必要な工具と部品
Using a small Phillips screwdriver, remove the screws from the bottom of the plastic case.
Rubber feet in the four corners must be removed first to gain access to the screws underneath. A sticker may also be covering the middle screw on the left.
Thanks so much for this! I’m a teacher and had to finish gifts yesterday. My laminator ate one of the kids pictures! Thanks to your post, I was able to take apart the laminator, get the picture out, and all was well! I appreciate it!
Pull off the silver plastic cover and gain access to the internal components.
The rollers, motor, circuit board, and LEDs are all visible now.
First unplug all three wire headers connected to the circuit board.
Unscrew the two screws holding down the circuit board by its corners and remove the board from the laminator.
Hold the roller enclosure from both sides, indicated by the markers, and pull upwards and slightly out.
Free access to the motor and rollers is now possible.
Remove the motor from the rollers by unscrewing the three screws holding them together.
Remove the sensor from the roller enclosure by unscrewing the two spring-loaded screws.
Pull the black washers sideways off the metal rod of the roller.
Pull the gears off.
With the gears off, the plastic panel falls off and the rollers come out of the enclosure.
The laminator is now disassembled.
Where can you get circuit boards for these
Thank you so much, this is very helpful! - a grateful teacher
16 件のコメント
Why is the screw on the left side so hard to get out?
Thank you! Just needed to open and remove a jam. Followed your guide and all is well.
KQuinn
Kate Quinn - 返信
Thank you for posting these instructions. I was able to remove a quarter that got trapped inside.
Thank you! My son fed a sheet in the wrong way and it got completely jammed. Following your instructions, I was able to take the cover off and pull the jammed plastic out. I would NEVER have thought to remove the rubber feet to look for screws!!
Can you provide instructions on re-assembly? I seem to be lost on the little bar with the hook.
I have one with the power cord cut completely off, just behind the machine. Theres not even enough cord left, machine side, to splice it back together. Would removing the plug/cord completely and replacing it with a new one (or the rest of the old one) be an option? Or am i just squat outta luck! Thanks
Thanks! Just fixed it!!! mine was jammed
Need to replace the thermal fuse just asking how many degrees is it?
I have this unit and bought it new out of the box at a thrift shop. Found out the thermal sensor that rests against the bottom roller was cracked in half, so it didn’t see any use because of this. Is there anyone that happens to know what the value of this sensor is so I could solder in a replacement?
have the TL901 laminator. Still laminates but the ready light does not go on. what could be the issue. thx.
Thank you this was very helpful I appreciate the pictures and the instructions! Hope you have a great day God bless.
