はじめに
実行不可能な分解のようですが、ついにSuper Nintendo Classic Editionに手を伸ばしてしまいました。言うまでもなく、まず最初にゲームをしたいという本能が沸き起こってきました。結局のところ、スーパーマリオワールドがどうやっても下手くそだとすぐに気づきました。 iFixit Pro Tech Toolkitを掴んで、溜まったゲームのフラストレーションを解き放つ唯一の方法に移りました。それは分解です。
もっと他にも分解情報を入手されたい方ーFacebook、Twitter、Twitter日本語版をフォローしてください。
必要な工具と部品
ビデオインストラクション
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
5 件のコメント
at 00:37, it says HDMI. HOW DOES THAT THING HAVE HDMI?
Aiden - 返信
pics are > video, tho ideally there would be both, but for heaven’s sake, if you’re only gonna have one or the other, stick to pics!!!!!!!
Firstname Lastname - 返信
So a while ago I decided to take my SNES classic apart for whatever reason, and when I came to turn it back on, the power led was not working and the reset button was not working. I think I’ve found that the problem is within the board itself, so I am unsure if I could buy that smaller board for the console somewhere else. I’ve tried cleaning it with isopropyl alcohol and to no avail. Thanks for the help.
Nintendo Gaming - 返信
So I recently opened mine up and cleaned it up with isopropyl. After doing this it turns on but nothing appears on the Television, I finally got it to work but anytime the console is moved, even the smallest amount the display flickers. Is this a short in the boar? Is there away to fix it?
Thomas Sullivan - 返信
yes you can fix it when you opened it and cleaned it you may have put something out of place or you knocked it out of place go back in to it and make sure its all good
tostypinapple -
