必要な工具と部品
Gently pull the tabs toward the center to release the latches hold the front and back together. These tabs are fragile but release easily. Use caution.
Lean the top forward and lift up to pull the front case from it's bottom latches.
DO NOT TRY TO REMOVE THE FRONT CASE. It is still connected to the back case by several wires and cables.
Disconnect the pink and white backlight inverter cable and the black and white right speaker cable from behind the floppy disk drive on the right side.
On the left side, disconnect the 50-pin SCSI ribbon cable, analog audio cable and power cable from the CD-ROM drive.
Disconnect the black and white left speaker cable.
Disconnect the flat, orange display data cable.
Open the top case to the left like a book. There will be one more 50-pin cable to disconnect from the front control panel board.
7 の人々がこのガイドを完成させました。
4 件のコメント
Hi,
One of the member of my Forum is looking for the Bose subwoofer including the power cable. Have you an idee on where could he find it ?
Thx.
Raziel
To echo the comment from 2014, i just performed this guide and there is a critical step missing between steps 6 & 7. The small plastic grille at the top rear needs to be removed; There are two tabs at the bottom and two on the sides. Flex it to remove. Then remove the two visible torx screws to release the top.
