はじめに
Teardown of string cheese
必要な工具と部品
Inspect the string cheese packaging. You should see a perforated corner that you can stick the tip of your spudger into.
Once you put the tip of the spudger into the plastic pull the corner with your other hand, guiding the spudger along as you peel back the packaging.
We're in to the GOOD stuff,
Pull up on the cheese to get it unstuck from the adhesive
19 件のコメント
HelloMacOS - 返信
@hellomacos - Help if you want
Sure ,what do you want me to do?
@hellomacos - Idk do what you want X-D
@hellomacos - Will Do! >:-D
[無効なガイドリンク]
