    • Hmm, where heve we seen these before?
    • My Xbox 360 Teardown, of course!
  5. Xbox Teardown: 手順 5、 3の画像 1 Xbox Teardown: 手順 5、 3の画像 2 Xbox Teardown: 手順 5、 3の画像 3
    • To remove the top half of the console, flip it upright and use a flathead screwdriver to separate the two halves.
    Don't do this ffs.
    Anna Lite - 返信
  6. Xbox Teardown: 手順 6、 2の画像 1 Xbox Teardown: 手順 6、 2の画像 2
    • Simply lift the top half off.
    • This reveals the drives.
    • From Left To Right: The DVD-ROM Drive, And A Seagate 8GB Parallel ATA Drive
  7. Xbox Teardown: 手順 7、 2の画像 1 Xbox Teardown: 手順 7、 2の画像 2
    • Removing the drives
    • Start by removing the ATA Cable from both drives. There might be a piece of double sided tape holding the ribbon cable in place.
  8. Xbox Teardown: 手順 8、 2の画像 1 Xbox Teardown: 手順 8、 2の画像 2
    • Next, remove the power cables from the drives.
    • The hard drive uses a standard molex connector for power, but the DVD-ROM drive uses a proprietary xbox connector similar to that of the xbox 360.
  9. Xbox Teardown: 手順 9、 2の画像 1 Xbox Teardown: 手順 9、 2の画像 2
    • Remove the DVD-ROM power cable.
  10. Xbox Teardown: 手順 10、 1の画像 1
    • Before we can continue, there are 3 T8 Torx screws hidden here that we need to remove.
    My xbox had T10 screws here, not T8.
    imi4tth3w - 返信
  11. Xbox Teardown: 手順 11、 2の画像 1 Xbox Teardown: 手順 11、 2の画像 2
    • Lift the hard drive and the plastic attatched to it out, you will need to route the power cable so you can get it out.
  12. Xbox Teardown: 手順 12、 3の画像 1 Xbox Teardown: 手順 12、 3の画像 2 Xbox Teardown: 手順 12、 3の画像 3
    • Removing the DVD-ROM drive.
    • Lift the DVD-ROM drive and the plastic attached to it out. This reveals the logic board.
  13. Xbox Teardown: 手順 13、 1の画像 1
    • Here's a view of the logic board.
    did a blind person take this photo?
    Nicole Best - 返信
  14. Xbox Teardown: 手順 14、 2の画像 1 Xbox Teardown: 手順 14、 2の画像 2
    • Removing the heatsinks.
    • The big one to the right, is the CPU, the smaller one to the left is for the GPU.
    • Lift the black tab up on the cpu heatsink. This will release the tension on the chip.
    • Next, use a flathead screwdriver to remove the clip. Then lift the CPU heatsink out (this may take some force).
    would i be able to put in a new fan?
    Andrew Veiga - 返信
  15. Xbox Teardown: 手順 15、 1の画像 1
    • The CPU
    • So What's Under Door Number One?
    • An Intel Pentium III CPU running at 733Mhz.
    • This is actualy a surprise, because almost every other console out there uses an IBM PowerPC CPU. This makes us wonder, could this console emulate Windows?
    • It also raises the question, why did Microsoft switch to PowerPC, around the same time Apple switched to Intel?
  16. Xbox Teardown: 手順 16、 3の画像 1 Xbox Teardown: 手順 16、 3の画像 2 Xbox Teardown: 手順 16、 3の画像 3
    • The GPU
    • Push on the tab on the GPU heatsink. While doing this, use a flathead screwdriver to push on the tab so when released, it clears the latch
    • Be careful, if you break any one of these tabs, then, your heatsinks will not be usable, and your console will fry, if you try to run it.
    • Removing the GPU heatsink, reveals an NVIDIA NV2A.
  17. Xbox Teardown: 手順 17、 1の画像 1
    • The Logic Board Overview:
    • The CPU: An Integrated Intel Pentium III CPU Clocked at 733Mhz with a 100Mhz Front Side Bus
    • The GPU: Nvidia NV2A running at 233Mhz
    • The Power Supply: Be Carefull When Working on this, you can get shocked by this if you touch it. The power connector is similar to that of an AT Power Supply found in 90's computers. It can supply 100 watts.
    • The ATA Header: This connects both drives to the Xbox Logic Board.
    • The A/V Ports
    • The Ethernet Port
    The NVidia GPU is similar to a GeForce 3 Ti/500. The 733MHz Intel CPU is a Coppermine core (the second P6 core to support SSE) but the specs (cache etc) are somewhere in-between what would be branded as a Celeron and a Pentium !!!. The OS is based on the Windows NT 5.0 kernel, but without Windows 2000’s GUI. The console’s RAM is 2x 32MB for a total of 64MB, running in dual channel mode. I believe the GPU steals some of this, but that’s my weak point with the Xbox specs. I notice that the DVD-ROM drive is a Philips in your console; doubtless different consoles will probably have DVD-ROM drives (and hard drives) supplied by different manufacturers. Speaking of the hard drive, later units’ hard drives were 10GB parts but still formatted to 8GB.
    Rowan Lloyd - 返信
作成者
9人の作成者と共同で作成されました。
Chris Green
メンバー登録日: 10/11/09
36,978 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,534のガイドは作成済み
11 件のコメント
Since the CPU has only 128kB L2 cache, it's actually the Celeron version of the Pentium III processor. Which was meant for office work, not gaming. :/
Saberus Terras - 返信
The original XBox was x86 largely because Microsoft had no clue what they were doing when they first designed the console. x86 is a dreadful architecture to work with outside of PCs, and even in the PC industry, x86 isn't really all that wonderful and is only in use because of how the PC market works. Apple knew if they stuck with PPC much longer on Macs they'd lose critical mass with software developers and they'd end up selling very expensive paperweights in a few years if they didn't do something.
As for game consoles: PPC has been demonstrated and proven time and time again to be technically superior to x86. To this day (April 2013) this is still holding true. Microsoft ditched x86 for PPC in the 360 when they realized basing the XBox on the x86 architecture was a horrible idea, both power and power-consumption-wise.
Alas, the next XBox and the PS4 are both going x86, whereas Nintendo is wisely staying PPC with the Wii U.
Yaro - 返信
Lol.
I am from the future and here to tell you how stupid that statement was.
Sources:
Xbox One - AMD Bulldozer
PlayStation 4 - AMD Bulldozer
Bobby Dazzler -
Oh, hello there Bob!
Still using AMD on upgraded tech, called Xbox Scorpio and PlayStation 4 Pro :P
Have fun,
Blinx
Blinx -
Oh hey and now Nintendo moved to Arm... Why leave PPC? Well, you know... Mobility and less power consumption...
Adriano Brito -
And considering the power and the longevity, the xBox One and the PS4 were clearly a fail. Building a gaming console so similar to a PC that developers dont have to do any optimizations to get the game to run, breaks the whole idea of consoles: Optimizing the games to run perfect on exactly that architecture and run better than PCs with superior hardware. Have you seen The Last of Us on the Playstation 3? Now keep in mind how old that console is and how bad the hardware is.
Chuckiele -
I am from the future to say:
I’m pretty the Xbox and PlayStation are not fails.
Aspect22 -
funny my xbox has a 1.4ghz cpu and 128mb of ram
gregseim - 返信
Given the 128 MB of RAM, it seems like you have a developer kit.
Nicholas -
Why is this teardown so blurry?
Aspect22 - 返信
Cómo cambio el GPU??
Tiburcio Jalaleay - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 28
過去 30 日: 210
今までの合計 67,822
