メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのToasterを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Toaster Teardown, Original Toaster: 手順 1、 3の画像 1 Toaster Teardown, Original Toaster: 手順 1、 3の画像 2 Toaster Teardown, Original Toaster: 手順 1、 3の画像 3
    • Starting functionality of toaster: toasts bread for a variable time depending on the knob setting when turned on.
  2. Toaster Teardown, Remove bottom 4 screws: 手順 2、 3の画像 1 Toaster Teardown, Remove bottom 4 screws: 手順 2、 3の画像 2 Toaster Teardown, Remove bottom 4 screws: 手順 2、 3の画像 3
    • Removing the bottom four screws allows the metal casing to open.
  3. Toaster Teardown, Remove Crumb Collector: 手順 3、 1の画像 1
    • Unlatch bottom crumb collector by removing the metal tab and wires connecting it to the base of the metal structure. This reveals a way to clean the toaster in the future.
  4. Toaster Teardown, slide out back and front plastic covers: 手順 4、 2の画像 1 Toaster Teardown, slide out back and front plastic covers: 手順 4、 2の画像 2
    • These covers were attached by the four screws at the bottom. To remove them, simply pull up and shimmy them out of their slots. However, the front cover still has electrical attachments.
  5. Toaster Teardown, Remove the 2 screws from power cord immobilizer: 手順 5、 2の画像 1 Toaster Teardown, Remove the 2 screws from power cord immobilizer: 手順 5、 2の画像 2
    • The cord immobilizer is a small black plastic piece held in by screws.
  6. Toaster Teardown, Lift on depressor lever and remove from sliding mechanism: 手順 6、 1の画像 1
    • This step requires a bit of muscle. The plastic lever is very well attached to the depressor lever. Then the front plastic cover can further be removed from the metal frame.
  7. Toaster Teardown, Unsolder leads from circuit board to filaments: 手順 7、 1の画像 1
    • The circuit board is welded to the heated filaments. In order to further open up the toaster frame, this step is necessary.
  8. Toaster Teardown, Remove Spring and Latch: 手順 8、 2の画像 1 Toaster Teardown, Remove Spring and Latch: 手順 8、 2の画像 2
    • The spring shown makes the lever bounce back up after the toast is done. The latches hold the toast in place when the lever is down.
作成者
2人の作成者と共同で作成されました。
Maria Pieroni
メンバー登録日: 11/20/19
157 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 11
今までの合計 1,061
