メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのXbox 360を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Xbox 360 Teardown, Hard drive: 手順 1、 1の画像 1
    • Here you would usually have a hard drive, my xbox does not. To remove it you push down the button and lift it out
  2. Xbox 360 Teardown, Removing the front cover: 手順 2、 3の画像 1 Xbox 360 Teardown, Removing the front cover: 手順 2、 3の画像 2 Xbox 360 Teardown, Removing the front cover: 手順 2、 3の画像 3
    • You can put a flat head screw driver in between the plastic as shown and gently pry open the front
    • You can alternatively grab inside the USB port and pull the cover off
  3. Xbox 360 Teardown, Removing the bottom panel: 手順 3、 3の画像 1 Xbox 360 Teardown, Removing the bottom panel: 手順 3、 3の画像 2 Xbox 360 Teardown, Removing the bottom panel: 手順 3、 3の画像 3
    • Use a small tool to stick in and push these pins
    • Be sure to keep pressure pulling outwards for this to come out easily
    • Make sure that you pop out the pins on both sides
  4. Xbox 360 Teardown, Removing the top plate: 手順 4、 3の画像 1 Xbox 360 Teardown, Removing the top plate: 手順 4、 3の画像 2 Xbox 360 Teardown, Removing the top plate: 手順 4、 3の画像 3
    • Same as the bottom plate you want to push in the buttons holding this in
    • Note that there are six buttons holding this together in total so it is ok to accidentally break 1 or 2
  5. Xbox 360 Teardown, The front case: 手順 5、 2の画像 1 Xbox 360 Teardown, The front case: 手順 5、 2の画像 2
    • You have to evenly disconnect all four of these connectors holding it together
    • I used flat head screw driver bits to hold the connectors open
    • You have to remove a warranty sticker to open the console. Be warned, this will void your warranty.
  6. Xbox 360 Teardown, Removing the back of the casing: 手順 6、 3の画像 1 Xbox 360 Teardown, Removing the back of the casing: 手順 6、 3の画像 2 Xbox 360 Teardown, Removing the back of the casing: 手順 6、 3の画像 3
    • You must push in these buttons (7 in total)
    • It is nearly impossible to not mess up the plastic using a screwdriver, i would recommend using an x-acto knife
    • This was one of the harder steps, you must push the button in until it clicks and then go farther still
    • Make sure you keep pressure applied outwards so that the locks do not re-engage
    Why is the hardest step on this teardown the only step without a picture of the someone showing the proper way to unclip the back of the case?!
    Sam Love - 返信
    I would say that is likely because of how difficult it would be to hold it open and take a picture without it closing itself back up.
    Michael - 返信
    I've heard there is a special tool for this if so, does anyone know if it is a better option?
    Marty Kendrick - 返信
  7. Xbox 360 Teardown, Removing the disc drive button: 手順 7、 3の画像 1 Xbox 360 Teardown, Removing the disc drive button: 手順 7、 3の画像 2 Xbox 360 Teardown, Removing the disc drive button: 手順 7、 3の画像 3
    • To pop off this button, use the flat end of a spudger or flat-head screwdriver.
  8. Xbox 360 Teardown, Opening up to the motherboard: 手順 8、 3の画像 1 Xbox 360 Teardown, Opening up to the motherboard: 手順 8、 3の画像 2 Xbox 360 Teardown, Opening up to the motherboard: 手順 8、 3の画像 3
    • Remove the six silver screws
    • Flip over the whole Xbox holding both the plastic and the metal, then pull off the casing
    Using what type of screwdriver bit?
    Tyler Olson - 返信
  9. Xbox 360 Teardown, Removing the disc drive: 手順 9、 3の画像 1 Xbox 360 Teardown, Removing the disc drive: 手順 9、 3の画像 2 Xbox 360 Teardown, Removing the disc drive: 手順 9、 3の画像 3
    • Carefully remove the two connectors
    • The disc drive may have some tape in the front holding it in place, simply remove this.
