必要な工具と部品
Place the controller face down on your working surface to allow access to rear screws.
Take the battery compartment out.
Use a TR9 bit and screwdriver to remove all 7 screws.
Remove the rear half of the controller by pulling perpendicular to the front half.
The battery terminals have specific grooves that they slide in and out of.
Detach the vibration motor cable from the PCB.
After detaching the vibration motor cable from the PCB, remove the vibration motor.
Utilize the same technique for the other vibration motor on the opposite side.
Make sure the front half of the controller is facing towards you.
The PCB should simply lift out with little to no force when being held by the areas highlighted.
If the PCB doesn't freely lift out, apply light consistent leverage under the highlighted area.
Gently peel off the conductive rubber pads to expose the backsides of the buttons
Remove the A, B, X, Y, Back, Start and Guide buttons. The Guide button sleeve may also be removed.
You can now remove the bumper assembly at the top.
Remove the last two screws in the D-pad with a #0 Phillips screwdriver.
Use a pair of tweezers to squeeze the clips together and remove the D-pad.
And here is the final result: a completely disassembled Xbox 360 Wireless Controller.
4 件のコメント
Excelente trabajos
Very clear, helped me clean my controller. Thank you :)
Hello. I just did clean one of mine that i did bye 2011. The Rumble on left end right are the opposit to this guide.
I did never disconnect them from the pcb. So ma bey its another revision or the left and right is missing.
From the back.
Small left , big right.
Se puede abrir el compartimiento de las baterias ya que no hace contacto, se pierde la señal del mando
