はじめに
SK17i Guide aint found anywhere on the www, so i figured i'd make one for the kind ppl, whom has provided some great guiden for me trough the repairs i've made :)
Please enjoy, and comment.
必要な工具と部品
Turn Off the phone :), Remove back cover, battery and simcard + sd card from the phone!
Unclip the keypad/screen ribbon cable
Unclip the camera
Unclip the small tabs holding the motherboard down and slide it out.
Once slide is removed, you got access to LCD and touch assembly. Easily remove the small flexcable from touch to LCD and take off LCD.
If you've got a new LCD assembly, probably no speaker is part of it. In that case don't forget to remove it from the defective assembly (see on the far left) and put it in the new assembly. It is simply mounted with adhesive.
27 件のコメント
@ Step 10: How a new LCD panel with the digitizer are glued again on to the metallic part???
George:
U need a "special" adhesive tape, a thin one, as the kind used for iphone 3GS touch screens.
Or you can buy another kind, it just have to be thin, STRONG and double sided!
What you do is: Cut the adhesive so it fits metal fram, NOT covering the sensors around the top.
After doing so, u fold the flex cables as they were on the old part. There should be some adhesive already on the LCD flex cables, that needs to be removed.
When thats done, you remove the coveredge on the doublesided adhesive tape, and place the touch + LCD firmly on it, now, press and hold for about 30seks, till you belive the touch is holding, mind the corners, press here also!
THEN your done, assemble the phone again, close your eyes and press the power button, hopefully your "lucky" and you got a picture on the screen hehe :D Good luck mate.
contact me on Skype: CRATERHEAD
Best Regards
Apple Repair Herning DNK
Palle Skov
Thanks so much! I'll probably get this: http://www.amazon.co.uk/Iphone-Touch-Pan...
George -
Åhh yes sir, my bad, the LCD aint glued to a metallic part, but its glued to the touch screen wich CAN NOT be separated!! Just like the iPhone 4, LCD screens + touch.
The touch glass however is softly glued to the "metallic" frame, bo biggie to remove!
Because:
In any case, you will need to buy a LCD assembly with the LCD already assemled with the touch screen!
Here: http://www.ebay.co.uk/itm/280781653630?s...
I will add
Hey dude...I am in a bad situation..I broke my mini pro some time back and ordered a touchscreen digitizer from here : http://www.ebay.com/itm/OEM-Digitizer-To...
Now, when I gave my handset to someone for repair, he sys me that he cannot change only the touchscreen because its glued badly to LCD and thus, will break even the LCD if he tries to do that. Now, he has made even my phone non usable and bad looking since he broke the touch component badly while repairing. What do you suggest..? Should he try to separate LCD and touch or is it of no use..? Shall I get my money refunded for touchscreen. Why is only then touchscreen being sold if they cannot be separated from LCD..:O..? Shall I better buy the complete assembly..? Please reply ..Thanks
