メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのPhone Accessoryを修理する際は、iFixitの修理ガイドをご利用ください。
  1. T-Mobile 3.1AMP Micro USB Car Charger Teardown, T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 1、 1の画像 1
    • T-Mobile's 3.1AMP Micro USB Car Charger has a sleek design that fits well into almost any cigarette lighter outlet and can power up to two micro USB devices.
    • The adapter has a rating of 5V/3.1A and comes in several colors
    • The charger includes:
    • Micro USB adapter
    • USB adapter for secondary device
    • LED to indicate status of charge
    • Convenient curly cord to conserve space
  2. T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 2、 2の画像 1 T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 2、 2の画像 2
    • Generally, car chargers are replaced instead of being repaired because of their low cost.
    • Because of this, it seems T-Mobile has made this charger particularly difficult to disassemble, given that there are no obvious points of entry
    • In order to pierce this seemingly impenetrable shell, we will need to reach for our plastic opening tool.
    • Pry the lid off the top of the charger with the plastic opening tool.
    • Do not apply too much force or you may damage the wires that connect the curly cord to the device.
  3. T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 3、 2の画像 1 T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 3、 2の画像 2
    • With the lid removed, we can now see a bit of the circuitry including:
    • USB port
    • LED light
    • a lone resistor
    • Separating the top cover from the bottom cover takes two steps:
    • There are two wires connecting the curly cord to the charger, so we need to cut these wires with the flush wire cutters to keep them neat and reusable.
    • Next we can see that there are two tabs keeping the red plastic cover connected to the black plastic cover. In order to separate these two we need to use two plastic opening tools in tandem with a little bit of force. As stated earlier, T-Mobile did not design these chargers to be easily repaired.
  4. T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 4、 3の画像 1 T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 4、 3の画像 2 T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 4、 3の画像 3
    • With the red plastic cover removed, we now need to remove the black plastic cover.
    • Remember earlier that this device was not built with future repair in mind, and this cover is proof of that.
    • In order to remove it, we'll need to use the vice grips to squeeze the cover until the tabs click and disconnect.
    • We do not have a picture of us separating this part, but the vice grips need to be perpendicular and across the seem.
    • Do not use too much pressure as this might permanently damage the device.
    • Simply pry the cover apart once the tabs are disconnected.
  5. T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 5、 1の画像 1
    • Once the black cover comes apart, there will be six parts:
    • Front and back of the cover
    • Front contact that connects with the positive end of the cigarette lighter
    • Two side contacts that connect with the negative end of the cigarette lighter
    • Circuit board with wire and spring
  6. T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 6、 3の画像 1 T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 6、 3の画像 2 T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 6、 3の画像 3
    • Now we are in the meat and potatoes of this device, the circuit board.
    • Surprisingly, the ONLY chip on the board is:
    • Active-Semi ACT4533B DC/DC Converter
    • This CLA was implemented with a relatively simple design using very few parts, including:
    • Several resistors, capacitors
    • Two diodes
    • Fuse
    • and one inductor
  7. T-Mobile 3.1AMP Micro USB Car Charger Teardown: 手順 7、 1の画像 1
    • T-Mobile 3.1AMP Universal USB Charger Repairability Score: 1 out of 10 (10 is easiest to repair)
    • Plastic cover was very difficult to remove.
    • Wires needed to be cut in order to disassemble (needs to be resoldered to put back together).
    • Contacts are difficult to keep in alignment during rebuilding.
    • It's clear that T-Mobile did not intend for these devices to be repaired, rather they are intended to simply be replaced.
作成者
1人の作成者と共同作成されました。
Oliver
メンバー登録日: 01/12/15
251 ポイント
2のガイドは作成済み
コメント 1 件
I am impressed that you were able to take it apart! These things can be a real hassle.
Jake Allen - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 67
今までの合計 4,524
