メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Teardown of electric guitar
この分解は修理ガイドでは ありません。 お持ちのSquier Strat Guitarを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Pull off the three tone/volume caps.
    • Pull off the three tone/volume caps.
  2. Pull off the end cap on the pickup selector.
    • Pull off the end cap on the pickup selector.
    • Note: This is not how the switch should normally look. This one is bent slightly; the tip should be pointing straight up.
  3. Unscrew the three bolts holding the tone/volume potentiometers to the scratch plate.
    • Unscrew the three bolts holding the tone/volume potentiometers to the scratch plate.
  4. Remove the 3 washers from the tone/volume potentiometers
    • Remove the 3 washers from the tone/volume potentiometers
  5. Unscrew the eight screws which hold the pick guard to the main body.
    • Unscrew the eight screws which hold the pick guard to the main body.
  6. Unscrew the two screws holding the pickup selector in place.
    • Unscrew the two screws holding the pickup selector in place.
  7. unscrew the six screws holding the three pickups in place.
    • unscrew the six screws holding the three pickups in place.
  8. Lift off the scratch plate, revealing the electronics inside the main body Lift off the scratch plate, revealing the electronics inside the main body
    • Lift off the scratch plate, revealing the electronics inside the main body
  9. Another method of dis-assembly: remove the pickguard screws (leaving pickup screws, pots and switch untouched).
    • Another method of dis-assembly: remove the pickguard screws (leaving pickup screws, pots and switch untouched).
    • Remove the jack plate, desolder or cut the output jack wires, flip over the guitar and desolder the ground wire on the tremolo. Remove the pickguard with all electronics attached.
    • This method gives easy access to do electronics repairs/mods, without having to readjust pickup heights and individual components won't move around when you're soldering.
  10. Lift off the three pickup covers.
    • Lift off the three pickup covers.
  11. Remove the springs which were on the underside of the pickups.
    • Remove the springs which were on the underside of the pickups.
  12. Unscrew the two screws holding the lead input cover in place and lift off the cover.
    • Unscrew the two screws holding the lead input cover in place and lift off the cover.
  13. Unscrew the input threaded bolt, which holds the output jack in place.
    • Unscrew the input threaded bolt, which holds the output jack in place.
  14. Unscrew the screw holding the bottom strap button in position. Unscrew the screw holding the bottom strap button in position.
    • Unscrew the screw holding the bottom strap button in position.
  15. Carry out the same process to remove the top strap button.
    • Carry out the same process to remove the top strap button.
  16. Remove the six screws securing the bridge to the body.
    • Remove the six screws securing the bridge to the body.
  17. Take out the six screws holding the white back plate in place.
    • Take out the six screws holding the white back plate in place.
  18. Remove the three tremolo springs from the spring claw and tremolo block.
    • Remove the three tremolo springs from the spring claw and tremolo block.
  19. Unscrew the two screws holding the spring claw to the body.
    • Unscrew the two screws holding the spring claw to the body.
  20. Remove Bridge from main body.
    • Remove Bridge from main body.
  21. Unscrew chrome parts.
    • Unscrew chrome parts.
  22. Undo the 6 screws holding the saddles to the bridge. Then remove the spring and unscrew the 12 threaded bars. Undo the 6 screws holding the saddles to the bridge. Then remove the spring and unscrew the 12 threaded bars. Undo the 6 screws holding the saddles to the bridge. Then remove the spring and unscrew the 12 threaded bars.
    • Undo the 6 screws holding the saddles to the bridge. Then remove the spring and unscrew the 12 threaded bars.
  23. Unscrew bridge from the tremolo block.
    • Unscrew bridge from the tremolo block.
  24. Remove the four wood screws holding the neck to the body of the guitar.
    • Remove the four wood screws holding the neck to the body of the guitar.
  25. Pull neck away from main body.
    • Pull neck away from main body.
  26. Unscrew the two small screws securing the string trees to the headstock.
    • Unscrew the two small screws securing the string trees to the headstock.
  27. Unscrew the tuner bushings with a 10mm hex driver
    • Unscrew the tuner bushings with a 10mm hex driver
  28. Push the tuners from the front to pop them loose. It make take a bit of force if the alignment peg is stuck. Some use screws instead.
    • Push the tuners from the front to pop them loose. It make take a bit of force if the alignment peg is stuck. Some use screws instead.
  29. Remove the tension screw followed by the tuner button, metal and then fiber washer.
    • Remove the tension screw followed by the tuner button, metal and then fiber washer.
Guitar group
メンバー登録日: 2010年02月17日
259 ポイント
1ガイドが承認済み
10 件のコメント
Awesome teardown! Keep up the good work!
Matthew Newsom - 返信
totally agree
lon -
Great for a "tear-down" per-se, but horrible first steps for anyone to use to get inside their Fender Strat.
To get inside, don't unscrew every screw from the surface as is described here. The faceplate of a Fender Strat (and many other guitars) holds all the electronics to itself, so you only need to undo the screws around the edges and then lift off the faceplate to get to everything inside. From here you can remove the components that matter and solder or re-wire as is necessary, and then replace the faceplate as a single unit.
The steps in this article will lead to far more work than is necessary if you plan on fixing or replacing aspects of the guitar.
Topher Kessler - 返信
when I pulled off the knobs they pulled out a metal pin and the pin will not come out of the knob and I cant get the knob and pin to go back in
nellasemaj2000 - 返信
I'm having the same problem. Does anyone know the fix or have you found a solution?
Manny OK -
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 32
過去 30 日: 169
今までの合計 54,170
