はじめに
Hey im Marios!I Make repairs on everythink you may have in your house!This is an easy repair but some people may want some help!Lets go!
必要な工具と部品
Remove the 2 screws holding the back cover!Should be fairly easy(You need a Phillips Screwdriver)
This is also fairly easy to do!You can use your hands to pull it off!Put first use a flat screwdriver to open the "clips"
Remove the cable antenna now!And thats it you are done,now just follow the guide in reverse and install your new wireless card/antenna if also needed!
WARNING:DO THIS CAREFULLY!ITS SUGGESTED THAT YOU DO THIS STEP SLOWLY!TAKE YOUR TIME OR YOU MAY DAMAGE THE CABLE OR EVEN THE BOARD!
