メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのExternal Storageを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Seagate 3TB Expansion Desktop Drive Teardown, Seagate 3TB Expansion Desktop Drive Teardown: 手順 1、 1の画像 1
    • Start at the plain end (the opposite side from the power jack) with the spudger. Carefully pry slightly up and away.
    • Once you have the end opened up, use the credit card to hold it open.
    • When you have the entire end separated, carefully pry the sides out and away along the adjoining two sides, working your way towards the end with the power jack. Save that end for last, it should lift away when you're done with the other sides.
  2. Seagate 3TB Expansion Desktop Drive Teardown: 手順 2、 3の画像 1 Seagate 3TB Expansion Desktop Drive Teardown: 手順 2、 3の画像 2 Seagate 3TB Expansion Desktop Drive Teardown: 手順 2、 3の画像 3
    • Work around the drive, ends first then the sides to open it
    • This is really challenging and I did end up breaking some of the clips. Its pretty hard to tear apart.
  3. Seagate 3TB Expansion Desktop Drive Teardown: 手順 3、 1の画像 1
    • Gently pull the sides slightly and the drive will lift out
  4. Seagate 3TB Expansion Desktop Drive Teardown: 手順 4、 3の画像 1 Seagate 3TB Expansion Desktop Drive Teardown: 手順 4、 3の画像 2 Seagate 3TB Expansion Desktop Drive Teardown: 手順 4、 3の画像 3
    • Pull the rubber screw covers off, these are mounted with a little glue and came off easily
    • Remove all four screws with the philips screwdriver
  5. Seagate 3TB Expansion Desktop Drive Teardown: 手順 5、 3の画像 1 Seagate 3TB Expansion Desktop Drive Teardown: 手順 5、 3の画像 2 Seagate 3TB Expansion Desktop Drive Teardown: 手順 5、 3の画像 3
    • Slide drive out of metal caddy (do not lift)
    • You will now have a SATA Hard Drive and the caddy separate
  6. Seagate 3TB Expansion Desktop Drive Teardown: 手順 6、 3の画像 1 Seagate 3TB Expansion Desktop Drive Teardown: 手順 6、 3の画像 2 Seagate 3TB Expansion Desktop Drive Teardown: 手順 6、 3の画像 3
    • From the bottom of the caddy there are two black screws
    • With the Philips screwdriver you can remove these
    • Pull the circuit board gently and evenly to remove it
作成者
4人の作成者と共同で作成されました。
Edd
メンバー登録日: 04/08/13
535 ポイント
2のガイドは作成済み
3 件のコメント
if i add a different adapter that doesnt require power, will the drive still work?
sulz - 返信
Does anyone know what to do if the Data port does not work ?
remus lungeanu - 返信
Thanks... I probably broke every clip in the process, but I finally got it apart... Tested the drive in another external USB case and still can't see the drive, so my hope that it was the case circuitry that was bad was crushed... 3TB paperweight... Thanks Seagate :(
Sean Seoltoir - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 57
今までの合計 56,385
