メインコンテンツにスキップ
はじめに
This guide will help you to completely disassemble your phone in order to perform other repairs.
この分解は修理ガイドでは ありません。 お持ちのUniden EXP 371を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Uniden EXP371 900 MHz Cordless Phone.
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone. Next remove the battery by pulling on the connector.
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver. Now remove the top portion of the case from the bottom.  This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  5. Your next step is to remove the five screws holding down the motherboard.  Use the PH1 philips screwdriver. Once you have removed the five screws you may lift the motherboard off of the front case. At this point you may also remove the dial pad. It simply lifts off.
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
Tim Reimer
メンバー登録日: 2010年06月19日
164 ポイント
3のガイドは作成済み
コメント1件
this guide is poorly written, please delete or improve it.
Walker Quine - 返信
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 4,405
