はじめに
We are going to start with the base of the fan, and move to the top afterwords.
必要な工具と部品
Remove the two 10 mm Phillips #1 screws found connecting the switch to the case.
At the base of the upper assembly there is a plug which conceals a screw.
The plug can be removed with a screwdriver. Removing the plug may take a few attempts.
Remove the rear fan guard by taking off the plastic nut that holds the rear fan guard to the upper assembly.
