はじめに
Here is Sony Xperia Z5 Compact teardown. This step-by-step guide will show you how to disassemble Xperia Z5 Compact and show all components inside.
必要な工具と部品
ビデオの概要
Release charging port connector.
Remove plastic protective bar.
Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
The motherboard may be attached to the case by a sticky pad near the charging connector. This can be dislodged by very carefully rotating the motherboard side to side, checking that the flex connectors aren't being stretched.
6 件のコメント
The Rear Camers is what rattles if tapped on the corners.
Shan Memon - 返信
My Z5 Compact frame is broken near to the power button (the color part).
Is there any way to buy just the frame?
alexandren - 返信
What is the black layer behind the LCD (which can be seen through squares left for SoC heatsinks). Is it a graphite cooling shield just like it is in XZ Premium?