  10. Xbox 360 Teardown, Opening up the fans: 手順 10、 3の画像 1 Xbox 360 Teardown, Opening up the fans: 手順 10、 3の画像 2 Xbox 360 Teardown, Opening up the fans: 手順 10、 3の画像 3
    • To remove the fan covering, use a flat head screw driver as shown to gently pry it off
  11. Xbox 360 Teardown, Removing the fans: 手順 11、 3の画像 1 Xbox 360 Teardown, Removing the fans: 手順 11、 3の画像 2 Xbox 360 Teardown, Removing the fans: 手順 11、 3の画像 3
    • Use a small flat head screw driver to open this locking mechanism and then gently remove the fan connector
    • Use a screw driver or spludger to pry out the fan from the casing
  12. Xbox 360 Teardown, Removing the power button: 手順 12、 3の画像 1 Xbox 360 Teardown, Removing the power button: 手順 12、 3の画像 2 Xbox 360 Teardown, Removing the power button: 手順 12、 3の画像 3
    • To remove the "On" button simply disconnect the plastic clip
    • Remove the three black screws and pull the chip directly outwards so you do not damage the connector
  13. Xbox 360 Teardown, Removing the mother board: 手順 13、 2の画像 1 Xbox 360 Teardown, Removing the mother board: 手順 13、 2の画像 2
    • Remove the 9 gold screws
    • Remove the 8 black screws
    • Carefully pull out the mother board and make sure that you do not damage any connectors
  14. Xbox 360 Teardown, Displaying the main components.: 手順 14、 2の画像 1 Xbox 360 Teardown, Displaying the main components.: 手順 14、 2の画像 2
    • Memory card ports
    • Custom ATi Graphics Processor with 10Mb of Ram
    • 3 IBM PowerPC Cores Each Running At 3.2Ghz with 512Mb of System Ram
    • Hard drive port
    • Power port
    • HDMI and Video ports
    The CPU is marked with pink colour, and the GPU is blue.
    Stefan G - 返信
  15. Xbox 360 Teardown, You’re finished!: 手順 15、 1の画像 1
    • This is it. Follow these steps in reverse to re-assemble your Xbox 360 system!
作成者
3人の作成者と共同で作成されました。
Michael
メンバー登録日: 10/23/16
510 ポイント
1ガイドが承認済み
11 件のコメント
Please comment if you have any suggestions or help so that I can be sure to update this, or do a better job in the future.
Michael - 返信
Your method is very offensive and not recommended when you wont damage the case of your Xbox 360.
TheSupport - 返信
Up yours it obviously helped 3.1 thousand people. Being as you have zero guides and close to no reputation, maybe you should try it. But your input is valued, so thank you.
Michael -
$@$*-hot reply - like it!!!
lawsewilliams - 返信
this was helpful
tostypinapple - 返信
To the person who said this method is offensive... okay? It literally is an ORIGINAL 360 body shell, I started repairing 360's back when the RROD was a big thing, and on base (I grew up as an Airforce Brat) we literally called it a suicide break anytime one had to be disassembled. Yeah there might be simpler prettier solutions but they take more time and finesse to achieve.
KASEY BIGBEE - 返信
thank you Michael
aghakamran.khan - 返信
Does diassembling this machine for the purpose of having fun while doing it a good idea?
I don't play any consoles and have one that's been sitting for 10+ years. Also, would any parts be of use for something else?
THanks
Faisal Rusheidat - 返信
I think the majority of electronics I tear apart is just for fun and maybe to fix something and learn along the way. As long as you're comfortable with working with electronics and aren't afraid of breaking it, I'd see it as a perfect opportunity to learn about what's inside hands on. As far as repurposing parts I'm not sure other than if you needed the fan and heat sinks for something else.
Michael -
I loved the one spicey comment. Your response was hilarious as well. I've used this guide before and haven't damaged anything. That was on my first repair as well. I'm back again to take a look as I repair my second 360 that belongs to my brother. I guess the thing just doesn't work at all right now and I just know it needs a cleaning, paste and possible disc drive maintenance so I'm stoked to crack that bad boy open. Have a good one!
Christopher Curtis - 返信
On a side note I had a 360 that wouldn't read disks anymore and found online that there are two potentiometers in the disk drive and I upped one of those and it works perfect now, in case that helps you or anyone else reading. I'm sure it's not good for it, but the drive dying sooner is better than not reading at all to me
Michael -
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 96
過去 30 日: 384
今までの合計 27,878
