メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのXbox 360 Wireless Controllerを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Xbox 360 Wireless Controller Teardown, Removing the first screws: 手順 1、 3の画像 1 Xbox 360 Wireless Controller Teardown, Removing the first screws: 手順 1、 3の画像 2 Xbox 360 Wireless Controller Teardown, Removing the first screws: 手順 1、 3の画像 3
    • Place the controller face down on your working surface to allow access to rear screws.
    • Take the battery compartment out.
    • Use a TR9 bit and screwdriver to remove all 7 screws.
  2. Xbox 360 Wireless Controller Teardown, Removing the back: 手順 2、 2の画像 1 Xbox 360 Wireless Controller Teardown, Removing the back: 手順 2、 2の画像 2
    • Remove the rear half of the controller by pulling perpendicular to the front half.
    • The battery terminals have specific grooves that they slide in and out of.
    • If the two halves do not easily separate, you can slide a spudger along the seam and/or slightly depress the left/right triggers.
  3. Xbox 360 Wireless Controller Teardown, Removing the vibration motors: 手順 3、 2の画像 1 Xbox 360 Wireless Controller Teardown, Removing the vibration motors: 手順 3、 2の画像 2
    • Detach the vibration motor cable from the PCB.
    • DO NOT use the cable to remove from the PCB. You may damage the motor, connector, or PCB by pulling on the cable.
    • After detaching the vibration motor cable from the PCB, remove the vibration motor.
    • Utilize the same technique for the other vibration motor on the opposite side.
  4. Xbox 360 Wireless Controller Teardown, Removing the PCB: 手順 4、 2の画像 1 Xbox 360 Wireless Controller Teardown, Removing the PCB: 手順 4、 2の画像 2
    • Make sure the front half of the controller is facing towards you.
    • The PCB should simply lift out with little to no force when being held by the areas highlighted.
    • If the PCB doesn't freely lift out, apply light consistent leverage under the highlighted area.
    • Be cognizant of the components on the opposing side of the PCB.
  5. Xbox 360 Wireless Controller Teardown: 手順 5、 1の画像 1
    • Full IC Identification:
    • You may need to enlarge it to view the text.
  6. Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: 手順 6、 3の画像 1 Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: 手順 6、 3の画像 2 Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: 手順 6、 3の画像 3
    • Gently peel off the conductive rubber pads to expose the backsides of the buttons
    • Remove the A, B, X, Y, Back, Start and Guide buttons. The Guide button sleeve may also be removed.
    • You can now remove the bumper assembly at the top.
  7. Xbox 360 Wireless Controller Teardown, Removing the D-Pad: 手順 7、 1の画像 1
    • Remove the last two screws in the D-pad with a #0 Phillips screwdriver.
    • Use a pair of tweezers to squeeze the clips together and remove the D-pad.
  8. Xbox 360 Wireless Controller Teardown, End result: 手順 8、 1の画像 1
    • And here is the final result: a completely disassembled Xbox 360 Wireless Controller.
作成者
7人の作成者と共同で作成されました。
Mart-Jan
メンバー登録日: 05/26/19
305 ポイント
1ガイドが承認済み
3 件のコメント
Excelente trabajos
RIGO NOLASCO - 返信
Very clear, helped me clean my controller. Thank you :)
Taydolf Swiftler - 返信
Hello. I just did clean one of mine that i did bye 2011. The Rumble on left end right are the opposit to this guide.
I did never disconnect them from the pcb. So ma bey its another revision or the left and right is missing.
From the back.
Small left , big right.
https://imgur.com/a/DxXdUNB
Michael Orban - 返信
コメントを追加
統計データ:
過去 24時間: 28
過去 7 日: 192
過去 30 日: 974
今までの合計 39,516
