メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのSuper Nintendo Entertainment System Controllerを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Super Nintendo Entertainment System Controller Teardown, Super Nintendo Entertainment System Controller Teardown: 手順 1、 1の画像 1
    • It's your classic Super Nintendo controller.
    • Notably, it's a wired controller (same as most of the controllers of the era), and has a very simple layout.
    • The design is often called a "dogbone", due to the shape of the lower part.
  2. Super Nintendo Entertainment System Controller Teardown: 手順 2、 1の画像 1
    • Nintendo, unlike the Control Deck counterpart, did not use custom screws in the controller, therefore it's very easy to open and clean.
    • We remove the 5 Phillips screws on the back of the controller.
  3. Super Nintendo Entertainment System Controller Teardown: 手順 3、 2の画像 1 Super Nintendo Entertainment System Controller Teardown: 手順 3、 2の画像 2
    • Open... the... controller.
  4. Super Nintendo Entertainment System Controller Teardown: 手順 4、 3の画像 1 Super Nintendo Entertainment System Controller Teardown: 手順 4、 3の画像 2 Super Nintendo Entertainment System Controller Teardown: 手順 4、 3の画像 3
    • There are two metal rods that we have to take care of before removing the rest, otherwise they might get lost.
    • We remove the two shoulder buttons.
  5. Super Nintendo Entertainment System Controller Teardown: 手順 5、 3の画像 1 Super Nintendo Entertainment System Controller Teardown: 手順 5、 3の画像 2 Super Nintendo Entertainment System Controller Teardown: 手順 5、 3の画像 3
    • Now we can get onto the board! We first remove the cable from the slack poles.
    • After that, it's only a matter of lifting the board out.
  6. Super Nintendo Entertainment System Controller Teardown: 手順 6、 3の画像 1 Super Nintendo Entertainment System Controller Teardown: 手順 6、 3の画像 2 Super Nintendo Entertainment System Controller Teardown: 手順 6、 3の画像 3
    • Onto the rubber pads that represent the buttons, we'll have to remove those too.
    • Many of these older controllers might have delicate rubber pads, they should be handled carefully.
  7. Super Nintendo Entertainment System Controller Teardown: 手順 7、 3の画像 1 Super Nintendo Entertainment System Controller Teardown: 手順 7、 3の画像 2 Super Nintendo Entertainment System Controller Teardown: 手順 7、 3の画像 3
    • Inching closer, we get to the shoulder button's rubber pads.
    • We can finally remove the remaining plastic buttons from the D-Pad and face button areas.
  8. Super Nintendo Entertainment System Controller Teardown: 手順 8、 3の画像 1 Super Nintendo Entertainment System Controller Teardown: 手順 8、 3の画像 2 Super Nintendo Entertainment System Controller Teardown: 手順 8、 3の画像 3
    • The board itself has the controller cable attached, we can remove that too.
    • Not all controllers have a removable cable. Some models, such as the SNS-102, have soldered-on cables.
    • We make sure to pull away from the connector, and not up! It might be a little difficult depending on how long it's been attached.
  9. Super Nintendo Entertainment System Controller Teardown: 手順 9、 3の画像 1 Super Nintendo Entertainment System Controller Teardown: 手順 9、 3の画像 2 Super Nintendo Entertainment System Controller Teardown: 手順 9、 3の画像 3
    • The SNES Controller board features a number of pads as well as a chip.
    • The chip on the board is a 12-bit shift register, used to multiplex all the button signals on the controller into a more budget-friendly connector.
  10. Super Nintendo Entertainment System Controller Teardown: 手順 10、 1の画像 1
    • Finally, we can see all the innards that make this little controller work.
    • Maybe we should play a few rounds of Super Mario World...
作成者
4人の作成者と共同で作成されました。
Foxlet
メンバー登録日: 05/17/10
601 ポイント
3のガイドは作成済み
2 件のコメント
What is the repair ability score ?
logan - 返信
what size screws are used?
Elizabeth Ziriada - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 55
過去 30 日: 221
今までの合計 12,820
