メインコンテンツにスキップ
Xbox Disassembly
必要な工具と部品
ビデオの概要
  1. Xbox Disassembly, Xbox Disassembly: 手順 1、 1の画像 1
    • Start with your Xbox unplugged and sitting on a flat, stable surface.
  2. Xbox Disassembly: 手順 2、 1の画像 1
    • Flip the Xbox over and pry off the rubber feet with a metal spudger.
  3. Xbox Disassembly: 手順 3、 2の画像 1 Xbox Disassembly: 手順 3、 2の画像 2
    • Peel back both the silver sticker and the white barcode sticker to reveal two additional screws.
  4. Xbox Disassembly: 手順 4、 1の画像 1
    • Use a T20 Torx screwdriver to remove the four screws located under the rubber feet you just removed as well as the two screws from beneath the stickers removed in the previous step.
  5. Xbox Disassembly: 手順 5、 2の画像 1 Xbox Disassembly: 手順 5、 2の画像 2
    • Once the bottom shell is no longer attached, carefully turn the Xbox right-side-up and lift off the top shell.
  6. Xbox Disassembly: 手順 6、 2の画像 1 Xbox Disassembly: 手順 6、 2の画像 2
    • Move the grey ribbon cable out of the way in order to remove the three 3 mm screws using T10 Torx screwdriver. They are located on the upper right corner, lower right, and lower left corners of disk drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  7. Xbox Disassembly: 手順 7、 2の画像 1 Xbox Disassembly: 手順 7、 2の画像 2
    • Lift the hard drive storage unit out of the Xbox. It should come right out.
    • Take the power cable out of the track around the hard drive so that the unit will come out easier.
  8. Xbox Disassembly: 手順 8、 3の画像 1 Xbox Disassembly: 手順 8、 3の画像 2 Xbox Disassembly: 手順 8、 3の画像 3
    • Use a T15 Torx screwdriver to remove four 3.37mm screws from both sides of the hard drive.
    • Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off.
  9. Xbox Disassembly: 手順 9、 2の画像 1 Xbox Disassembly: 手順 9、 2の画像 2
    • Unplug both the ribbon cable and power cable from hard drive.
    • They are in there pretty tightly, so this may take some effort.
  10. Xbox Disassembly: 手順 10、 3の画像 1 Xbox Disassembly: 手順 10、 3の画像 2 Xbox Disassembly: 手順 10、 3の画像 3
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
  11. Xbox Disassembly: 手順 11、 1の画像 1
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
  12. Xbox Disassembly: 手順 12、 1の画像 1
    • Unplug the multi-colored power cord from the motherboard. It can be plugged in very tight, so it may take some effort to unplug it.
  13. Xbox Disassembly: 手順 13、 2の画像 1 Xbox Disassembly: 手順 13、 2の画像 2
    • Using T10 Torx screwdriver, remove two 3mm screws from the power supply board.
  14. Xbox Disassembly: 手順 14、 2の画像 1 Xbox Disassembly: 手順 14、 2の画像 2
    • Remove the power supply and set it aside. It should lift right out.
  15. Xbox Disassembly: 手順 15、 2の画像 1 Xbox Disassembly: 手順 15、 2の画像 2
    • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
  16. Xbox Disassembly: 手順 16、 2の画像 1 Xbox Disassembly: 手順 16、 2の画像 2
    • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
    • Unplug the power cable attached to the fan.
  17. Xbox Disassembly: 手順 17、 1の画像 1
    • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
  18. Xbox Disassembly: 手順 18、 1の画像 1
    • Pry the plastic fan clips away from the fan base and remove the fan.
    • This may take a little effort, as the clips are pretty stiff. Beware, the fan will be filthy.
  19. Xbox Disassembly: 手順 19、 2の画像 1 Xbox Disassembly: 手順 19、 2の画像 2
    • Using a T10 Torx screwdriver, remove two 3mm screws from each of two controller sockets.
    • Take the sockets out by pulling back and up at the same time.
  20. Xbox Disassembly: 手順 20、 1の画像 1
    • Congratulations, your Xbox is now completely dismembered.
終わりに
48 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
rmarstel
メンバー登録日: 10/29/09
5,674 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 18-2, Maness Fall 2009 Cal Poly, Team 18-2, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S18G2
3 メンバー
24のガイドは作成済み
10 件のコメント
Awesomeness, thanks a lot!
godoyander - 返信
Thanks a million - perfect!
xan_lucky16 - 返信
Heatsink removal?
Matt Russell - 返信
Face plate removal?
Herberth Alvarez - 返信
Did a complete cleanup and refresh of my Xbox thanks to your guide, thank you :)
Mickaël STEMMER - 返信
コメントを追加
統計データ:
過去 24時間: 72
過去 7 日: 406
過去 30 日: 1,864
今までの合計 181,266
