メインコンテンツにスキップ
Twentieth Anniversary Mac Teardown
必要な工具と部品
  1. Twentieth Anniversary Mac Teardown, Logic Board: 手順 1、 1の画像 1
    • Use the release tabs to remove the rear cover
  2. Twentieth Anniversary Mac Teardown: 手順 2、 1の画像 1
    • Remove any ComSlot II or PCI cards that may be installed and their risers.
  3. Twentieth Anniversary Mac Teardown: 手順 3、 1の画像 1
    • Unplug the logic board connections to the PRAM battery and fan.
    • Remove the PRAM battery from it's Velcro mounting.
    • Remove the four #0 Philips screws securing the hard drive and processor fan assembly.
    • Remove the hard drive and processor fan assembly.
  4. Twentieth Anniversary Mac Teardown: 手順 4、 1の画像 1
    • Remove the two T6 Torx screws securing the A/V input board.
    • Remove the A/V Input board
  5. Twentieth Anniversary Mac Teardown: 手順 5、 1の画像 1
    • Remove the white plastic shield
    • Remove the T6 torx screw securing the logic board to the frame.
  6. Twentieth Anniversary Mac Teardown: 手順 6、 2の画像 1 Twentieth Anniversary Mac Teardown: 手順 6、 2の画像 2
    • Turn the TAM around with the front facing you.
    • Use a spudger to gently loosen the speaker covers from their press-fit snaps. Remove the speaker covers.
  7. Twentieth Anniversary Mac Teardown: 手順 7、 1の画像 1
    • Remove the six T8 torx screws securing the front case to the rear case.
  8. Twentieth Anniversary Mac Teardown: 手順 8、 3の画像 1 Twentieth Anniversary Mac Teardown: 手順 8、 3の画像 2 Twentieth Anniversary Mac Teardown: 手順 8、 3の画像 3
    • Gently pull the tabs toward the center to release the latches hold the front and back together. These tabs are fragile but release easily. Use caution.
    • Lean the top forward and lift up to pull the front case from it's bottom latches.
    • DO NOT TRY TO REMOVE THE FRONT CASE. It is still connected to the back case by several wires and cables.
  9. Twentieth Anniversary Mac Teardown: 手順 9、 3の画像 1 Twentieth Anniversary Mac Teardown: 手順 9、 3の画像 2 Twentieth Anniversary Mac Teardown: 手順 9、 3の画像 3
    • Disconnect the pink and white backlight inverter cable and the black and white right speaker cable from behind the floppy disk drive on the right side.
    • On the left side, disconnect the 50-pin SCSI ribbon cable, analog audio cable and power cable from the CD-ROM drive.
    • Disconnect the black and white left speaker cable.
    • Disconnect the flat, orange display data cable.
    • Open the top case to the left like a book. There will be one more 50-pin cable to disconnect from the front control panel board.
  10. Twentieth Anniversary Mac Teardown: 手順 10、 1の画像 1
    • The easiest method to remove the logic board is to remove it with the tuner card and cabling.
    • Disconnect the five cables illustrated.
  11. Twentieth Anniversary Mac Teardown: 手順 11、 1の画像 1
    • Remove the T10 torx screw and extract the stiff wire cable brace from the left side
  12. Twentieth Anniversary Mac Teardown: 手順 12、 1の画像 1
    • Carefully peel back the tape securing the cables to the white, plastic logic board cover. Pull the cables back to reveal the back side of the logic board.
    • Remove the five T10 screws holding the logic and tuner boards to the back case.
  13. Twentieth Anniversary Mac Teardown: 手順 13、 3の画像 1 Twentieth Anniversary Mac Teardown: 手順 13、 3の画像 2 Twentieth Anniversary Mac Teardown: 手順 13、 3の画像 3
    • Lift the logic board from the left edge then straight up to remove it from the rear case.
    • The logic board slides out of the cabling connector.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Dylan
メンバー登録日: 02/04/13
511 ポイント
1ガイドが承認済み
4 件のコメント
Hi,
One of the member of my Forum is looking for the Bose subwoofer including the power cable. Have you an idee on where could he find it ?
Thx.
Raziel
vitalisfrance - 返信
It's missing the step to remove the two torx screws on the upper back side, below the cover with all the holes, after Step 5
Deagol - 返信
Dose anybody know what goes in the top-most chip slot that is empty? Is that for an L2 Cache chip?
garo211 - 返信
To echo the comment from 2014, i just performed this guide and there is a critical step missing between steps 6 & 7. The small plastic grille at the top rear needs to be removed; There are two tabs at the bottom and two on the sides. Flex it to remove. Then remove the two visible torx screws to release the top.
coryheisterkamp - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 53
今までの合計 11,124
